Julian Posted June 5, 2013 Share Posted June 5, 2013 Just a straight conversion from raw to CineForm is my workflow. Then grade it in Resolve or Premiere as normal. There's not really any in-between step that's necessary. I see. I also noticed that when I open the CineForm files in Resolve, it looks pretty close to the raw DNG's with standard conversion in ACR. when I open them in quicktime everything looks dull. But with this workflow, you don't have control over things like debayering. I noticed you can drag DNG sequences straight into CineForm Studio and then you have full control over the conversion, sharpness, noise reduction, etc. Will have to experiment with this... When using CineForm 444 the compression is 'only' about 3.25:1 btw. At least I got 21.7 GB of .raw files and that converted to 6.66GB of CineForm 444 mov. I might experiment with CineForm 422, that should work with the free version. Maybe could use that for quick projects/proxies and go the full CinemaDNG route in resolve if I want full control. $300 also buys me at least 6TB of HDD space. Link to comment Share on other sites More sharing options...
bplet Posted June 5, 2013 Share Posted June 5, 2013 Sorry for my noob noob question... Could you be so gentle to write at a dummy level the steps to convert the raw file in cineform files? I've got the cineform free but I continue to get an error and the raw2gpcf quit. I'm on win8 i7 16GB 680m... Is it possible the problem here (I've heard several people describe similar issues) is that they're attempting this using the free version? I was under the impression that the free version does not include RAW output Link to comment Share on other sites More sharing options...
sigoldberg1 Posted June 8, 2013 Share Posted June 8, 2013 An series of applied engineering questions. To what extent can some form of "lossless conversion be done in camera before writing to storage? Are any of the processors even close in power? Suppose one were to substitute a relatively "lossless conversion" algorithm for the H264 compression now built in? Is this possible? Is the H264 algorithm in firmware or hardware? Can it be intercepted in progress and made into camera output? This applies to all the cameras with some form of ML raw. What about Nikon? Apparently their DSL engine has a more public architecture? Thanks Link to comment Share on other sites More sharing options...
PANDETTA Posted August 28, 2013 Share Posted August 28, 2013 Can I edit cineform raw footage in premiere without installing gopro cineform studio premium? Link to comment Share on other sites More sharing options...
PrimeHD Posted October 11, 2013 Share Posted October 11, 2013 Andrew, guys: There might be another alternative now. Check out: raw4pro.com I am both a programmer and a videographer. For me, this RAW to CineformRAW conversion app works great. Thanks, Alex Link to comment Share on other sites More sharing options...
nigelbb Posted October 12, 2013 Share Posted October 12, 2013 Unless I missed something thar raw2cfraw does not operate on Magic Lantern 5D3 RAW video files just .CR2 stills sequences. Link to comment Share on other sites More sharing options...
PrimeHD Posted October 20, 2013 Share Posted October 20, 2013 Unless I missed something thar raw2cfraw does not operate on Magic Lantern 5D3 RAW video files just .CR2 stills sequences. I downloaded 5D III RAW sample ( DNG frame sequence folder) from here: http://neumannfilms.net/2013/05/21/red-epic5d3-raw-tests/ ...and converted it with our RAW 4 PRO utility to CineformRAW just fine - see here: http://goo.gl/IU9qqJ Sorry, I'm not closely following the developments - are there other raw formats 5D III saves video in? Where can I download some samples? Link to comment Share on other sites More sharing options...
PrimeHD Posted October 21, 2013 Share Posted October 21, 2013 Unless I missed something thar raw2cfraw does not operate on Magic Lantern 5D3 RAW video files just .CR2 stills sequences. I looked a bit further, and here it says that .raw "...files cannot currently be processed directly by any video editor. Each RAW file encapsulates the frames in DNG format so we need to extract these frames first" Source: http://www.magiclantern.fm/forum/index.php?topic=5654.0 It then proceeds to explain how to extract DNG out of .raw So then, that would be your step 1 in case of 5D Mk III - produced raw video. Step 2 would be using RAW 2 CF RAW if you wish to get an easily viewable/editable video raw out of that DNG sequence. I do this a lot (albeit with BMCC's DNGs.) Link to comment Share on other sites More sharing options...
PrimeHD Posted October 30, 2013 Share Posted October 30, 2013 duplicate post deleted Link to comment Share on other sites More sharing options...
PrimeHD Posted November 19, 2013 Share Posted November 19, 2013 So since the last post, we have tested RAW 2 CF RAW with BMCC, Digital Bolex, Ikonoskop DNGs - all successfully. Now moving on to the BATCH edition. It will, of course, still merge audio. The resulting video is RAW, so you can apply LUTs for instant grading, etc. Link to comment Share on other sites More sharing options...
PrimeHD Posted August 6, 2014 Share Posted August 6, 2014 ...and now RAW 4 PRO v 3.0 supports Blackmagic Production Camera 4K RAW clips, too! Link to comment Share on other sites More sharing options...
PrimeHD Posted January 10, 2016 Share Posted January 10, 2016 Just released RAW 4 PRO v5.1 with improvements and low-cost options. Free demo / updates here: http://Raw4pro.com Link to comment Share on other sites More sharing options...
PrimeHD Posted November 15, 2017 Share Posted November 15, 2017 Hey, so we have removed all the limitations from the newest RAW 4 PRO EASY edition. It no longer requires an Internet connection, there's no registration, and it can be installed/reinstalled an unlimited number of times on your PCs. Truly easy. The ONLY converter with Cineform RAW output, sanctioned by Cineform. I'd like to offer a discount code to EOSHD members: put EASY in the cart and apply coupon eoshd81off This lowers the price from $110 all the way down to just $29. Thanks for reading. Link to comment Share on other sites More sharing options...
