ZEEK Posted June 20, 2019 Share Posted June 20, 2019 5 hours ago, plucas said: For anyone who has used both the EOS M and 5Dii, what's the relative ISO capabilities when using Magic Lantern? With the EOS M, I get lots of noise after 160-200. One of Andrew's articles made mention of noise at higher ISOs like 800 and 1600 (but that they added an attractive film-like grain). Can the 5Dii keep a cleaner image at higher ISOs than the EOS M? I have two EOS M's and have had two 5D2's, the 5D is cleaner than the EOS M without the speedbooster at high ISOs. Pop a speedbooster on the EOS M and then they're pretty close with the 5D slightly at the upper hand. Honestly, I don't get the point of shooting at high ISO's (unless it's your base ISO e.g. 800). If you must shoot in the dark, just use some cheap lights, an iphone screen or something and then add de-noising and it's fine. webrunner5, Emanuel and plucas 2 1 Link to comment Share on other sites More sharing options...
plucas Posted June 20, 2019 Share Posted June 20, 2019 2 hours ago, ZEEK said: I have two EOS M's and have had two 5D2's, the 5D is cleaner than the EOS M without the speedbooster at high ISOs. Pop a speedbooster on the EOS M and then they're pretty close with the 5D slightly at the upper hand. Honestly, I don't get the point of shooting at high ISO's (unless it's your base ISO e.g. 800). If you must shoot in the dark, just use some cheap lights, an iphone screen or something and then add de-noising and it's fine. I suppose that's right. It helps best to apply a light source rather than rely on ISO. I could imagine a use for higher ISO if you want to capture a deeper depth of field for your scene and natural light is poor. I live, for example, near a bridge that crosses a river in Geelong and would love to shoot the sunset there over the horizon. Otherwise I've thought about buying one of those Neewer LED light panels that hook on to a hot shoe for the EOS M but a smartphone with the backlight turned on could work well enough too if the focus object is nearby. Encouraging to hear that the EOS M with the speedbooster is a near match for the 5Dii. Thanks again, Zeek. Link to comment Share on other sites More sharing options...
ZEEK Posted June 21, 2019 Share Posted June 21, 2019 No problem. I they're both great cameras for sure! I just prefer the form factor of the EOS M and how the files look when they're graded compared to the 5DII. Cheers plucas and Emanuel 2 Link to comment Share on other sites More sharing options...
loybart Posted June 30, 2019 Share Posted June 30, 2019 guys, I just pulled the trigger for this camera. However, the firmware version is 1.6 something and canon's site is only offering 2.3. Where can i download a credible 2.2 version? I understand the 2.3 on ML will brick the camera. thanks. kaylee 1 Link to comment Share on other sites More sharing options...
Avenger 2.0 Posted June 30, 2019 Share Posted June 30, 2019 24 minutes ago, loybart said: guys, I just pulled the trigger for this camera. However, the firmware version is 1.6 something and canon's site is only offering 2.3. Where can i download a credible 2.2 version? I understand the 2.3 on ML will brick the camera. thanks. Should be on the ML website. The 2.3 has an experimental ML version. You can also always downgrade back to 2.2. kaylee and loybart 2 Link to comment Share on other sites More sharing options...
loybart Posted June 30, 2019 Share Posted June 30, 2019 Avenger 2.0, Thanks!!!! Got it... Link to comment Share on other sites More sharing options...
