bmpcc4k t5 alternative?
capitanazo
Hi, im getting ready to get my bmpcc4k ready for the launch, and im decided that usb-c ssd would be my best alternative for record.
now i got a chance to record with alexa mini, and some red cameras but one of the requeriments is i have is to had 1 ssd at least.
so i was thinking in get some ssd and buy a case to usb-c 3.1 to have the option to use te same ssd for work with the red and alexa cameras and
my bmpcc4k.
so, https://www.amazon.com/Satechi-Aluminum-2-5-inch-Enclosure-Interface/dp/B01FWT2N4E this case can do the work?
its there any other requeriment on bmpcc4k for use usb-c ssd?
Bye!
my bmpcc4k.
Bye!
If you don't mind the size then this will be cheaper than the Samsung T5.
All you need is an enclosure (lots out there so look around, as you might find cheaper & be careful, as you should be getting Read/Write speeds of about 400 min - should be over 500 if it's a good enclosure) & the Samsung SSD 860 evo (has the best TBW or lifespan), there are other brands which might be cheaper. This solution will be cheaper, but bigger than the T5 - that's why the T5 is so much more expensive.
I've gone this way for external storage (also can double as hard drive to boot from), but didn't bother with an enclosure & just got a cable - a lot cheaper & faster read/write speeds than the T5 (mine gets well over 500 for R/W speeds).
nicee!
i would start looking, here in my country sell t5 has double of the price, so the sdd and enclosure would be awesome.
my only concern its maybe bus powered is a requeriment for record on bmpcc4k and if enclosoure will power it up.
16 minutes ago, capitanazo said:
nicee!
I think only the HDD need external power. And any enclosure that needs external power will have 2 cables coming from it.
I use this wire & the SSD gets powered by the computer:
https://www.amazon.co.uk/Sabrent-2-5-Inch-Adapter-Optimized-EC-SS31/dp/B014T3JRFM/ref=sr_1_sc_2?tag=macr0e-21&s=pc&ie=UTF8&qid=1480434478&sr=1-2-spell&keywords=sabremt%2Busb3%2Bto%2Bssd&th=1
It's exactly the same as the T5, so the camera will power the SSD. Be careful of which enclosure you get, as some aren't great & actually slow down the Read/Write rates, which might mean you might not be able to record. Personally, when I get the P4K I am just going to use the SSD without an enclosure & just keep it in a jacket pocket because the SSD is already in a case.
  • 1 month later...
heres a list of approved cards and ssd's
What CFast cards should I use with Blackmagic Pocket Cinema Camera 4K?
The following CFast 2.0 cards are recommended for recording 4K DCI Lossless RAW up to 30 fps.
AngelbirdAV PRO CF128GB
AngelbirdAV PRO CF256GB
AngelbirdAV PRO CF512GB
Komputerbay3400x CFast 2.0128GB
ProGrade Digital550MB/s CFast 2.0256GB
ProGrade Digital550MB/s CFast 2.0512GB
SanDiskExtreme Pro CFast 2.0 SDCFSP-64G-x46D64GB
SanDiskExtreme Pro CFast 2.0 SDCFSP-128G-x46D128GB
SanDiskExtreme Pro CFast 2.0 SDCFSP-256G-x46D256GB
SonyCFast 2.0 G Series CAT-G6464GB
SonyCFast 2.0 G Series CAT-G128128GB
WISECFast 2.0 3400x128GB
WISECFast 2.0 3400x256GB
WISECFast 2.0 3500x512GB
The following CFast 2.0 cards are recommended for recording 4K DCI 3:1 RAW up to 60 fps.
KomputerBay3400x CFast 2.0128GB
WISECFast 2.0 3400x512GB
The following CFast 2.0 cards are recommended for recording 4K DCI ProRes HQ up to 60 fps.
AngelbirdAVpro CF128GB
AngelbirdAVpro CF256GB
AngelbirdAVpro CF512GB
What SD cards should I use with Blackmagic Pocket Cinema Camera 4K?
The following SD cards are recommended for recording 4K DCI 4:1 RAW up to 60 fps.
SonyTough SF-G64T64GB
SonyTough SF-G128T128GB
ToshibaExceria Pro UHS-II N502 SDXC32GB
The following SD cards are recommended for recording 1080p Lossless RAW up to 60 fps.
WISESDXC UHS-II64GB
WISESDXC UHS-II128GB
ToshibaExceria Pro UHS-II N502 SDXC64GB
ToshibaExceria Pro UHS-II N502 SDXC128GB
ToshibaExceria Pro UHS-II N502 SDXC256GB
The following SD cards are recommended for recording 4K DCI Lossless RAW up to 24 fps.
WISESDXC UHS-II64GB
The following SD cards are recommended for recording 4K DCI ProRes HQ up to 60 fps.
WISESDXC UHS-II64GB
What USB‑C drives should I use with Blackmagic Pocket Cinema Camera 4K?
The following USB-C drives are recommended for recording 4K DCI Lossless RAW up to 30 fps.
AngelbirdSSD2GO PKT512GB
AngelbirdSSD2GO PKT2TB
WISEPortable SSD256GB
WISEPortable SSD512GB
SamsungPortable SSD T51TB
The following USB-C drives are recommended for recording 4K DCI 3:1 RAW up to 60 fps.
SamsungPortable SSD T5500GB
The following USB-C drives are recommended for recording 4K DCI ProRes HQ up to 60 fps.
GlyphAtom500GB
SandiskExtreme Portable SSD1TB
ssd's seemed to have dropped in price the last couple of days, i swear msy  a computer shop in my country had the t5 1t listed for $395 a few days ago.someone said that b&h were having a special on ssd so i had a look $ 316 damn that was tempting so i had another look at msy their now $329 looks like their about $70 cheaper at the moment  it seems, not sure how long that will last. if their the same price next pay day i'm grabbing one.
