Inazuma Posted February 17, 2019 Share Posted February 17, 2019 2 hours ago, Django said: XT2 is probably the best hybrid camera deal around. Especially since it got the 120fps FHD & internal F-Log update. XH1's have also gone down a lot, and with IBIS + Eterna they are solid affordable options as well. oh damn, forgot about the 120fps update! Is it any good? Link to comment Share on other sites More sharing options...
Vladimir Posted February 17, 2019 Share Posted February 17, 2019 4 hours ago, Inazuma said: oh damn, forgot about the 120fps update! Is it any good? decide yourself ) (shot this handheld with xt2) Snowbro, Thomas Hill, jbCinC_12 and 4 others 7 Link to comment Share on other sites More sharing options...
Thomas Hill Posted February 17, 2019 Share Posted February 17, 2019 1 hour ago, Vladimir said: decide yourself ) (shot this handheld with xt2) Beautiful. What lens(es) and how high did you go on the ISO? Link to comment Share on other sites More sharing options...
Vladimir Posted February 17, 2019 Share Posted February 17, 2019 9 minutes ago, Thomas Hill said: Beautiful. What lens(es) and how high did you go on the ISO? konica 40/1.8 and cheap noname speedbooster (and a little of machining work). most probably highest iso is 1600 (since i dont do post nr), maybe 3200 in one or two shots. Link to comment Share on other sites More sharing options...
androidlad Posted February 17, 2019 Share Posted February 17, 2019 X-T2/X-H1 120fps is derived from line-skipping the full sensor, moire/aliasing/noise are severe, the video above (and a few similar ones) use heavy grain and aged film effect to cleverly mask those image artifacts. It's a nice workaround but has limited use. X-T3/X-T30 120fps improved considerably by incorporating weighted pixel-binning and reduced line-skipping (at the expense of 1.29x crop). Link to comment Share on other sites More sharing options...
thephoenix Posted February 17, 2019 Share Posted February 17, 2019 anyone having the moza air 2 with the xt3 ? was wondering if the camera is supported Link to comment Share on other sites More sharing options...
Vladimir Posted February 17, 2019 Share Posted February 17, 2019 29 minutes ago, androidlad said: X-T2/X-H1 120fps is derived from line-skipping the full sensor, moire/aliasing/noise are severe, the video above (and a few similar ones) use heavy grain and aged film effect to cleverly mask those image artifacts. It's a nice workaround but has limited use. true, aliasing is bad, so im shooting with fast [soft] lenses wide open, 360° and as you said adding a lot of grain (i like it anyway)) over original noise. not suited for clean work but to catch a moment its enough for me. here is another example of 100fps but with xh1; theres a lot of red so watch in 2160 quality (yeah its funny chosing 2160 option to watch 720-like footage but its YT compression bbe )): Link to comment Share on other sites More sharing options...
jbCinC_12 Posted February 18, 2019 Share Posted February 18, 2019 15 hours ago, Vladimir said: true, aliasing is bad, so im shooting with fast [soft] lenses wide open, 360° and as you said adding a lot of grain (i like it anyway)) over original noise. not suited for clean work but to catch a moment its enough for me. here is another example of 100fps but with xh1; theres a lot of red so watch in 2160 quality (yeah its funny chosing 2160 option to watch 720-like footage but its YT compression bbe )): Beautifully shot. Did you use the Konica as well? Link to comment Share on other sites More sharing options...
Vladimir Posted February 18, 2019 Share Posted February 18, 2019 8 hours ago, jbCinC_12 said: Beautifully shot. Did you use the Konica as well? nikkor 55/1.2 with/without speedbooster jbCinC_12 1 Link to comment Share on other sites More sharing options...
Hene1 Posted February 18, 2019 Share Posted February 18, 2019 On 2/17/2019 at 4:58 PM, Vladimir said: decide yourself ) (shot this handheld with xt2) That is really nice! May I ask what grain do you use? Link to comment Share on other sites More sharing options...
