Inazuma Posted September 28, 2018 Share Posted September 28, 2018 My Commodore won't run these h264 files. Outrageous! Brian Williams, homestar_kevin and Thomas Hill 1 2 Link to comment Share on other sites More sharing options...
Ty Harper Posted September 28, 2018 Share Posted September 28, 2018 Anyone with experience with the Fujinon 10-24mm f4 OIS? Link to comment Share on other sites More sharing options...
Brian Williams Posted September 28, 2018 Share Posted September 28, 2018 On 9/28/2018 at 4:19 PM, Jimmy said: Interesting to see the xh1 will get a 2 stop upgrade to ibis when used with ois lenses too. Their upgrade program is truly great! Expand I feel like I've said this way too many times here, and people probably think I'm just trolling bc no one ever responds to it- when I spent a week with the X-H1, I found the ibis to be almost unusable for video, unless you are standing completely still, way to jerky otherwise. Has this changed, or is this not your experience with it? I would possibly return my X-T3 and go with the X-H1 if I thought the stabilization had improved (I'm coming from past GH5 ownership so I'm spoiled in the stabilization department and prefer good stabilization over 10bit if I had to choose), esp since, knowing Fuji, the X-H1 may get some of the X-T3's features at some point through firmware. padam 1 Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted September 28, 2018 Super Members Share Posted September 28, 2018 On 9/28/2018 at 6:26 PM, Brian Williams said: - when I spent a week with the X-H1, I found the ibis to be almost unusable for video, unless you are standing completely still, way to jerky otherwise. Expand That is not my experience at all. Its very usable for video. Almost as good as my Panasonic G80/85. frontfocus 1 Link to comment Share on other sites More sharing options...
Inazuma Posted September 28, 2018 Share Posted September 28, 2018 I heard it was improved with firmware Link to comment Share on other sites More sharing options...
Henry Ciullo Posted September 28, 2018 Share Posted September 28, 2018 I will be receiving my x-t3 wednesday. Regarding battery life, anybody can confirm you can recharge via usb, and camera if camera can actually be powered via usb? I'm used to power my BMPCC and Pana GX80 via usb power bank so it would be cool if I could still use my power bank instead of buying lots of batteries. Link to comment Share on other sites More sharing options...
Brian Williams Posted September 28, 2018 Share Posted September 28, 2018 On 9/28/2018 at 6:49 PM, Mattias Burling said: That is not my experience at all. Its very usable for video. Almost as good as my Panasonic G80/85. Expand Really? You don't get jerkiness if panning or moving side to side? Walking forward or standing still I found it to be great, but any movement left or right caused the sensor to keep jerking back into position. Well thats disappointing, I was hoping someone would say a firmware had come out to improve or was on the way, not that I'm imagining things. I see- https://www.fujirumors.com/fujifilm-x-h1-firmware-update-will-improve-ibis-in-2018/ Link to comment Share on other sites More sharing options...
Jimmy Posted September 28, 2018 Share Posted September 28, 2018 What lens were you using?... the 18-55 seems fine for dolly/pan type shots, especially at the wide end. Link to comment Share on other sites More sharing options...
Brian Williams Posted September 28, 2018 Share Posted September 28, 2018 On 9/28/2018 at 7:30 PM, Jimmy said: What lens were you using?... the 18-55 seems fine for dolly/pan type shots, especially at the wide end. Expand Sorry, I didn't mean to hi-jack the x-t3 topic with x-h1 comments. I believe it was either the 23mm f2 or 35mm f2. Here is the only clip I have from my time with the camera, around the :15 sec mark I think you can see the jerkiness when panning. Link to comment Share on other sites More sharing options...
frontfocus Posted September 28, 2018 Share Posted September 28, 2018 On 9/28/2018 at 7:07 PM, Henry Ciullo said: Regarding battery life, anybody can confirm you can recharge via usb, and camera if camera can actually be powered via usb? Expand yes to both Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted September 29, 2018 Share Posted September 29, 2018 I'd love to see a under/over dynamic range test for the XT3. gethin 1 Link to comment Share on other sites More sharing options...
androidlad Posted September 29, 2018 Share Posted September 29, 2018 Fuji Kaizen update news: 1. X-H1 to receive firmware update to offer dual IS (IBIS + lens OIS), which adds 1.5-2 stops of additional stablisation. 2. X-T3 (and very likely X-H1/X-T2) to receive firmware update to enable file size larger than 4GB when using SD cards formatted as exFAT (64GB+). Link to comment Share on other sites More sharing options...
androidlad Posted September 29, 2018 Share Posted September 29, 2018 X-T3 10bit encoding anaylsis from Weibo: https://www.weibo.com/KazuoHiraiSONY?is_hot=1#1538181717102 X-T3 10bit HEVC encoder has SAO (Sample Adaptive Offset) and SIS (Strong Intra Smoothing) filters enabled, which unfortunately reduces high frequency detail. Link to comment Share on other sites More sharing options...