tupp Posted June 30, 2019 Share Posted June 30, 2019 6 hours ago, loybart said: I just pulled the trigger for this camera. However, the firmware version is 1.6 something and canon's site is only offering 2.3. Where can i download a credible 2.2 version? I understand the 2.3 on ML will brick the camera. There is/was an ML version for EOSM firmware 2.0.3. ML developer Daniel Fort has a 2.0.3 ML version from January 2017 on his bitbucket download page (scroll down to "magiclantern-Nightly.2017Jan13.EOSM203.zip"), Always make sure that your camera battery is fully charged before you attempt to install Magic Lantern. If you would like to downgrade your EOSM firmware to 2.0.2, and then install the latest builds for 2.0.2, here is Daniel Fort's tutorial on how to downgrade Canon firmware. It is fairly easy, once you have the firmware (.fir) file -- just reflash the firmware the same way you would flash ML (except the SD card should not have the "boot flag" enabled). Always make sure that your camera battery is fully charged before you attempt a firmware update. Canon doesn't seem to have the EOSM 2.0.2 firmware posted for download, but here is the link that Daniel Fort gives for most Canon firmware (scroll to the bottom of this page to find the firmware links). The EOSM 2.0.2 firmware can also be found on this non-Canon page. Scroll down to the firmware download link for "eosm-v202-win.zip" near the bottom of the page (it's not the "ksd291a_installer.zip" download link near the top of the page). Windows (nor any other particular OS) is not required, once you have extracted the firmware from the zip file. In Fort's firmware downgrade tutorial, he seems to suggest that it is very unlikely that someone would/could tamper with compressed Canon firmware files (.fir) loybart, webrunner5 and PannySVHS 2 1 Link to comment Share on other sites More sharing options...
plucas Posted July 1, 2019 Share Posted July 1, 2019 From Zeek: slow-motion test on the EOS M. ZEEK and Emanuel 2 Link to comment Share on other sites More sharing options...
loybart Posted July 1, 2019 Share Posted July 1, 2019 10 hours ago, tupp said: There is/was an ML version for EOSM firmware 2.0.3. ML developer Daniel Fort has a 2.0.3 ML version from January 2017 on his bitbucket download page (scroll down to "magiclantern-Nightly.2017Jan13.EOSM203.zip"), Always make sure that your camera battery is fully charged before you attempt to install Magic Lantern. If you would like to downgrade your EOSM firmware to 2.0.2, and then install the latest builds for 2.0.2, here is Daniel Fort's tutorial on how to downgrade Canon firmware. It is fairly easy, once you have the firmware (.fir) file -- just reflash the firmware the same way you would flash ML (except the SD card should not have the "boot flag" enabled). Always make sure that your camera battery is fully charged before you attempt a firmware update. Canon doesn't seem to have the EOSM 2.0.2 firmware posted for download, but here is the link that Daniel Fort gives for most Canon firmware (scroll to the bottom of this page to find the firmware links). The EOSM 2.0.2 firmware can also be found on this non-Canon page. Scroll down to the firmware download link for "eosm-v202-win.zip" near the bottom of the page (it's not the "ksd291a_installer.zip" download link near the top of the page). Windows (nor any other particular OS) is not required, once you have extracted the firmware from the zip file. In Fort's firmware downgrade tutorial, he seems to suggest that it is very unlikely that someone would/could tamper with compressed Canon firmware files (.fir) Tupp, Thanks. This group is awesome. Hopefully I will be testing the camera this weekend. Link to comment Share on other sites More sharing options...
plucas Posted July 4, 2019 Share Posted July 4, 2019 The EOSMPCC: Emanuel, ZEEK and loybart 2 1 Link to comment Share on other sites More sharing options...
ZEEK Posted July 4, 2019 Share Posted July 4, 2019 7 hours ago, plucas said: Nice one Pau! The whole rig looks breathtaking, now it's time to see some footage . You've gone the Vintage Minolta route, nice one! Link to comment Share on other sites More sharing options...
plucas Posted July 4, 2019 Share Posted July 4, 2019 My bad! Should've made clear that this is somebody else's rig. It just impressed me; that's all. It does show though how useful the EOS M has become for serious hobbyists. Link to comment Share on other sites More sharing options...
ZEEK Posted July 4, 2019 Share Posted July 4, 2019 Haha, all good. Its good to see the EOS M getting a good work out Best cam for me in my opinion. A lot of people are seeing its true potential and what beautiful footage it can create for the price. plucas, Emanuel and webrunner5 3 Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted July 25, 2019 Super Members Share Posted July 25, 2019 Usually when people argue about camera sale statistics from Japan they show lists that is excluding crop sensor cameras and DSLRs (in order to make the Z6, EOS-R, A7iii look better, because DSLRs still outsell them all). And when one looks at a list that at least shows all the mirrorless cameras, crop sensors included, It is an EOS-M model at the top. Pretty interesting imo. Goes to show that our "old" views doesn't apply to the generation that will run the world in 10-15 years. My tip from a business stand point is to stop brushing "millennial", "vloggers" and "kids" under the rug. Because it will be your doom. Adapt or disappear. (This is June only so it doesn't represent the whole truth. Should go without saying but Ive learned to stop overestimating the internet ) Link to comment Share on other sites More sharing options...
