austinchimp Posted November 21, 2018 Share Posted November 21, 2018 I find that one of the main differentiators in feel between small mirrorless or DSLRs and larger cameras like the Alexa is the movement of the camera itself when it's handheld. Small cameras have that horrible jittery shaky distracting motion while larger cameras can feel 'cinematic' even while they're being carried while running for example, and using unstabilised lenses. Like in this clip at 1'35. The obvious factor is rolling shutter, but assuming that my camera has low rolling shutter, how best to replicate this look and feel with - say - a X-T3? Two things I want to avoid are shoulder mounting, and making a big rig. I've thought about actually weighing the camera down somehow, or perhaps using a handle mounted on the top to avoid the usual mirrorless shooting position of holding it out in front of you. Any ideas?? jgharding 1 Link to comment Share on other sites More sharing options...
seanzzxx Posted November 21, 2018 Share Posted November 21, 2018 Using steadicams/glidecams as opposed to gimbals really does the trick I think, it adds a certain flow to the movement that is very filmlike in my opinion. Here's one example, all shot on a glidecam: heart0less 1 Link to comment Share on other sites More sharing options...
austinchimp Posted November 21, 2018 Author Share Posted November 21, 2018 30 minutes ago, seanzzxx said: Using steadicams/glidecams as opposed to gimbals really does the trick I think, it adds a certain flow to the movement that is very filmlike in my opinion. Here's one example, all shot on a glidecam: Yeah that looks great. Ideally I don't want to use anything large though. I'm not asking for any particular job. Obviously if a project requires stabilisation I use it. I'm only asking because it's something that's been on my mind for a while. I do find that most electronic gimbals look very in-organic and steadicams do look more cinematic to me, like in your example. I really like a little organic wobble in the movement, like a cinema verite thing. That's what I'm trying to recreate with a small camera. I just hate micro-jitter and shake that reminds me of 5dmkii videos from 2009. Link to comment Share on other sites More sharing options...
jgharding Posted November 21, 2018 Share Posted November 21, 2018 Weight is part of it, an Alexa weight a ton as do the lenses usually, most often it'll be on easy rig or steadicam vest or both. If not it's on a big tripod. The example looks great, but it does look like a small camera still, it's the quick jitter at the start I've tried using GH5 with Dual-IS2 and a Ronin S recently and it gets closer but it doesn't look like a heavy camera. So perhaps just add a load of lead ? Maybe a Ronin S in briefcase mode? maxmizer and hansel 1 1 Link to comment Share on other sites More sharing options...
heart0less Posted November 21, 2018 Share Posted November 21, 2018 Some really good discussion here: https://www.eoshd.com/comments/topic/26826-shoulder-rig-for-a-mirrorless-camera-how-not-to-go-overboard Link to comment Share on other sites More sharing options...
Inazuma Posted November 21, 2018 Share Posted November 21, 2018 Put the camera on a large gorillapod and use it as a chest/shoulder mount austinchimp 1 Link to comment Share on other sites More sharing options...
jagnje Posted November 21, 2018 Share Posted November 21, 2018 well what you get with a light camera and a steady cam in not what you get with a heavy cam handheld...lets clear first of all what do you want a steady cam of a heavy handheld camera. If you want to have a look of an alexa on a steady cam you get a steady cam and a great colorist If you want the look of a heavy camera being handheld you need a heavy camera and operate it handheld but really as Inazuma said, multiple points of contact with the operater and simply add weight, v-lock batteries help a bunch and yes a top handle for low slung shots, it`s a must. I don`t really like gimbals that much, don`t get me wrong they are superb tools that have opened so many doors to so many filmmakers, but they have their own feel and look. What I have used many many times with all kinds of cameras for follow along shots was a wheelchair with two apple boxes to sit on or simply standing on a skateboard going backwards, on smooth surfaces that is. Link to comment Share on other sites More sharing options...
