JVC GY-HC500 & GY-HC550
AlexTrinder96
'JVC has announced two new models in their Connected cam range – the GY-HC500 and the GY-HC550 JVC’s Connected Cam series are designed specifically so users can live stream and FTP file transfer directly from the camera. JVC has really made a name for themselves with smart cameras that can be used for news, sports and event coverage'
https://www.newsshooter.com/2018/09/11/jvc-gy-hc500-gc550/
Recording Codecs
Apple ProRes 422, MPEG-4 AVC/H.264, MPEG-2*
4K UHD 60p/50p
(Apple ProRes 422) 3840 × 2160, Apple ProRes 422 HQ/Apple ProRes 422/Apple ProRes 422 LT, 10-bit
4K UHD 30p/25p/24p
(H.264) 3840 × 2160, 4:2:2 10-bit / 4:2:0 8-bit 150Mbps/70Mbps (MOV)
HD (H.264) 1920 × 1080/1280 × 720, 4:2:2 10-bit / 4:2:0 8-bit
50Mbps ~ 8Mbps (MOV/MP4)
HD (MPEG-2 Long GOP)* 1920 × 1080/1440 × 1080/1280 × 720, 35Mbps /25Mbps (MOV/MXF)
SD (H.264) 720 × 480/576, 8Mbps (MOV)
Proxy (H.264) 960 × 540/480 × 270, 3 ~ 1.2Mbps(MOV)
Streaming Specs:
1920 × 1080 (59.94p/50p) 20 ~ 8Mbps
1920 × 1080 (29.97p/25p) 20 ~ 3Mbps
1920 × 1080 (59.94i/50i) 20 ~ 3Mbps
1280 × 720 (59.94p/50p) 20 ~ 3Mbps
1280 × 720 (29.97p/25p) 8 ~ 1.5Mbps
720 × 480 (59.94i), 720 x 576 (50i) 8 ~ 0.3 Mbps
640 × 360 (59.94p/50p) 3/1.5Mbps
640 × 360 (29.97p/25p) 3 ~ 0.3Mbps
Connections
3G-SDI (BNC × 1)、HDMI × 1、AV (Φ3.5mm)  XLR × 2(MIC、+48V/LINE), φ3.5mm
RCA × 1
USB(3.0)
Ethernet RJ-45 ×1
LAN 2.4GHz/5GHz MIMO
SSD
53 minutes ago, Kisaha said:
Where is the LS500?!
Not the LS300mkII but an upper tier camera.
I'd be happy to settle for getting excited over a LS300 mk2 (or a firmware update) which is more or less the same as the LS300 mk1 but adds 4K 60fps 10bit internal
4K UHD 60p/50p
 4K UHD 30p/25p/24p
So close yet so far! If only this was a S35 camera.
I'm interested in these, I'd like for the thread to stay open so we can talk about them as more info emerges / reviews start to trickle in.
JVC honestly might be the camera company that gives you the most bang for your buck, in terms of features and stuff. My biggest issue with them is their menu system feels ancient and bloated. My LS300 still has the ui of a 90s camcorder and just feels ancient. But I love the picture!
