mercer Posted December 27, 2018 Share Posted December 27, 2018 19 hours ago, deezid said: Just make it more dramatic then? For sure... my comment/opinion was based from the parameters and results of his test. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted December 27, 2018 Share Posted December 27, 2018 Fooling around with HLG. Adjusted curves using a waveform and added some saturation. It definitely seems a bit cleaner then log. Skin tones looked good according to the vectorscopes. mercer, deezid, Mark Romero 2 and 2 others 5 Link to comment Share on other sites More sharing options...
webrunner5 Posted December 27, 2018 Share Posted December 27, 2018 Wow that looks nice. Just about a perfect exposure. Mark Romero 2 and thebrothersthre3 2 Link to comment Share on other sites More sharing options...
DanielVranic Posted December 27, 2018 Share Posted December 27, 2018 Okay, I am 100% new to HLG and everything. I took a test shot this morning, and I saw that there is a lot of latitudes, but getting the most of it required really stretching it in Resolve. What is everyone's HLG X-T3 workflow? I just perfected my FLog workflow like a week ago and now this LOL Link to comment Share on other sites More sharing options...
chrisE Posted December 28, 2018 Share Posted December 28, 2018 22 hours ago, androidlad said: HLG was not designed to be an acquisition format, the curve is extremely non-linear and hard to grade manually. Where did you get this information from? I'd be really interested in the specs for HLG to get a better understanding of the characteristics and how to grade it properly. Any white papers? Link to comment Share on other sites More sharing options...
androidlad Posted December 28, 2018 Author Share Posted December 28, 2018 3 hours ago, chrisE said: Where did you get this information from? I'd be really interested in the specs for HLG to get a better understanding of the characteristics and how to grade it properly. Any white papers? https://www.itu.int/dms_pubrec/itu-r/rec/bt/R-REC-BT.2100-2-201807-I!!PDF-E.pdf As HLG is a relative standard just like BT.709, manufacturers can add their own customisation. Link to comment Share on other sites More sharing options...
DanielVranic Posted December 28, 2018 Share Posted December 28, 2018 I have done about a dozen separate HLG vs FLog tests here and HLG has not looked better in any of them. Low light capture is significantly better with Flog, maybe a full stop more captured information. Flog has been cleaner and easier to work with by a huge factor. I will still aim that way unless an awesome HLG workflow comes out. Link to comment Share on other sites More sharing options...
androidlad Posted December 28, 2018 Author Share Posted December 28, 2018 1 hour ago, DanielVranic said: I have done about a dozen separate HLG vs FLog tests here and HLG has not looked better in any of them. Low light capture is significantly better with Flog, maybe a full stop more captured information. Flog has been cleaner and easier to work with by a huge factor. I will still aim that way unless an awesome HLG workflow comes out. Please support your claims with empirical evidence - sample frames, exposure parameters etc. Link to comment Share on other sites More sharing options...
DanielVranic Posted December 28, 2018 Share Posted December 28, 2018 48 minutes ago, androidlad said: Please support your claims with empirical evidence - sample frames, exposure parameters etc. Will do as soon as I get home! Early start today Link to comment Share on other sites More sharing options...
chrisE Posted December 29, 2018 Share Posted December 29, 2018 On 12/28/2018 at 2:58 PM, androidlad said: https://www.itu.int/dms_pubrec/itu-r/rec/bt/R-REC-BT.2100-2-201807-I!!PDF-E.pdf As HLG is a relative standard just like BT.709, manufacturers can add their own customisation. Thanks a lot, that's a start! But after a first look, that seems to be more about the color that curve that's being used to convert the raw data from the sensor to the 8bits in the final video file. Any more information? Link to comment Share on other sites More sharing options...
androidlad Posted December 29, 2018 Author Share Posted December 29, 2018 6 minutes ago, chrisE said: Thanks a lot, that's a start! But after a first look, that seems to be more about the color that curve that's being used to convert the raw data from the sensor to the 8bits in the final video file. Any more information? Everything about HLG (and PQ) is in that whitepaper, it delineates both the OETF and EOTF that underpin HLG as a system. Link to comment Share on other sites More sharing options...
DanielVranic Posted December 30, 2018 Share Posted December 30, 2018 is HLG 10 bit or no? Link to comment Share on other sites More sharing options...
BrunoCH Posted December 31, 2018 Share Posted December 31, 2018 1 hour ago, DanielVranic said: is HLG 10 bit or no? Normally you can get the info with VideoSpec or Mediainfo (free app). Link to comment Share on other sites More sharing options...
webrunner5 Posted December 31, 2018 Share Posted December 31, 2018 1 hour ago, DanielVranic said: is HLG 10 bit or no? As far as I know it is 10bit and above. But it is available in the Sony A7r mk III, and that is not a 10 bit camera?? Link to comment Share on other sites More sharing options...
androidlad Posted December 31, 2018 Author Share Posted December 31, 2018 1 hour ago, DanielVranic said: is HLG 10 bit or no? HLG can be either 10bit or 12bit per BT.2100 standard. X-T3 is BT.2100 compliant and can only record using HEVC codec when HLG mode is selected. Since HLG is an open standard, Sony decided to deviate from the standard and used 8bit encoding, along with various HLG curves. Link to comment Share on other sites More sharing options...
DanielVranic Posted December 31, 2018 Share Posted December 31, 2018 13 hours ago, androidlad said: HLG can be either 10bit or 12bit per BT.2100 standard. X-T3 is BT.2100 compliant and can only record using HEVC codec when HLG mode is selected. Since HLG is an open standard, Sony decided to deviate from the standard and used 8bit encoding, along with various HLG curves. Thanks! Also, I haven't posted samples yet because upon further testing my processing chain was wrong. I still have no idea how to process or grade Fuji HLG footage Link to comment Share on other sites More sharing options...
MeanRevert Posted February 28, 2019 Share Posted February 28, 2019 Hey guys, Just following this interesting thread waiting for my camera to arrive.. You guys still going down the Flog route or is HLG the way to go? I've seen some good side by side from camtheman and the hlg looked great. Any new info since this thread? Link to comment Share on other sites More sharing options...
KnightsFan Posted February 28, 2019 Share Posted February 28, 2019 I have only done a few tests so far, but i am liking HLG better. It is easier to grade. Link to comment Share on other sites More sharing options...
MeanRevert Posted February 28, 2019 Share Posted February 28, 2019 14 hours ago, KnightsFan said: I have only done a few tests so far, but i am liking HLG better. It is easier to grade. Hi, are you using the same FLOG LUTs with this or are they too strong? Link to comment Share on other sites More sharing options...
KnightsFan Posted February 28, 2019 Share Posted February 28, 2019 13 minutes ago, MeanRevert said: Hi, are you using the same FLOG LUTs with this or are they too strong? I used the offical Fuji FLog luts, and created some using LutCalc. For HLG I used the Color Space Transform node in Resolve, and tried out the HLG LUTs that came packaged with Resolve. Overall i found it much easier to get the result i wanted when using HLG. Link to comment Share on other sites More sharing options...
