Julian Posted May 29, 2013 Share Posted May 29, 2013 Wow, so impressed that this thing is developing so fast. I can't keep up. Can anyone tell me if they ever got past the 4GB recording limitation? Not in the current 50D built yet, but on the other camera's that's been fixed, so that should be no problem. Link to comment Share on other sites More sharing options...
artiswar Posted May 29, 2013 Share Posted May 29, 2013 http://www2.picturepush.com/photo/a/13184955/img/13184955.png Quick test of a flat Camera Raw treatment and 4K upscale. Holds up pretty well, contrasts back down and resaturates well. This is only 2k due to the monitor. Julian 1 Link to comment Share on other sites More sharing options...
Oscar M. Posted May 29, 2013 Share Posted May 29, 2013 UPDATE: I will post a video later tonight about this. Basically YES, you CAN get HDMI output from the 50D (output is 1080i) as well as CLEAN HDMI (Not to be confused with uncompressed HDMI) out from the 50D - All while recording RAW! This will improve later also. Link to comment Share on other sites More sharing options...
Andrew Breault Posted May 29, 2013 Share Posted May 29, 2013 Remember: you need to have downloaded the experimental work-in-progress alpha build to use the raw functionality. If you just get the regular Magic Lantern stable release version, then the option to shoot raw won't be there. Is that the same as the "nightly build?" I could not find the "experimental work-in-progress alpha." You got a link for that? Thanks btw! Link to comment Share on other sites More sharing options...
artiswar Posted May 29, 2013 Share Posted May 29, 2013 @JulianH - Have you done any compiling yourself? Any idea how to port the 4GB+ module to the 50D? http://www.magiclantern.fm/forum/index.php?topic=5655.0 Link to comment Share on other sites More sharing options...
Leica50mm Posted May 29, 2013 Share Posted May 29, 2013 The 50D didn't have a native video option and ML has unlocked video on it, right? Well, why can't the EOS 1Ds iii? It has live view, but no video option . Could it happen? Thanks, Tim Link to comment Share on other sites More sharing options...
Julian Posted May 29, 2013 Share Posted May 29, 2013 @JulianH - Have you done any compiling yourself? Any idea how to port the 4GB+ module to the 50D? http://www.magiclantern.fm/forum/index.php?topic=5655.0 I haven't done anything except using and testing the builds of others, who don't have a fast CF card to try it out yet. /Edit: forget what I wrote here.. premature conclusions, have to check how/if the footage actually works. Link to comment Share on other sites More sharing options...
artiswar Posted May 29, 2013 Share Posted May 29, 2013 @Julian - Have been, thanks. Waiting for my account to get activated so I can contribute. Good news! Link to comment Share on other sites More sharing options...
thelebaron Posted May 29, 2013 Share Posted May 29, 2013 i think alex said 7d is a no go for raw due to dual digics. Link to comment Share on other sites More sharing options...
Julian Posted May 29, 2013 Share Posted May 29, 2013 New resolution test with GregoryOfManhattan's Alpha build using hacked mode. (Check ML 50D topic, alpha testers wanted, send him a message) Sandisk 32GB 90MB/s CF 3:2 @ 1592x1062 ~ 135 frames 5:3 @ 1952x955 ~ 270 frames 16:9 @ 1592x 895 ~ 480 frames 1.85:1 @ 1592x860 ~ 850 frames2:1 @ 1592x796 - No skipping!It can record over 4GB and span! I shot 1592x796 continously, stopped recording manually at 10GB. The buffer is completely fine. But right now the files don't convert properly so it's not usable yet! Wanted to try anamorphic resolutions like 1440x1062 and 1320x990 but ran out of batteries... Overall definitely an improvement over the previous build, that gave me these results:1592×1062 – frame skipping after about 50 frames 1592×840 – frame skipping after about 480 frames 1592×720 – no frame skipping Link to comment Share on other sites More sharing options...