webrunner5 Posted July 25, 2019 Share Posted July 25, 2019 2 hours ago, Mattias Burling said: Usually when people argue about camera sale statistics from Japan they show lists that is excluding crop sensor cameras and DSLRs (in order to make the Z6, EOS-R, A7iii look better, because DSLRs still outsell them all). And when one looks at a list that at least shows all the mirrorless cameras, crop sensors included, It is an EOS-M model at the top. Pretty interesting imo. Goes to show that our "old" views doesn't apply to the generation that will run the world in 10-15 years. My tip from a business stand point is to stop brushing "millennial", "vloggers" and "kids" under the rug. Because it will be your doom. Adapt or disappear. (This is June only so it doesn't represent the whole truth. Should go without saying but Ive learned to stop overestimating the internet ) Oh I will be dead thank God by the time those silly bastards take over. If you are younger than me than you Are doomed. And your list is silly as hell. Naturally cheaper cameras are going to sell a shit pot more than cameras that cost 3 to 5 times more. Crazy people. Aren't you a "millennial"? Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted July 25, 2019 Super Members Share Posted July 25, 2019 Luckily there are many business men and women in your age that does not roll over and give up. Instead they see the potential for something different, which unlike what many believe, isn't the same as worse. Will be fun to follow which camera companies that gets it and doesn't die. Trying to make the this century a copy paste of the last is a first class ticket to marginalization. PannySVHS 1 Link to comment Share on other sites More sharing options...
Shell64 Posted August 1, 2019 Share Posted August 1, 2019 Canon eos m raw w/ experimental builds vs canon 50d. What is better and more stable for raw video? Link to comment Share on other sites More sharing options...
webrunner5 Posted August 2, 2019 Share Posted August 2, 2019 On 7/25/2019 at 10:38 AM, Mattias Burling said: Luckily there are many business men and women in your age that does not roll over and give up. Instead they see the potential for something different, which unlike what many believe, isn't the same as worse. Will be fun to follow which camera companies that gets it and doesn't die. Trying to make the this century a copy paste of the last is a first class ticket to marginalization. You don't know much about politics then. Any radical change is suicide. They might know they are wrong, but money and power is stronger than common sense. That is why it is so screwed up now. And the trend now for young people wanting everything for free is Socialism. We see how well that has worked out around the world. A middle ground well sure. Not extremes. Every 4 to 8 years here in the USA the pengelium swings the complete opposite way. Republicans versus the Democrats. Sort of kept it in balance in the past. Now all I see is hatred toward the other side. No good end in the near future for that kind of belief. Radical beliefs lead to Very bad outcomes. In this day and age 3 to 4 top economies can change the entire world. Not like it was years ago. Everyone is vulnerable now. Times have changed, probably for the worse. Too little, too late now. The Oh My God moment was several years ago. To me the EU put a heck of a lot of countries in harms way more than they have helped them down the road. Skip77 1 Link to comment Share on other sites More sharing options...
Avenger 2.0 Posted August 2, 2019 Share Posted August 2, 2019 11 hours ago, Shell64 said: Canon eos m raw w/ experimental builds vs canon 50d. What is better and more stable for raw video? I find the Eos M more stable. Canon 50D wasn't really made for video and will overheat. And not sure the 50D is actively supported at the moment. Link to comment Share on other sites More sharing options...
plucas Posted August 2, 2019 Share Posted August 2, 2019 It looks like ML development on the EOS M is actively ongoing. There are new experimental builds available every week or two. It has a great (small) form factor, accepts a speedbooster, and thereby allows you to film with a 1.14X field of view crop. It upscales to 4K decently. The weakness is the low light performance and lack of autofocus but compared to the 50D, I can't imagine you'll fare worse. If you need any conviction about the potential of the EOS M, search "Zeek magic lantern" on Youtube. Link to comment Share on other sites More sharing options...
