Ian Edward Weir Posted October 31, 2018 Share Posted October 31, 2018 Here is a video poem piece I did pairing the Kowa Inflight 1.75x with the Voigtlander Nokton 25mm f/0.95. Shot at f1.4 on GH5 and delivered in 5k. Really love this combo. Slight coloring tweaks with Film Convert. Hope you guys like image. I took off HCDNA to avoid vignetting. video > Make America Again Francisco Rios and Bold 2 Link to comment Share on other sites More sharing options...
Grimor Posted November 1, 2018 Share Posted November 1, 2018 Hi Ian! Great images for sure!!! Can you explain a little bit of your workflow: Is the GH5 on 4:3 anamorphic 6k mode? How bad is the vignette with the rectilux? I really interested because i have those pieces of equipment, but with Kowa B&H instead (so for me is 2x). I will be doing a Christmass ad for my corporation next week and anamorphic is always a plus! Link to comment Share on other sites More sharing options...
Ian Edward Weir Posted November 1, 2018 Author Share Posted November 1, 2018 5 hours ago, Grimor said: Hi Ian! Great images for sure!!! Can you explain a little bit of your workflow: Is the GH5 on 4:3 anamorphic 6k mode? How bad is the vignette with the rectilux? I really interested because i have those pieces of equipment, but with Kowa B&H instead (so for me is 2x). I will be doing a Christmass ad for my corporation next week and anamorphic is always a plus! Hi Grimor, I shot in 4:3 4k for a de-stretched image size of 5824 x 2496. I then finished in 5k with a 5120 × 2880 frame size for YouTube. I was pushing the limit with a 25mm taking lens which is why I did not have the HCDNA in front to avoid more vignetting. I even did a slight Mesh Warp in After Effects on vignettes that were there. In your case with a 2x, I think you might want to use 4:3 4k with 1.4x tele. You could use the HCDNA with that. I knew I would not be moving much and double focus was not an issue. Link to comment Share on other sites More sharing options...
Grimor Posted November 1, 2018 Share Posted November 1, 2018 Thanks!!! Link to comment Share on other sites More sharing options...
