Cinema 24p or HBR?
paulva
EOSHD Guide states to shoot at Cinema 24p, if I shoot at Cinema 24p with Aquamotion v2 Hack am I still getting the 88m/s?
PV's FAQ page states to shoot at HBR.
Which method makes use of the hack the most?
Thanks for your help. Could not find a simple answer via Google or the search function of the forum. If there is a newbie page out there that explains this in non-techie language, please forward me to it! Thank you.
You've got it, Joshua. Variable bitrate hacks do not always record at the highest rate. It depends on the complexity and brightness of the subject, i.e. a forest background will record at a higher bitrate generally than a solid background.
Is Orion variable or constant? Can't remember offhand. But do not look at total file size to see recording bitrates, you need a secondary tool such as 5DtoRGB or MediaInfo. Or whichever one is suggested on the Personal View site.
