Wynand Posted September 9, 2018 Share Posted September 9, 2018 Maybe an already asked question (although I could not find it directly...) but I have the GH5 S. I also have a GH4 and use it with my normal Metabones XL (.64). As discussed on the forum the XL is/was made for the GH4 and not for the GH5... Having said that, the GH5 S has an even wider sensor! I mainly shoot with Rokinon / Samyang CINE lenses - all manual. My FF Samyang 85mm works well on the GH5 S via the XL BUT my Rokinon CINE 10mm APSC has an issue (showing two black lines on both sides of the lens / sensor...) Question then... will the Metabones Ultra .71 be enough to eliminate this?? Many thanks for the much needed info in advance!! Link to comment Share on other sites More sharing options...
IronFilm Posted September 11, 2018 Share Posted September 11, 2018 GH5S + x0.64 focal reducer gives a larger than APS-C FoV, in fact it is beginning to near on vistavision/FF FoV! GH5S + x0.71 gives a bit larger than APS-C FoV, but not by so much. Thus an APS-C designed lens might or might not work, depending on the lens. As many lenses do cover a bit larger image circle (so as to improve edge performance). Also it depends on how you're going to use it, a lens which might slightly vignette for 16:9 won't if you crop the image for a 2.39:1 aspect ratio. Adam Kuźniar 1 Link to comment Share on other sites More sharing options...
webrunner5 Posted September 11, 2018 Share Posted September 11, 2018 1 hour ago, IronFilm said: GH5S + x0.64 focal reducer gives a larger than APS-C FoV, in fact it is beginning to near on vistavision/FF FoV! GH5S + x0.71 gives a bit larger than APS-C FoV, but not by so much. Thus an APS-C designed lens might or might not work, depending on the lens. As many lenses do cover a bit larger image circle (so as to improve edge performance). Also it depends on how you're going to use it, a lens which might slightly vignette for 16:9 won't if you crop the image for a 2.39:1 aspect ratio. Great advice. Informative post. Eh, out of likes. ? Link to comment Share on other sites More sharing options...