TheRenaissanceMan Posted November 21, 2018 Share Posted November 21, 2018 You want the look of a heavier camera, you need to make the camera heavier. Period. The extra weight/mass is what makes bigger cameras look better handheld. Either you're willing to do it for the look or you're not. There's no way to "fake" inertia. Gimbals and steadicams will give you steadier footage with a light camera and eliminate micro-jitter, but it's not the same aesthetic at all. On a recent short, all it took was popping the F3 on a simple shoulder pad, and suddenly beautiful handheld was effortless. I can PM you a link if you're interested. jhnkng, Raafi Rivero, Zak Forsman and 1 other 3 1 Link to comment Share on other sites More sharing options...
BenEricson Posted November 21, 2018 Share Posted November 21, 2018 12 minutes ago, TheRenaissanceMan said: You want the look of a heavier camera, you need to make the camera heavier. Period. The extra weight/mass is what makes bigger cameras look better handheld. Either you're willing to do it for the look or you're not. There's no way to "fake" inertia. Gimbals and steadicams will give you steadier footage with a light camera and eliminate micro-jitter, but it's not the same aesthetic at all. On a recent short, all it took was popping the F3 on a simple shoulder pad, and suddenly beautiful handheld was effortless. I can PM you a link if you're interested. Agreed. I was using the F3 with the 7Q for a while. You get really nice heavy and smooth movements with that setup. The way the camera settles is different than a camera with no weight. Surprised so many people would recommend steady cams and Ronins? There’s no need to complicate things. You need a well balanced rig that weights 7/8 pounds. TheRenaissanceMan 1 Link to comment Share on other sites More sharing options...
kye Posted November 22, 2018 Share Posted November 22, 2018 Adding weight is one thing (that people already mentioned) but what they didn't mention is adding weight at a distance. A steadicam works because the weights are at a distance from the camera. Here's the physics of the situation: https://en.wikipedia.org/wiki/Moment_of_inertia Something you can try immediately is to use a tripod. Mount your camera on a tripod and try the following tests: Use the tripod with legs compacted and folded together and hold it underneath the camera allowing it to work like a steadicam Same as above but extend the legs most of the way to the floor Same as above but fold the legs out You will find that the first test gives some smoothing in tilt and roll but little stabilisation in pan, the second will be more of the same, and the third will add in some stabilisation to the panning as well because the legs are not all on the same axis. With physics you need a combination of mass and distance, you can't get around it. If you don't want either then do what I did and invest in IBIS. hansel 1 Link to comment Share on other sites More sharing options...
webrunner5 Posted November 22, 2018 Share Posted November 22, 2018 Like I have stated before most of the footage you see on TV is shot on a full sized ENG, probably a Sony, and they weigh at least 17 pounds or more and you tell me how many times you have ever seen shaky, goofy looking stuff out of them. A lot of the time they are even walking backwards at a pretty good pace! And none of them has any kind of OIS or IBIS even now that I know of. There may be OIS ENG lenses by now? But I don't see one. Wow look at the price of this ENG lens. Christ. https://www.bhphotovideo.com/c/product/1309404-REG/fujinon_ua80x9besm_e_digi_1_2_ext_ua80x9besm_e_digi_is_4k.html I know from experience that is it not that hard to do. But yeah granted you spend a Lot of time learning how to use them, it is your full time job, but that weight is what makes it happen. These light camera rigs, IBIS or not are not that conducive to rock solid output. But learning how to walk with them right helps. The heaver they are the less exaggerated you have to do the duck walk thing LoL. Link to comment Share on other sites More sharing options...
mercer Posted November 22, 2018 Share Posted November 22, 2018 For small, unobtrusive set up, I’ve been using a long strap, and a Benro monopod, with a Manfrotto tilt head, completely collapsed, with the bottom of the monopod inside the kangaroo pocket of a hooded sweat shirt. Obviously you can’t walk around with it but for quick set ups I am getting some steady shots. kye 1 Link to comment Share on other sites More sharing options...
jgharding Posted November 22, 2018 Share Posted November 22, 2018 I have done a combination recently, and had a GH5 with IBIS on top of a heavy tripod with the legs pulled up, and holding it by the “neck” section or you can build a shoulder rig and hang a weight off the back in short nothing replaces weight but you can get some reasonably similar looks by other methods Link to comment Share on other sites More sharing options...