Attila Bakos Posted September 29, 2018 Share Posted September 29, 2018 On 9/29/2018 at 12:47 AM, androidlad said: X-T3 10bit encoding anaylsis from Weibo: https://www.weibo.com/KazuoHiraiSONY?is_hot=1#1538181717102 X-T3 10bit HEVC encoder has SAO (Sample Adaptive Offset) and SIS (Strong Intra Smoothing) filters enabled, which unfortunately reduces high frequency detail. Expand While that might be true, both are designed to reduce artifacts like banding, blocking, ringing, and both are enabled in x265 by default, so I guess it's nothing to worry about. Link to comment Share on other sites More sharing options...
androidlad Posted September 29, 2018 Share Posted September 29, 2018 On 9/29/2018 at 5:38 AM, Attila Bakos said: While that might be true, both are designed to reduce artifacts like banding, blocking, ringing, and both are enabled in x265 by default, so I guess it's nothing to worry about. Expand Yes, these two filters are designed to preserve overall image quality at low bitrate, at 200/400Mbps bitrate Fuji implemented, they really should disable those filters to allow more fine detail to come through. Link to comment Share on other sites More sharing options...
Attila Bakos Posted September 29, 2018 Share Posted September 29, 2018 On 9/29/2018 at 5:48 AM, androidlad said: Yes, these two filters are designed to preserve overall image quality at low bitrate, at 200/400Mbps bitrate Fuji implemented, they really should disable those filters to allow more fine detail to come through. Expand But do they really reduce fine detail at these high bitrates? Would love to see a comparison, maybe this is for pixel peepers only. Link to comment Share on other sites More sharing options...
androidlad Posted September 29, 2018 Share Posted September 29, 2018 On 9/29/2018 at 6:20 AM, Attila Bakos said: But do they really reduce fine detail at these high bitrates? Would love to see a comparison, maybe this is for pixel peepers only. Expand SAO and SIS are essentially smoothing filters and are bitrate independent. UHD BD authoring tools have these turned off. http://iphome.hhi.de/wiegand/assets/pdfs/2012_12_IEEE-HEVC-Performance.pdf Link to comment Share on other sites More sharing options...
Attila Bakos Posted September 29, 2018 Share Posted September 29, 2018 On 9/29/2018 at 6:31 AM, androidlad said: SAO and SIS are essentially smoothing filters and are bitrate independent. UHD BD authoring tools have these turned off. http://iphome.hhi.de/wiegand/assets/pdfs/2012_12_IEEE-HEVC-Performance.pdf Expand Well, all we need is someone with an X-T3 and an external recorder to see if there's any visible difference. Link to comment Share on other sites More sharing options...
Simon Young Posted September 29, 2018 Share Posted September 29, 2018 On 9/29/2018 at 12:03 AM, androidlad said: Expand On 9/29/2018 at 12:03 AM, androidlad said: Fuji Kaizen update news: 1. X-H1 to receive firmware update to offer dual IS (IBIS + lens OIS), which adds 1.5-2 stops of additional stablisation. 2. X-T3 (and very likely X-H1/X-T2) to receive firmware update to enable file size larger than 4GB when using SD cards formatted as exFAT (64GB+). Expand Please give us a believable source. You’re not Luke Mason in disguise are you? Back with a vengeance, dropping “knowledge” here citing no one except yourself or, in this case, some obscure Weibo account. Viridian 1 Link to comment Share on other sites More sharing options...
androidlad Posted September 29, 2018 Share Posted September 29, 2018 On 9/29/2018 at 8:12 AM, Simon Young said: Please give us a believable source. You’re not Luke Mason in disguise are you? Back with a vengeance, dropping “knowledge” here citing no one except yourself or, in this case, some obscure Weibo account. Expand Ha I'm not that daft prick, are you? https://www.fujirumors.com/fujifilm-x-t3-new-firmware-will-add-exfat-file-system-support-eliminating-4gb-file-size-limit/ The Weibo lady is a well respected figure in the Japanese semiconductor industry. Link to comment Share on other sites More sharing options...
