Snowbro Posted December 21, 2018 Share Posted December 21, 2018 4 hours ago, thephoenix said: the great feature would be ot have a peaking that actually is efficient Burn Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted December 21, 2018 Share Posted December 21, 2018 12 hours ago, thephoenix said: the great feature would be ot have a peaking that actually is efficient I've never found peaking useful, but maybe the cameras I've used all had it poorly implemented. Link to comment Share on other sites More sharing options...
thephoenix Posted December 21, 2018 Share Posted December 21, 2018 1 minute ago, thebrothersthre3 said: I've never found peaking useful, but maybe the cameras I've used all had it poorly implemented. very usefull when shooting handheld and you don't rely on the af. but compared to the 5d mkII with magic lantern the fuji peaking is useless at moments areas that are in focus aren't visible because the dots are far too small and fade into the material wtf Link to comment Share on other sites More sharing options...
webrunner5 Posted December 21, 2018 Share Posted December 21, 2018 I know peaking was pretty damn good in my Sony a7s. I used it all the time with MF lenses. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted December 21, 2018 Share Posted December 21, 2018 I've only ever used it on the A6300 and all the Pana GH cameras. Never could get reliable results without using a larger external monitor. I've never used Canon or the A7 series tho Link to comment Share on other sites More sharing options...
webrunner5 Posted December 21, 2018 Share Posted December 21, 2018 I never have owned a A6000 series camera, but i would imagine the A6300 was close to the same as a a7s? I have never worn glasses so maybe that helps me, I don't know. But I had my original A7, A7r and never ever owned a native lens for them. Always used old MF FF lenses. But it was mostly for Photos, so on average I had the time to tweak it. Link to comment Share on other sites More sharing options...
thephoenix Posted December 22, 2018 Share Posted December 22, 2018 still learning to use my camera. one thing i find anoying is the fact that when using af if you touch the manual focus ring it goes to manual focus. don't know how to go back to af except turning off and on the camera again or switching the front focus selection button Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted December 22, 2018 Share Posted December 22, 2018 1 hour ago, thephoenix said: still learning to use my camera. one thing i find anoying is the fact that when using af if you touch the manual focus ring it goes to manual focus. don't know how to go back to af except turning off and on the camera again or switching the front focus selection button Hmm that doesn't happen for me. The manual focus ring simply doesn't do anything when AF-c or AF-S is on Link to comment Share on other sites More sharing options...
bsalisbury Posted December 22, 2018 Share Posted December 22, 2018 26 minutes ago, thebrothersthre3 said: Hmm that doesn't happen for me. The manual focus ring simply doesn't do anything when AF-c or AF-S is on Same for me, and I checked the X-T3 manual as well. Link to comment Share on other sites More sharing options...
thephoenix Posted December 23, 2018 Share Posted December 23, 2018 maybe the fringer adapter. the lens is tamron 24-70 Link to comment Share on other sites More sharing options...
Azagey Posted December 23, 2018 Share Posted December 23, 2018 Can anyone let me know if it’s possible to input a LUT in camera for F-log monitoring without needing an external recorder? For example, can I record F-log internally to the SD while simultaneously displaying the Eterna LUT on the back screen? Thanks! Link to comment Share on other sites More sharing options...
androidlad Posted December 23, 2018 Share Posted December 23, 2018 20 minutes ago, Azagey said: Can anyone let me know if it’s possible to input a LUT in camera for F-log monitoring without needing an external recorder? For example, can I record F-log internally to the SD while simultaneously displaying the Eterna LUT on the back screen? Thanks! You can't put any LUT into the camera, but there's a feature called "Natural Liveview" that works as a view assist, it displays a BT.709 image on screen but records F-log. Link to comment Share on other sites More sharing options...
Azagey Posted December 23, 2018 Share Posted December 23, 2018 Many thanks! Link to comment Share on other sites More sharing options...
thephoenix Posted December 24, 2018 Share Posted December 24, 2018 5 hours ago, androidlad said: You can't put any LUT into the camera, but there's a feature called "Natural Liveview" that works as a view assist, it displays a BT.709 image on screen but records F-log. can we have the "eterna look" on the screen and record flog ? Link to comment Share on other sites More sharing options...
jagnje Posted December 24, 2018 Share Posted December 24, 2018 Does this camera do off speed playback? And if so, does it play it out the HDMI? I forgot to check this while I had it at home. I wonder if you can do what I used to do while I had the fs5, where I would record a super slow motion, play it back at 24 fps and record the playback to the shogun, to get prores on the spot. Link to comment Share on other sites More sharing options...
androidlad Posted December 24, 2018 Share Posted December 24, 2018 9 hours ago, thephoenix said: can we have the "eterna look" on the screen and record flog ? No it's just a neutral BT.709 look with "natural live view" feature, with 2.0 firmware the camera can send Eterna look via HDMI and record F-log internally (or the other way), but there's a bug at the moment that applies a 1.18x crop on all 4K frame rates. 10 minutes ago, jagnje said: Does this camera do off speed playback? And if so, does it play it out the HDMI? I forgot to check this while I had it at home. I wonder if you can do what I used to do while I had the fs5, where I would record a super slow motion, play it back at 24 fps and record the playback to the shogun, to get prores on the spot. Yes, only in FHD high speed recording mode. But the HDMI output resolution is fixed at 4K30p, regardless of what frame rate you set in camera. Also the playback mode displays some UI element but disappear as soon as playback starts, it'll need to be manually edited out. Link to comment Share on other sites More sharing options...
jagnje Posted December 24, 2018 Share Posted December 24, 2018 Ok, not bad actually then, 120fps to 4K30fps, good enough for my needs. Waiting for the BMPCC4k to test but so far I`m liking that I`m getting here. Link to comment Share on other sites More sharing options...
Attila Bakos Posted December 27, 2018 Share Posted December 27, 2018 I didn't pay too much attention to this video, until I noticed the same: It doesn't really bother me as it took months to shoot a scene where I actually noticed it, but I wonder what's the explanation for this issue. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted December 27, 2018 Share Posted December 27, 2018 I see it. Looks like what you'd get if you had a fluorescent light on and the wrong shutter speed. Looks like natural light though. Link to comment Share on other sites More sharing options...
Attila Bakos Posted December 27, 2018 Share Posted December 27, 2018 2 minutes ago, thebrothersthre3 said: I see it. Looks like what you'd get if you had a fluorescent light on and the wrong shutter speed. Looks like natural light though. I thought the same so I played with the shutter speed, didn't make a difference, and when I first saw it it was with natural light. Link to comment Share on other sites More sharing options...