Adam Kuźniar Posted November 22, 2018 Share Posted November 22, 2018 10 hours ago, webrunner5 said: Wow look at the price of this ENG lens. Christ. https://www.bhphotovideo.com/c/product/1309404-REG/fujinon_ua80x9besm_e_digi_1_2_ext_ua80x9besm_e_digi_is_4k.html This is not an ENG lens, more of a sports/studio type, always mounted on a heavy duty tripod. Link to comment Share on other sites More sharing options...
Trek of Joy Posted November 22, 2018 Share Posted November 22, 2018 2 hours ago, jgharding said: I have done a combination recently, and had a GH5 with IBIS on top of a heavy tripod with the legs pulled up, and holding it by the “neck” section I do the same thing with my Manfrotto video monopod and the a73, or my extendo-pole with the GoPro. There’s enough weight to slow the small movements that make stuff look jittery. I have an office video/holiday card shoot coming up and I’m planning on doing multiple takes using my monopod for a more handheld look in addition to a gimbal. Chris jgharding 1 Link to comment Share on other sites More sharing options...
Raafi Rivero Posted November 22, 2018 Share Posted November 22, 2018 I use a counter-weight by Neewer on the back of my rig. It cost me $30 on Amazon. Here’s a link. Redrock Micro also sells a dual counter weight that fits on rails for around $350, LOL. @TheRenaissanceMan said it earlier. Getting your setup heavier is the only way. An extreme way of thinking about it is: you’re standing in the middle of a windy field holding a single piece of paper in your hands. You twist and kneel with it like you were operating a camera. You trade the piece of paper for a 15lb boulder, doing the same things. Which one flutters in the wind more? Link to comment Share on other sites More sharing options...
kye Posted November 22, 2018 Share Posted November 22, 2018 Further to the above comments, weight at distance is one part, but the other is how and where you hold it. I spent ages running around the house with various rigs of PVC piping (modular for travel) and even went so far as to fill it with water (readily available at your destination!) and quickly came to the conclusion that the less firmly I gripped it the less hand-shake it got, and basically replicated a steadicam by making little handles that could swivel and were mounted at the balance point of the whole rig. Link to comment Share on other sites More sharing options...
fuzzynormal Posted November 22, 2018 Share Posted November 22, 2018 My initial handheld shooting experiences were with film cameras and electronic tube cameras with outboard 3/4" recorders. Heavy stuff. You can't compensate for mass. As mentioned, that's pretty much the solution. You want a certain look with handheld, make your rig balanced yet heavy. Link to comment Share on other sites More sharing options...
webrunner5 Posted November 22, 2018 Share Posted November 22, 2018 1 hour ago, kye said: Further to the above comments, weight at distance is one part, but the other is how and where you hold it. I spent ages running around the house with various rigs of PVC piping (modular for travel) and even went so far as to fill it with water (readily available at your destination!) and quickly came to the conclusion that the less firmly I gripped it the less hand-shake it got, and basically replicated a steadicam by making little handles that could swivel and were mounted at the balance point of the whole rig. Yeah a steadicam is probably the better option than taking a 3 pound camera and trying to make it a 15 pound rig! ? Link to comment Share on other sites More sharing options...
Raafi Rivero Posted November 22, 2018 Share Posted November 22, 2018 1 hour ago, kye said: basically replicated a steadicam by making little handles that could swivel and were mounted at the balance point of the whole rig. do you have pics of this setup? Link to comment Share on other sites More sharing options...
