thebrothersthre3 Posted February 9, 2019 Share Posted February 9, 2019 Weird, good way to get extra focal length I guess. Would be neat if they did a 1.5 crop mode with reduced rolling shutter. Link to comment Share on other sites More sharing options...
BrunoCH Posted February 9, 2019 Share Posted February 9, 2019 1 hour ago, Attila Bakos said: That's what I thought when the issue appeared. I don't think it will be fixed. That's what I was thinking too. I think a monitor with LUT is a better solution to record LOG and check a REC 709 image. Combination XT3, monitor SWIT 55C, Anker 26000 (to supply power both) is perfect in my fiction work. Link to comment Share on other sites More sharing options...
androidlad Posted February 9, 2019 Share Posted February 9, 2019 1 hour ago, BrunoCH said: That's what I was thinking too. I think a monitor with LUT is a better solution to record LOG and check a REC 709 image. Combination XT3, monitor SWIT 55C, Anker 26000 (to supply power both) is perfect in my fiction work. In the pictures your monitor wasn't actually powered via micro USB ? Link to comment Share on other sites More sharing options...
BrunoCH Posted February 9, 2019 Share Posted February 9, 2019 23 minutes ago, androidlad said: In the pictures your monitor wasn't actually powered via micro USB ? Yes it was. But the path isn’t simple and not visible. Link to comment Share on other sites More sharing options...
MrSMW Posted February 11, 2019 Share Posted February 11, 2019 New member here so appreciate I have next to zero credibility, but an XT3 user specifically for video. I was using an XH1 last year and an XT20 the year prior, but the XT3 is by far and away the best hybrid I have used to date. I use mine on a Sirui freestanding monopod only so have no issues with it not having IBIS (and use my XH1 for anything handheld). I don't use any native lenses, but principally the Sigma 18-35 with variable ND and the Fringer Pro and eye AF and whilst it's not quite as fast as Fuji's own zooms, it's actually pretty good, even in low light. Where I find Fuji's eye and face AF doesn't work so well is at a distance, but the April firmware looks like it's going to make it quite special. When I need something longer, I swap over to the Samyang 50mm T1.3 which is a superb '75mm' equiv option. Manual focus only. But why the Sigma 18-35 over any native options? Quite simply, f1.8 throughout the focal range. Meanwhile, Fuji's own 16-55mm is at f2.8 and the 18-55mm at the longer end, f4. As a wedding photographer who also shoots video, the low light capability is a must for me as is having AF for the times when I need the camera to be recording whilst I'm shooting stills at the same time, such as entrances/exits/confetti etc. Heavy/bulky? Yup, a bit, but a couple of inches shorter than the MK lens and including the adapter, faster and 1/5th of the price...though I'm considering one for next year! Want to go lightweight and mobile... the pancake-like 15-45mm is great outdoors. Ninja V next to replace the Feelworld 5" I was running last year. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted February 11, 2019 Share Posted February 11, 2019 Messing around with my XT-3 last night. Used minolta lenses 24mm 2.8 and 135mm 2.8 Shot with Eterna, no color corrections, just a couple curve adjustments here and there. mercer and Kubrickian 2 Link to comment Share on other sites More sharing options...
mercer Posted February 11, 2019 Share Posted February 11, 2019 1 hour ago, thebrothersthre3 said: Messing around with my XT-3 last night. Used minolta lenses 24mm 2.8 and 135mm 2.8 Shot with Eterna, no color corrections, just a couple curve adjustments here and there. Looks good. Are you in the Northeast? It snowed here last night too. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted February 11, 2019 Share Posted February 11, 2019 2 minutes ago, mercer said: Looks good. Are you in the Northeast? It snowed here last night too. Not too far from Northeast but I am living in Michigan. I took the time to record some audio as well rather than slapping on a music track. Link to comment Share on other sites More sharing options...
jbCinC_12 Posted February 12, 2019 Share Posted February 12, 2019 I'm leaning towards the X-T3 as well for video. Is the crop factor in 4K60p at 1.14 or is it higher? Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted February 12, 2019 Share Posted February 12, 2019 51 minutes ago, jbCinC_12 said: I'm leaning towards the X-T3 as well for video. Is the crop factor in 4K60p at 1.14 or is it higher? 1.17 crop for 4k 60p and 1.29 crop in 1080 120p Link to comment Share on other sites More sharing options...
jbCinC_12 Posted February 12, 2019 Share Posted February 12, 2019 2 minutes ago, thebrothersthre3 said: 1.17 crop Thanks. So that's almost full-frame, be it an Academy ratio size sensor (ASP-C). Is it true that there's a crop issue (output) from what androidlad posted? Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted February 12, 2019 Share Posted February 12, 2019 44 minutes ago, jbCinC_12 said: Thanks. So that's almost full-frame, be it an Academy ratio size sensor (ASP-C). Is it true that there's a crop issue (output) from what androidlad posted? Yeah there is a crop if you want to shoot in Flog and view it as a film simulation like Eterna. So you either have to get an external recorder that can use a LUT to preview the image or just monitor with Flog in camera, or just deal with the crop. Link to comment Share on other sites More sharing options...
jbCinC_12 Posted February 12, 2019 Share Posted February 12, 2019 1 minute ago, thebrothersthre3 said: Yeah there is a crop if you want to shoot in Flog and view it as a film simulation like Eterna. So you either have to get an external recorder that can use a LUT to preview the image or just monitor with Flog in camera, or just deal with the crop. I see. Thanks. Link to comment Share on other sites More sharing options...
thephoenix Posted February 12, 2019 Share Posted February 12, 2019 https://www.youtube.com/watch?v=ZS5RLv2A6YQ Link to comment Share on other sites More sharing options...
Django Posted February 12, 2019 Share Posted February 12, 2019 4 hours ago, jbCinC_12 said: Thanks. So that's almost full-frame, be it an Academy ratio size sensor (ASP-C). No, the crop is obviously added on top of the native sensor size so it’s 1.17x + 1.5x (APS-C) . That’s nowhere near FF.. Link to comment Share on other sites More sharing options...
jbCinC_12 Posted February 12, 2019 Share Posted February 12, 2019 2 minutes ago, Django said: No, the crop is obviously added on top of the native sensor size so it’s 1.17x + 1.5x (APS-C) . That’s nowhere near FF.. So, for a video crop to shoot internal, would it be give or take Super 35 size? Link to comment Share on other sites More sharing options...
Django Posted February 12, 2019 Share Posted February 12, 2019 APS-C = Super35. 4k60p on XT3 is 1.67x 1.71x so yeah closer to Super35 than to FF. Link to comment Share on other sites More sharing options...
androidlad Posted February 12, 2019 Share Posted February 12, 2019 4k60p crop is 1.18x, with v2.0 firmware the crop factor is displayed on the top left corner. Link to comment Share on other sites More sharing options...
Kisaha Posted February 12, 2019 Share Posted February 12, 2019 Fujifilm X-T3 crop factor: Sensor diagonal = 28.21 mm Crop factor = 43.27 : 28.21= 1.53 This is the true form factor. proteanstar and jbCinC_12 1 1 Link to comment Share on other sites More sharing options...
thephoenix Posted February 12, 2019 Share Posted February 12, 2019 i am 2 fw updates late, do i need to process both or can i just update with the latest one ? Link to comment Share on other sites More sharing options...
