Jip-Hop Posted May 14, 2019 Share Posted May 14, 2019 Video AF can be enabled, also when using ML. Didn't really test it, but when I noticed the lens started to autofocus I turned AF off. Don't think the AF will be usable in video mode on this camera. Link to comment Share on other sites More sharing options...
stephen Posted May 14, 2019 Share Posted May 14, 2019 It depends what kind of AF. Tracking AF in video is not working. At least when in ML RAW modes. It's working in photo mode. But don't like it and don't use it. However single shot AF is working in both photo and video including ML RAW. Single shot like: you press the button, camera focuses and signals when focus is achieved. It's kind of slow but it works and focus is reliable. In my settings different buttons are assigned for focusing and exposure metering. Here is how usually shoot no matter if AF or MF is used. 1. check/correct exposure settings 2. Frame 3. Focus 4.Start recording. It's a slow process but works reasonably well. This is not a camera for fast paced shooting. Settings in video are as follows: AF method - FlexiZoneAF square / Focus mode - AF+MF webrunner5 1 Link to comment Share on other sites More sharing options...
plucas Posted May 15, 2019 Share Posted May 15, 2019 Thanks Jip-Hop and Stephen. Continuous autofocus would have been great but 14 bit RAW for $150 was bound to have limitations like this. Link to comment Share on other sites More sharing options...
Emanuel Posted May 16, 2019 Share Posted May 16, 2019 kaylee and heart0less 2 Link to comment Share on other sites More sharing options...
Emanuel Posted May 16, 2019 Share Posted May 16, 2019 heart0less 1 Link to comment Share on other sites More sharing options...
Emanuel Posted May 19, 2019 Share Posted May 19, 2019 EF-M 18-55 Kit lens: On 5/14/2019 at 11:17 AM, plucas said: Perhaps a silly question from an about-to-be first time ML user: does the EOS M autofocus work with Magic Lantern? kaylee 1 Link to comment Share on other sites More sharing options...
Emanuel Posted May 25, 2019 Share Posted May 25, 2019 tupp and ZEEK 2 Link to comment Share on other sites More sharing options...
ZEEK Posted May 26, 2019 Share Posted May 26, 2019 7 hours ago, Emanuel said: Nice! The pink highlights gave the EOS M away. But it can be fixed immediately in MLV App if the RAW White level is changed from the original "16200" to "15000". I also purchased the Orginal BMPCC for peanuts, though haven't used it much yet as I still need a few extra pieces of equipment (one being a "powerbank"). Few test footage looks quite nice though. mercer, Emanuel and webrunner5 3 Link to comment Share on other sites More sharing options...
mercer Posted May 26, 2019 Share Posted May 26, 2019 48 minutes ago, ZEEK said: Nice! The pink highlights gave the EOS M away. But it can be fixed immediately in MLV App if the RAW White level is changed from the original "16200" to "15000". I also purchased the Orginal BMPCC for peanuts, though haven't used it much yet as I still need a few extra pieces of equipment (one being a "powerbank"). Few test footage looks quite nice though. Love what you’re doing with the EOS-M, zeek! The Milvus/Samyang comparison was great. I look forward to your BMPCC videos!! tupp, ZEEK and Emanuel 3 Link to comment Share on other sites More sharing options...
ZEEK Posted May 26, 2019 Share Posted May 26, 2019 21 minutes ago, mercer said: Love what you’re doing with the EOS-M, zeek! The Milvus/Samyang comparison was great. I look forward to your BMPCC videos!! Thanks, Mercer, the Eos m raw can really shine if the RAW is manipulated properly, i'm still learning anyway. I'm really impressed with the bmpcc original as well. The proress HQ looks very close to RAW, and the RAW, when upscaled to 4K resolution in Davinci Resolve, looks quite close to the BMPCC 4K. Cheers! mercer, tupp and webrunner5 3 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 26, 2019 Author Administrators Share Posted May 26, 2019 On 5/16/2019 at 12:23 PM, Emanuel said: Are these full sensor width, or a heavy crop? Link to comment Share on other sites More sharing options...
ZEEK Posted May 27, 2019 Share Posted May 27, 2019 1 hour ago, Andrew Reid said: Are these full sensor width, or a heavy crop? No heavy crop at all! The crop I believe is the typical canon EOS M crop x1.61. My Sigma 18-35mm looks really wide and with a Viltrox 0.71x speed booster, I can use between 24-35mm F1.2. webrunner5 and tupp 2 Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted May 27, 2019 Author Administrators Share Posted May 27, 2019 Wow. Liked your footage a lot Zeek... What res was it before the upscale to 4K? Even my 4K screenshot of the YouTube frame has plenty of pop ZEEK 1 Link to comment Share on other sites More sharing options...
ZEEK Posted May 27, 2019 Share Posted May 27, 2019 1 39 minutes ago, Andrew Reid said: Thanks a lot! . Yeah, surprisingly enough, it was recorded at the resolution of 1736x976 before the upscale. Just shows how much information the RAW file contains. tupp 1 Link to comment Share on other sites More sharing options...
tupp Posted May 27, 2019 Share Posted May 27, 2019 @ZEEK Thank you for the beautiful, informative videos and for the luts! It is very helpful when you include detailed settings with each video for ML and for the MLV app. Please keep up the good work! ZEEK 1 Link to comment Share on other sites More sharing options...
ZEEK Posted May 27, 2019 Share Posted May 27, 2019 @Tupp No problem! Link to comment Share on other sites More sharing options...
plucas Posted May 28, 2019 Share Posted May 28, 2019 Zeek's film presents for the MLV App are great. I think you need to over-expose without clipping highlights to achieve best results but, as said above, it holds a lot of detail. I've found low light fliming tricky though because there's so much noise. Link to comment Share on other sites More sharing options...
ZEEK Posted May 28, 2019 Share Posted May 28, 2019 7 hours ago, plucas said: Zeek's film presents for the MLV App are great. I think you need to over-expose without clipping highlights to achieve best results but, as said above, it holds a lot of detail. I've found low light fliming tricky though because there's so much noise. Dual ISO 100/400 (I feel 100/800 is too aggressive) really helps heaps in tough situations and gets you 12.9-13 stops of DR. I haven't had any issues with Low light! Use a speed booster, keep ISO @100, and use a fast lens (at least f1.4 for the night). Cinema companies still use noise reduction software, so that can be included in the editing workflow if needed. Emanuel and plucas 1 1 Link to comment Share on other sites More sharing options...
Emanuel Posted May 28, 2019 Share Posted May 28, 2019 Exactly my own findings : -) ZEEK 1 Link to comment Share on other sites More sharing options...
plucas Posted May 28, 2019 Share Posted May 28, 2019 Thanks. I'll definitely try that dual ISO. 12-13 stops of DR is very appealing too. I have wondered if there's something wrong with my copy of the EOS M because the noise is terrible indoors and without a lot of light. Hopefully it's user error. ZEEK 1 Link to comment Share on other sites More sharing options...
