eyesuncloudedphoto Posted September 21, 2018 Share Posted September 21, 2018 12 minutes ago, Mmmbeats said: I'm guessing then there are no implications for video? (of pixel-shift) Can't see how it can be used for video. It's the same mechanism that does IBIS, by the way 3 minutes ago, KnightsFan said: I wonder if Panasonic will use a <1mm sensor stack like Leica does? If so, some lenses designed for film might have slightly better performance here than on the new Sony/Canon/Nikon. I think the big question for all is whether this will be a Sony manufactured sensor or Panasonic will go for a Samsung or Towerjazz design. I find the non-Sony option very exciting. Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted September 21, 2018 Super Members Share Posted September 21, 2018 35 minutes ago, eyesuncloudedphoto said: Exactly. I'm on the same boat, and let's not forget Panasonic in general always had a tradition for innovation and very few weaknesses with their cameras. E.g. apart from the sensor limitations (where applicable) and video AF (for the most part, although improved), the GH5/G9 are almost perfect hybrid cameras IMHO. I agree, the G9 is a few tweaks from the perfect hybrid. I don't care about much of the stuff people ask for. A little extra bitrate or a new log profile isn't as important to me as things like Canons way seamless stills to video switch, Panasonics ability to take stills with the mechanical shutter during recording or Fujis "dual menus" for video and stills. These are the type of things I really want. Marketing specs is just icing on the cake. Panasonic usually delivers both. Thats why a FF from them gets me very, very excited. 38 minutes ago, eyesuncloudedphoto said: It can do much more: as Hasselblad does, it can also get true color information for each pixel (three different positions) and still produce a "base" resolution image with much improved (accurate) color. Yup, I just tried to give the fast version newfoundmass 1 Link to comment Share on other sites More sharing options...
kye Posted September 21, 2018 Share Posted September 21, 2018 49 minutes ago, Mmmbeats said: I'm guessing then there are no implications for video? (of pixel-shift) Unlikely as it's combining multiple frames together, so if the subject is moving then it'll be like a worse version of when the de-interlacing isn't done right! Of course, it kind of depends on how fast it can capture the images. Apple combine multiple exposures in the iPhone cameras to get better low light, so in theory you could build something that attempted it, but we're probably a few tech cycles away of it being good enough to release to the public, and by then we'll have 8K and not need pixel shift to get the resolution, we'll just have more pixels Link to comment Share on other sites More sharing options...
PannySVHS Posted September 21, 2018 Share Posted September 21, 2018 wowsers, that with zero sharpening and NR, also 10bit in vfr and true hd quality up to 120p and interframe 400mbit for HD 120fps! Link to comment Share on other sites More sharing options...
vas Posted September 22, 2018 Share Posted September 22, 2018 4k 60p, IBS, clean ISO 6400, 1080 240fps at high bit rate, and I'm all in. Link to comment Share on other sites More sharing options...
Thpriest Posted September 22, 2018 Share Posted September 22, 2018 This camera sounds pretty interesting. What would be great is if the new lens system could be adapted to the m43 line through a Panasonic speedbooster with and integrated ND(no idea if that's possible). I think if Panasonic could really integrate the FF, m43 and EVA1 as far as colours, VLOG recording codecs etc are concerned they'd really dominate the market. Back when I was using the Canon C100 as my main camera I was always frustrated that I couldn't find a good B cam with in the Canon range. I tried the 7D, 700D, 5d mk... and they all looked poor next to the C100 footage. The XC10 just wasn't up to it in lowlight situations. So a FF Panasonic paired with the GH5s/GH5 sounds very interesting. Or maybe I have no idea what I'm talking about!!!? Link to comment Share on other sites More sharing options...
eyesuncloudedphoto Posted September 22, 2018 Share Posted September 22, 2018 19 minutes ago, Thpriest said: This camera sounds pretty interesting. What would be great is if the new lens system could be adapted to the m43 line through a Panasonic speedbooster with and integrated ND(no idea if that's possible). Unfortunately, not. The L-mount is 19mm flange distance, while m43 is 19.25mm. The option for a dummy "ring" adapter is certainly feasible, but I'm not optimistic that electronics could be fitted for AF and EXIF. OTOH you never know. Extra optical elements or ND integration are out of the question though. What I hope for is an electronic ND filter in the camera (a physical one would again be very hard to implement). Link to comment Share on other sites More sharing options...