Oscar M. Posted May 29, 2013 Share Posted May 29, 2013 New resolution test with GregoryOfManhattan's Alpha build using hacked mode. (Check ML 50D topic, alpha testers wanted, send him a message) Sandisk 32GB 90MB/s CF 3:2 @ 1592x1062 ~ 135 frames 5:3 @ 1952x955 ~ 270 frames 16:9 @ 1592x 895 ~ 480 frames 1.85:1 @ 1592x860 ~ 850 frames2:1 @ 1592x796 - No skipping!It can record over 4GB and span! I shot 1592x796 continously, stopped recording manually at 10GB. The buffer is completely fine. But right now the files don't convert properly so it's not usable yet! Wanted to try anamorphic resolutions like 1440x1062 and 1320x990 but ran out of batteries... Overall definitely an improvement over the previous build, that gave me these results:1592×1062 – frame skipping after about 50 frames 1592×840 – frame skipping after about 480 frames 1592×720 – no frame skipping Question: Did you mean a single 10GB file, or 10GB spanned on several files? As far as I know Fat32 tops at 4GB per file. If single, is your card formatted as Fat32 or exFat ? . . . . or did you format in camera? Link to comment Share on other sites More sharing options...
Julian Posted May 29, 2013 Share Posted May 29, 2013 Spanned over several files. I format in camera. The counter on the screen just adds up the MB's, on the card it is split in 4GB chunks. Link to comment Share on other sites More sharing options...
Julian Posted May 29, 2013 Share Posted May 29, 2013 My quick observations using GregoryOfManhattan's Alpha build.- Better speed, stable 1592x796 recording (see test above)- Playback works (B&W, slow speed) - Buffer improved to 5 stars from 4 stars on my camera - Way more available resolutions, select width and choose aspect ratio - 'Digital dolly' mode works! - Recording with live view button, I don't have to do any kind of work around- Cropped mode works - display still turns pink but DNG files are fine!- 4GB+ recording works but the raw files aren't converted properly yet - not usable yet, work in progress- recording rectable / frame counter is flickering all the time (same as previous build)- Camera crashes when trying to play back raw files made in cropped mode Link to comment Share on other sites More sharing options...
Oscar M. Posted May 29, 2013 Share Posted May 29, 2013 Spanned over several files. I format in camera. The counter on the screen just adds up the MB's, on the card it is split in 4GB chunks. OK. Did you have a chance to see if the video files are seamless? In other words, is there a time gap between the files? Never mind. No way to know until the DNGs can be extracted. Julian 1 Link to comment Share on other sites More sharing options...
Julian Posted May 29, 2013 Share Posted May 29, 2013 The data is corrupt for now. Lets wait till it actually works, but I have good hope. Remember that a lot of work has been done for other camera's, like the 5D2, most of it I think applies to the 50D as well. Link to comment Share on other sites More sharing options...
artiswar Posted May 29, 2013 Share Posted May 29, 2013 Here's Julian's footage at 4k psuedo-log to play with. Have a go in DaVinci. Amazing flexibility. http://www.qfpost.com/file/d?g=QxEkiKUg1 Link to comment Share on other sites More sharing options...
Oscar M. Posted May 30, 2013 Share Posted May 30, 2013 UPDATE: I will post a video later tonight about this. Basically YES, you CAN get HDMI output from the 50D (output is 1080i) as well as CLEAN HDMI (Not to be confused with uncompressed HDMI) out from the 50D - All while recording RAW! This will improve later also. http://vimeo.com/67271335 Keep in mind that if your monitor does not have a "Camera" or crop function, then the output will be 4:3 as the 50D does not output in 16:9 . . . Julian and rommex 2 Link to comment Share on other sites More sharing options...
rommex Posted May 30, 2013 Share Posted May 30, 2013 Julian, Oscar, thanks people! I keep wondering, looking at this 5-year-old hardware -- what's in the Canon's lab today, ha? Link to comment Share on other sites More sharing options...
odie Posted May 30, 2013 Share Posted May 30, 2013 it would be nice if this worked on the 1dx Link to comment Share on other sites More sharing options...
Brellivids Posted May 30, 2013 Share Posted May 30, 2013 it would be nice if this worked on the 1dx Indeed. the funny thing about this whole ordeal is ... What on earth will canon release next. I mean for instance do they think they can just do minimal video feature upgrades and sell alot. Will they try to make hardware locks for future cameras or provide even better hacker friendly products. Say 5D mark IV with 2 Sata III ports.. ;) Julian 1 Link to comment Share on other sites More sharing options...