thephoenix Posted February 18, 2019 Share Posted February 18, 2019 so i tried to trigger the xt3 with the tilta nucleus nano, connected a 2.5mm male male from the motor to the fuji plug that is on the top right side of the cam. didn't work i thought it was just sending a basic electrical signal for the camera to start recording and stops recording but it must be more complicated than that. sent tilta a message to ask them to support the xt3, hope they will do as this camera sells pretty well i guess Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted February 18, 2019 Super Members Share Posted February 18, 2019 1 hour ago, thephoenix said: so i tried to trigger the xt3 with the tilta nucleus nano, connected a 2.5mm male male from the motor to the fuji plug that is on the top right side of the cam. didn't work i thought it was just sending a basic electrical signal for the camera to start recording and stops recording but it must be more complicated than that. sent tilta a message to ask them to support the xt3, hope they will do as this camera sells pretty well i guess Looking at the page for the run/stop cables for the Nucleus Nano ( https://tilta.com/shop/nucleus-nano-run-stop-cables/ ) the controller end (on the right in this picture) is a 4 pole jack With the Fuji release cable, it is a 3 pole You might get lucky by using a 2.5mm 3 pole to 3 pole cable from the camera and putting a 4 pole adapter on the end into the controller. Otherwise it will be a case of rolling your own by measuring what is coming off each pole when you do the run/stop from the controller and re-wiring the 3 pole connector going into the camera to match what the Fuji is expecting. The pinout for the Fuji is the same as for Canon, which you will find here http://www.doc-diy.net/photo/remote_pinout/index.php An alternative would be to buy the Panasonic version and make an adapter and, again, the pinout for the Panasonic is at the same link. thephoenix 1 Link to comment Share on other sites More sharing options...
TheRealOG Posted February 18, 2019 Share Posted February 18, 2019 On 2/17/2019 at 1:45 AM, Django said: FWIW i made decent coin doing pro work using XT2. I was able to bring that camera in parts of the world were anything more conspicuous might have gotten me in trouble. An often underrated aspect of these Fuji's is most people take them for retro film cameras! The only thing that's given me cold feet about XT3 is all these build quality issues. Really hope they get back to the Sendai manufacturing plant for XH2 etc.. Recently repurchased the X-H1... Local camera store had an open box with warranty and battery grip deal for $1,099.. Traded in an old T4i... Added the Viltrox adapter EF-FX1 for my Sigma 18-35 and it's a pretty decent machine for images. I still have my 80D because that DPAF is hard to beat (hate to admit it, but that Canon Color science SOOC is still gorgeous...) Link to comment Share on other sites More sharing options...
thephoenix Posted February 18, 2019 Share Posted February 18, 2019 Somel ike this ? https://www.thomann.de/fr/rode_sc7.htm?glp=1&gclid=Cj0KCQiAzKnjBRDPARIsAKxfTRB4zJk3s-CSPVhwNBNr4Y9bN9KvTNMbX5dWlkBl_am7ad_vidHeaYgaAmhYEALw_wcB with 2 adapters to 2.5 maybe Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted February 18, 2019 Super Members Share Posted February 18, 2019 3 minutes ago, thephoenix said: Somel ike this ? https://www.thomann.de/fr/rode_sc7.htm?glp=1&gclid=Cj0KCQiAzKnjBRDPARIsAKxfTRB4zJk3s-CSPVhwNBNr4Y9bN9KvTNMbX5dWlkBl_am7ad_vidHeaYgaAmhYEALw_wcB with 2 adapters to 2.5 maybe Yes, if you get really, really lucky that might actually work as is. If it doesn't then you've got a handy cable to connect a Rode video mic to an iPad ! Link to comment Share on other sites More sharing options...
thephoenix Posted February 18, 2019 Share Posted February 18, 2019 Just now, BTM_Pix said: Yes, if you get really, really lucky that might actually work as is. If it doesn't then you've got a handy cable to connect a Rode video mic to an iPad ! The cool thing with amazon is that you can return things. I can try and see what happens Link to comment Share on other sites More sharing options...
BrunoCH Posted February 18, 2019 Share Posted February 18, 2019 2 minutes ago, BTM_Pix said: Yes, if you get really, really lucky that might actually work as is. If it doesn't then you've got a handy cable to connect a Rode video mic to an iPad ! Rode SC7 is a 3,5mm jack !?! BTM_Pix 1 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted February 18, 2019 Super Members Share Posted February 18, 2019 2 minutes ago, BrunoCH said: Rode SC7 is a 3,5mm jack !?! Ooops!!! Well spotted ! Yes, cancel that order @thephoenix Link to comment Share on other sites More sharing options...
thephoenix Posted February 18, 2019 Share Posted February 18, 2019 1 minute ago, BrunoCH said: Rode SC7 is a 3,5mm jack !?! Which is why i added with adapters to 2.5 ; ) 2 minutes ago, BTM_Pix said: Ooops!!! Well spotted ! Yes, cancel that order @thephoenix Same answer as to brunoch Should work with 3.5 to 2.5 adapters Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted February 18, 2019 Super Members Share Posted February 18, 2019 5 minutes ago, thephoenix said: Which is why i added with adapters to 2.5 ; ) In my defence, it is late and I am old thephoenix 1 Link to comment Share on other sites More sharing options...