Thpriest Posted September 22, 2018 Share Posted September 22, 2018 2 minutes ago, eyesuncloudedphoto said: Unfortunately, not. The L-mount is 19mm flange distance, while m43 is 19.25mm. The option for a dummy "ring" adapter is certainly feasible, but I'm not optimistic that electronics could be fitted for AF and EXIF. OTOH you never know. Extra optical elements or ND integration are out of the question though. What I hope for is an electronic ND filter in the camera (a physical one would again be very hard to implement). Bummer. Anyway, if the colours and 4k have a similar look and feel (FF vs m43/Speedboster besides) then it still could work as a properly integrated system. Link to comment Share on other sites More sharing options...
eyesuncloudedphoto Posted September 22, 2018 Share Posted September 22, 2018 27 minutes ago, Thpriest said: Bummer. Anyway, if the colours and 4k have a similar look and feel (FF vs m43/Speedboster besides) then it still could work as a properly integrated system. There is a rumor (or is it confirmed already? I don't remember) about a new firmware update coming up for GH5(s)/G9. Could it make color science more consistent among cameras? Can it be done with firmware only or is it too much sensor-specific? If Panasonic gives us an updated color science which is more or less the same in their whole line of cameras, they will dominate everything. This and high-performance video AF is their only relative weaknesses against the competition. Thpriest 1 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted September 22, 2018 Super Members Share Posted September 22, 2018 A version of Aputure's DEC Vari ND with electronic Follow Focus to go from EF to SL would be feasible though. Link to comment Share on other sites More sharing options...
androidlad Posted September 22, 2018 Share Posted September 22, 2018 I was told that TowerJazz, a CMOS sensor manufacturer, just signed off a large order with a big client for its FF global shutter sensor, the client is very likely to be Panasonic. Link to comment Share on other sites More sharing options...
jonpais Posted September 22, 2018 Share Posted September 22, 2018 (L3) Sigma is going ot make an EF to L-mount adapter and also release their current lenses as L-mount Link to comment Share on other sites More sharing options...
matthere Posted September 22, 2018 Share Posted September 22, 2018 Which mounts can be adapted to the L mount? Link to comment Share on other sites More sharing options...
KnightsFan Posted September 22, 2018 Share Posted September 22, 2018 Which mounts can be adapted to the L mount? https://en.m.wikipedia.org/wiki/Flange_focal_distance look at this list. Any lens with a flange distance LONGER than a camera can be adapted with a simple mechanical adapter, but not vice versa. So you can put an ef lens on an l mount, but you can't put an l lens on an Ef mount so you can adapt f, ef, m42, pl, and many others to l. whether or not you can electronically control the adapted lens depends on whether the lens protocol is open, or if someone has reverse engineered it. matthere 1 Link to comment Share on other sites More sharing options...
kye Posted September 22, 2018 Share Posted September 22, 2018 1 hour ago, jonpais said: (L3) Sigma is going ot make an EF to L-mount adapter and also release their current lenses as L-mount That totally makes sense. I think this industry is in a period of rationalisation where the smaller players will die unless they form alliances strong enough to challenge the big players. Sigma has a native mount but no real share of the camera body market, and they have been making lenses that seem to be (are?) designed to be adaptable. If the announcement included Sigma saying that all of their FF lenses with convertible lens mounts could be converted to this new mount then they would definitely win the lens availability category against canikon! I'm not sure what they will release but out of all the rumours this year I'm optimistic that they'll deliver a larger percentage of what is technically possible and what we want than the other manufacturers attempts. Link to comment Share on other sites More sharing options...
KnightsFan Posted September 22, 2018 Share Posted September 22, 2018 1 hour ago, jonpais said: (L3) Sigma is going ot make an EF to L-mount adapter and also release their current lenses as L-mount Not surprised! It would be nice if they took a note out of Canon's playbook, and included a rear filter slot and/or electronic ring on the adapter. Link to comment Share on other sites More sharing options...
arson519 Posted September 22, 2018 Share Posted September 22, 2018 this news is making want to me sell all my sony ff gear ASAP Im Ready Link to comment Share on other sites More sharing options...
Rinad Amir Posted September 22, 2018 Share Posted September 22, 2018 I really hope the new FF GH model will have full Log curve instead of lite deezid 1 Link to comment Share on other sites More sharing options...
deezid Posted September 23, 2018 Share Posted September 23, 2018 1 hour ago, Rinad Amir said: I really hope the new FF GH model will have full Log curve instead of lite And finally V-Gamut compatible and no sharpening (like the EVA-1). but who knows... Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted September 23, 2018 Share Posted September 23, 2018 Hmm global shutter will probably mean subpar dynamic range and low light. No rolling shutter would be great for weddings though, no half screen flashes from the rolling shutter. Link to comment Share on other sites More sharing options...
