jcs Posted May 23, 2013 Share Posted May 23, 2013 1. Convert to DNG with raw2dng 2. Open all DNGs with Photoshop CS6, this opens up ACR 3. Press Select All and Synchronize (upper left on screen) 4. Grade, do noise reduction, etc. 5. Press Save All and save to JPG at 100% (grading is done, so 8-bit is OK). 6. In Premiere CS6, import first JPG, then press checkbox for Image Squence. 7. Modify clip- Interpret Footage as 23.976. This is pretty fast once you do it a few times (much faster than an AE workflow), and plays back in real-time in Premiere. To get a 10-bit 422 workflow, Cinema 5D recommended saving first to 16-bit TIF, then converting to ProRes (Mac. On PC can do DNxHD, etc.). A 4GB RAW file produces around 270MB in 100% quality JPGs (47 seconds). stargazer 1 Link to comment Share on other sites More sharing options...
nahua Posted May 23, 2013 Share Posted May 23, 2013 Will PNGs retain all the color information? I'd like to try this since doing the AE workflow is dog slow. Where do I find raw2png? And will interpreting footage to 24P help? I find in AE I still have to conform EACH clip to 120% speed, just changing the comp to 24P doesn't work. Link to comment Share on other sites More sharing options...
jcs Posted May 23, 2013 Author Share Posted May 23, 2013 Sorry- working on other project with PNGs- meant DNG. Corrected original post. The TIF workflow to ProRes or DNxHD will get you color bits > 8. Link to comment Share on other sites More sharing options...
jcs Posted May 24, 2013 Author Share Posted May 24, 2013 Using the May 22 ML and latest raw2dng, with 2800+ DNG frames, PS CS6 chokes... Link to comment Share on other sites More sharing options...
nahua Posted May 24, 2013 Share Posted May 24, 2013 Ah OK well I'll see how much better PS is versus AE. Not sure if PS was meant to process that many frames. Wonder if this can be batch processed with an action or something? Link to comment Share on other sites More sharing options...
Julian Posted May 24, 2013 Share Posted May 24, 2013 Don't open all the DNG's in CS6/ACR, that's unnecessary. Â 1. Open Photoshop 2. Open Bridge (File, Browse in Bridge) 3. Navigate to your DNG's, open one DNG of your sequence and edit it, just press 'done' when finnished. 4. Back to bridge, select the edited DNG, right click > develop settings > copy settings. 5. Select all DNG's from the sequence, right click > develop settings > paste settings. 6. Select all > right click > export to > hard drive, etc! Â Exporting the frames takes most of the time. You could first grade all your shots, copy all the settings, when everything is done select all your shots (probably in seperate folders, just sellect the folders), export everything while you take a break.. :) Â For windows users there is a great app to create a quick proxy, you can use it to preview your files for example. http://www.magiclantern.fm/forum/index.php?topic=5557.0 Link to comment Share on other sites More sharing options...
jcs Posted May 24, 2013 Author Share Posted May 24, 2013 Thanks for the tip Julian- Bridge CS6 on a 12-Core MacPro also choked with 2813 files. AE works so far- will also explore the other tools mentioned on the ML site. Link to comment Share on other sites More sharing options...
Oedipax Posted May 25, 2013 Share Posted May 25, 2013 And will interpreting footage to 24P help? I find in AE I still have to conform EACH clip to 120% speed, just changing the comp to 24P doesn't work. nahua, you're doing this wrong - you need to interpret your image sequences as 23.976, and set your sequences to 23.976. Then they will play back at the correct 24fps without any interpolation or repeated frames. You can go a step further and go to Preferences/Import and set 23.976 as your default framerate so that new image sequences that get imported already have the right framerate. Julian 1 Link to comment Share on other sites More sharing options...
