@yan_berthemy_photography Posted January 9, 2019 Share Posted January 9, 2019 Hi there, just got my GH5, one question, I would like to use In-body stabilization, will in body stabilization this crop the image? Using 4k, I know it will crop, but if I add the in body stabilization, will it crop also? Thanks. Link to comment Share on other sites More sharing options...
webrunner5 Posted January 9, 2019 Share Posted January 9, 2019 As far as I know there is three types of stabilization for video capture; lens, in-camera, and electronic. Only the electronic one will crop. @yan_berthemy_photography 1 Link to comment Share on other sites More sharing options...
anonim Posted January 9, 2019 Share Posted January 9, 2019 2 hours ago, @yan_berthemy_photography said: Hi there, just got my GH5, one question, I would like to use In-body stabilization, will in body stabilization this crop the image? Using 4k, I know it will crop, but if I add the in body stabilization, will it crop also? Thanks. There's no crop with just sensor stabilization, even in 4K. Orangenz and @yan_berthemy_photography 1 1 Link to comment Share on other sites More sharing options...
@yan_berthemy_photography Posted January 9, 2019 Author Share Posted January 9, 2019 57 minutes ago, anonim said: There's no crop with just sensor stabilization, even in 4K. Ok thanks a lot for your answer! Link to comment Share on other sites More sharing options...
kye Posted January 9, 2019 Share Posted January 9, 2019 No crop and it's really wonderful to use - I have used it handheld with long vintage lenses and it's worked really well. Enjoy! @yan_berthemy_photography 1 Link to comment Share on other sites More sharing options...
@yan_berthemy_photography Posted January 9, 2019 Author Share Posted January 9, 2019 21 minutes ago, kye said: No crop and it's really wonderful to use - I have used it handheld with long vintage lenses and it's worked really well. Enjoy! Thanks a lot! I will use it with my gimbal, will this be good with 100mm lens? Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted January 9, 2019 Share Posted January 9, 2019 29 minutes ago, @yan_berthemy_photography said: Thanks a lot! I will use it with my gimbal, will this be good with 100mm lens? I'd rather use a gimbal or monopod with a long lens like that. For me gimbals are better for getting wide moving shots. @yan_berthemy_photography 1 Link to comment Share on other sites More sharing options...
@yan_berthemy_photography Posted January 9, 2019 Author Share Posted January 9, 2019 3 minutes ago, thebrothersthre3 said: I'd rather use a gimbal or monopod with a long lens like that. For me gimbals are better for getting wide moving shots. yes, I agree with you, but I use 25mm 1.7 so should be fine. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted January 9, 2019 Share Posted January 9, 2019 Just now, @yan_berthemy_photography said: yes, I agree with you, but I use 25mm 1.7 so should be fine. Ahh, yeah you can get good shots handheld with 100mm. Link to comment Share on other sites More sharing options...
kye Posted January 9, 2019 Share Posted January 9, 2019 I used mine hand-held with a 58mm Helios on it, which is the equivalent of a 116mm lens on full-frame. That worked well when I was able to be reasonably steady but needed a bit of help when I was cold or had been active. On a gimbal you shouldn't have any problems at all Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted January 9, 2019 Share Posted January 9, 2019 31 minutes ago, kye said: I used mine hand-held with a 58mm Helios on it, which is the equivalent of a 116mm lens on full-frame. That worked well when I was able to be reasonably steady but needed a bit of help when I was cold or had been active. On a gimbal you shouldn't have any problems at all 100mm is twice as long as 50mm. The issue I have with mounting a long lens on a gimbal is movement. Gimbals are harder to control then simply holding something by hand. If you are just doing a static shot its fine but if you are trying to pan with the gimbal or move its really difficult. Link to comment Share on other sites More sharing options...
kye Posted January 9, 2019 Share Posted January 9, 2019 39 minutes ago, thebrothersthre3 said: 100mm is twice as long as 50mm. The issue I have with mounting a long lens on a gimbal is movement. Gimbals are harder to control then simply holding something by hand. If you are just doing a static shot its fine but if you are trying to pan with the gimbal or move its really difficult. I'm still unclear if the OP is using a 100mm lens or a 100mm equivalent lens. I'm also a little surprised that you didn't get good results. I've only used a gimbal on my phone but it made smooth movement really easy to achieve. Maybe with a longer lens it would help to change to the slowest movement? What was the problem you had? Was the pan speed uneven or did it not stabilise enough? Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted January 10, 2019 Share Posted January 10, 2019 30 minutes ago, kye said: I'm still unclear if the OP is using a 100mm lens or a 100mm equivalent lens. I'm also a little surprised that you didn't get good results. I've only used a gimbal on my phone but it made smooth movement really easy to achieve. Maybe with a longer lens it would help to change to the slowest movement? What was the problem you had? Was the pan speed uneven or did it not stabilise enough? Hard to control movements precisely with a gimbal. A little movement translates to a big movement on a long lens. kye 1 Link to comment Share on other sites More sharing options...
