kaseybonez Posted October 1, 2018 Share Posted October 1, 2018 I understand the principle of dividing the 100mbps over 24 fps is going to yield frames with more information per than the same 100mbps spread across 120 frames.... HOWEVER, I've seen so much beautiful footage from other users that i just cant seem to replicate... I typically shoot in Slog-2 and thought that maybe that picture profile was adding to my noise problem, so now im just trying to find the best picture profile for slow motion. Any suggestions? What're your slow motion settings? Link to comment Share on other sites More sharing options...
Mako Sports Posted October 2, 2018 Share Posted October 2, 2018 2 hours ago, kaseybonez said: I understand the principle of dividing the 100mbps over 24 fps is going to yield frames with more information per than the same 100mbps spread across 120 frames.... HOWEVER, I've seen so much beautiful footage from other users that i just cant seem to replicate... I typically shoot in Slog-2 and thought that maybe that picture profile was adding to my noise problem, so now im just trying to find the best picture profile for slow motion. Any suggestions? What're your slow motion settings? You probably aren't exposing your S Log 2 correctly, that or your shooting in conditions that are not (Bright Daytime exteriors) which Slog 2 was specifically made for and excels at. Stuff like lowlight. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted October 2, 2018 Share Posted October 2, 2018 Try shooting in standard, or maybe one of the cine settings. Slog2 has the most noise, which isn't necessarily a bad thing you'll just need to use neat video (or another NR software) in post sometimes. Link to comment Share on other sites More sharing options...
docmoore Posted October 2, 2018 Share Posted October 2, 2018 120P takes a lot of light for proper exposure as the shutter speed is correspondingly much shorter than 24P. Probably ISO or gain ramped to give you decent levels but in doing so ramped the noise. So add light or use something like Cine2 to mask the noise. Otherwise noise reduction will soften details. Link to comment Share on other sites More sharing options...
