majoraxis Posted December 23, 2018 Share Posted December 23, 2018 Currently, on sale at through Amazon there are 2 x $339 high bright 7" monitors with SDI, one by Feelworld, one by Portkeys. The Feelworld is 2200nits, The Portkey is 1200nit. both are daylight viewable. though the Feelworld should be almost twice as bright. The Portkeys is has 3DLUT support, the Feelworld does not. Both have SDI, 4k HDMI... and a host of additional features. If you need 3D LUT support then the PortKeys HS7T (current on sale through December 25th for $339) seems like a reasonable trade off if your camera does not have an HDMI or SDI output with a 3D LUT applied. I plan to use it with the Blackmagic Cinema Camera. https://www.amazon.com/PortKeys-HS7T-Bright-1200nit-Monitor/dp/B07GSPGDHH/ref=sr_1_8?s=electronics&ie=UTF8&qid=1545551040&sr=1-8&keywords=Portkeys The FEELWORLD FW279S might be a better choice if you don't need 3D LUTS https://www.amazon.com/dp/B07J4CPJ3R?aaxitk=HgWbenBv6YilQplNdIhNyw&pd_rd_i=B07J4CPJ3R&pf_rd_p=3ff6092e-8451-438b-8278-7e94064b4d42&hsa_cr_id=8430460080401&sb-ci-n=productDescription&sb-ci-v=FEELWORLD FW279S 7 Inch 4K HDMI 3G-SDI 2200nit Daylight Viewable 1920x1200 On-Camera Field Monitor with Histogram%2C Focus Assist%2C Zebra Exposure%2C False Color%2C Check Field%2C Pixel to Pixel for DSLR Camer Also worth mentioning the Must HD M703S at $449 with says it supports 4k 60Hz in case it goes on deeper discount in the future. https://www.amazon.com/MustHD-Hyper-Brite-Brightness-1920x1200-Loop-Through/dp/B071412MSF/ref=sr_1_1?ie=UTF8&qid=1545552813&sr=8-1&keywords=musthd+m703s Link to comment Share on other sites More sharing options...
androidlad Posted December 23, 2018 Share Posted December 23, 2018 User interface is much much better on the Portkeys. Link to comment Share on other sites More sharing options...
Mako Sports Posted December 23, 2018 Share Posted December 23, 2018 C.J. did a really good review on the portkeys, makes me wanna sell my Smallhd 701 for it, sold my focus sdi a few days ago also ? https://youtu.be/hz3p_A2owC8 Link to comment Share on other sites More sharing options...
