Leica50mm Posted June 4, 2013 Share Posted June 4, 2013 I think i like the look of the 50D better than the 5D. Looks really film like. OffewMapype 1 Link to comment Share on other sites More sharing options...
fluxo Posted June 5, 2013 Share Posted June 5, 2013 canon is really crippling everything!! got them you canon http://***URL not allowed***/news/?p=18311 Link to comment Share on other sites More sharing options...
Tim Posted June 7, 2013 Share Posted June 7, 2013 I've just received my Komputerbay 1000X 64gb cards and I'm testing the build, but how do I set the fps? I believe it's recording at 29.98fps. Any help? :S Cheers Link to comment Share on other sites More sharing options...
Julian Posted June 7, 2013 Share Posted June 7, 2013 Use FPS override - set to exact fps - press the FUNC button on the camera to get into the menu options. Link to comment Share on other sites More sharing options...
Tim Posted June 7, 2013 Share Posted June 7, 2013 Awesome! Thanks! ILY! I'm getting no dropped frames at 1280x720, how do I increase the size to exactly 1592x896? I'm keen to use my la7200 for some anamorphic shots :D Thanks again Julian Link to comment Share on other sites More sharing options...
Julian Posted June 7, 2013 Share Posted June 7, 2013 Just change the size at the raw video options? If you don't have experience with ML just read the manual for Unified 2.3, at least you'll understand how to access extra menu's and stuff - it's a piece of cake. The whole manual is even inside of the camera if you download ML 2.3. Hints: press 'func', the set button and use the scroll wheel... Tim and nahua 2 Link to comment Share on other sites More sharing options...
JohnBarlow Posted June 7, 2013 Share Posted June 7, 2013 I'm kinda liking 2:1 Scope, being a half way house between 16:9 and 2.35:1 Can someone tell me the biggest square crop at 24p thats possible with this cam? Is it 1152x1152? Link to comment Share on other sites More sharing options...
Julian Posted June 7, 2013 Share Posted June 7, 2013 Max height of the 50D live view feed is 1058 px in full sensor mode or 1080 px in zoomed mode. You can select a square recording area so these will be your maximum squares. You can select about every other aspect ratio as well, like 5:4, 4:3 etc. All great for anamorphics! Link to comment Share on other sites More sharing options...
Julian Posted June 7, 2013 Share Posted June 7, 2013 Found some time to edit my shots I made earlier this week. Experimented with a new workflow, I wanted something faster than ACR/Bridge, so I used RAWanizer to convert to CineformRAW 444 (about 10 minutes for 21GB of footage), graded the clips in Davincie Resolve Lite 9 and edited in Premiere CS6. http://vimeo.com/67916713 nahua and Leica50mm 2 Link to comment Share on other sites More sharing options...
gh2sound Posted June 8, 2013 Share Posted June 8, 2013 10 Mins 21 Gig - lol sadly no way this will eek its way into any PM's budget. Home use - amazing - real world not yet . Link to comment Share on other sites More sharing options...
Bruno Posted June 8, 2013 Share Posted June 8, 2013 10 Mins 21 Gig - lol sadly no way this will eek its way into any PM's budget. Home use - amazing - real world not yet . Is that any slower than converting 21Gb worth of h264 footage to prores? Because that's what everyone has been doing for the past 3 or 4 years for much worse results, and it hasn't stop anyone! :) Link to comment Share on other sites More sharing options...
Tim Posted June 8, 2013 Share Posted June 8, 2013 Just change the size at the raw video options? If you don't have experience with ML just read the manual for Unified 2.3, at least you'll understand how to access extra menu's and stuff - it's a piece of cake. The whole manual is even inside of the camera if you download ML 2.3. Hints: press 'func', the set button and use the scroll wheel... I just realised I was using Smeangol's build, now I'm using Gregory's build and am getting 1592x896. Cheers Link to comment Share on other sites More sharing options...
Julian Posted June 8, 2013 Share Posted June 8, 2013 10 Mins 21 Gig - lol sadly no way this will eek its way into any PM's budget. Home use - amazing - real world not yet . This is only relevant during acquisition. If you don't like the big files you could just convert to cineform 422 or something for small size. You could do this in the field with a laptop - unload your card, convert the raws, empty card, shoot more... I think this would work fine for longer low budget projects as well. Link to comment Share on other sites More sharing options...
Julian Posted June 8, 2013 Share Posted June 8, 2013 /double post Link to comment Share on other sites More sharing options...
frerichs Posted June 9, 2013 Share Posted June 9, 2013 Using the May 28 build and the settings recommended throughout this post, I did a test run and posted the video on Vimeo. I have a Lexar 64Gb 1000X card and was able to record at 16:9 at 57mbps without filling the buffer but had issues at 3:2 at 71mbps and couldn't achieve more than 450 frames before stopping. I used an external SmallHD monitor via HDMI and had weird intermittent frame garbage. Happened in both 16:9 and 3:2. Workflow was RAW>raw2dng>Photoshop RAW>TIFF>Quicktime>FinalCut 7. Shot with a Moller Bolex 1.5x anamorphic lens and Zeiss 80mm f/2.8.www.vimeo.com/67965891 JohnBarlow, nahua and Leica50mm 3 Link to comment Share on other sites More sharing options...
septemberdawn Posted June 9, 2013 Share Posted June 9, 2013 Very nice! Link to comment Share on other sites More sharing options...
Macfawlty Posted June 9, 2013 Share Posted June 9, 2013 After reading this very fine article, I picked up a 50D on eBay for under $400. I have a 5D2 and a 5D3. Using the ML software, in the movie mode enable menu I only see two options; 1920x1080 30fps and 640x480. How did you get to the movie resolutions you tested in the ML menu? Link to comment Share on other sites More sharing options...
nahua Posted June 9, 2013 Share Posted June 9, 2013 After reading this very fine article, I picked up a 50D on eBay for under $400. I have a 5D2 and a 5D3. Using the ML software, in the movie mode enable menu I only see two options; 1920x1080 30fps and 640x480. How did you get to the movie resolutions you tested in the ML menu? Press the "FUNC" button under the LCD. Julian says this in post #166 above. Link to comment Share on other sites More sharing options...
Julian Posted June 9, 2013 Share Posted June 9, 2013 First download the raw hack and load the modules ;) 1080p and 480p are just for h264 on the Canon 50D. Found out today, via the ML forums, that you better turn ON the H264 movie mode when shooting raw with the 50D. Then it turns the whole camera to 'movie' mode and you get correct exposure etc. Tim 1 Link to comment Share on other sites More sharing options...
ergopossum Posted June 11, 2013 Share Posted June 11, 2013 My first 50D test footage. I'm new at this, I experimented with a few different ISO settings but much of it was 800 or 1600 given the low light of the environment. I was getting a lot of noise and lines on the image in many cases, probably because I pushed it too far in terms of ISO and my adjustments to the raw afterward. Nikkor AIS 50mm f/1.8 for all shots. At the very least, I love how well it captured fine detail! The memory card I used was the 64 gb Transcend 1000x card, and it performed valiantly! I had a few hiccups where the camera dropped or stopped recording, but I suspect that had more to do with some instability on the part of the build. Apologies for the somewhat rough YouTube compression. http://www.youtube.com/watch?v=Tg4Bkfg80z8 http://www.youtube.com/watch?v=y_hQyaIF3os Link to comment Share on other sites More sharing options...
