6FPS 5D3 RAW Conversion with AE CS6
jcs
I had turned off Render Multiple Frames at once in AE CS6 due to stability issues for other tasks. I turned it back on with 1.5GB per render and 10 processors (12 core 2.93GHz MacPro).
Hit 99% CPU- used all 12(!) cores, up to 21GB of RAM (24 total)) and rendered 6FPS (1/4 real-time).
Rendered out to 150Mbps Matrox MPEG2 I-frame HD (422) for editing in PPro CS6.
It's running at 99% CPU with 1.5GB per processor set in AE CS6. Didn't try setting to 1GB per proc as it's already running at full speed (24 cores are available). Was running at .5FPS before, so ~12x speed up once using all cores (as expected).
