BrunoCH Posted January 18, 2019 Share Posted January 18, 2019 In LUTCalc, I made a LUT : False color for XT-3. I choose 3D 17x17x17. I check this LUT in FCPX. It works fine. But I can’t load this LUT in my monitor SWIT 55C. Did anyone manage to do that? Link to comment Share on other sites More sharing options...
webrunner5 Posted January 18, 2019 Share Posted January 18, 2019 So are you actually trying to put it in using the SD card slot? Link to comment Share on other sites More sharing options...
BrunoCH Posted January 18, 2019 Author Share Posted January 18, 2019 Yes I formatted the card in FAT and I put the LUT at the root. The monitor recognizes the card but does not see the LUT. Link to comment Share on other sites More sharing options...
androidlad Posted January 18, 2019 Share Posted January 18, 2019 There are three LUT options, camera/user/calibration, make sure you select "user". Link to comment Share on other sites More sharing options...
BrunoCH Posted January 18, 2019 Author Share Posted January 18, 2019 Thanks. That's good. Reformat the card with my Nikon, placed the LUT at the root and everything works fine. (Before format the card on my iMac in FAT) IronFilm 1 Link to comment Share on other sites More sharing options...
androidlad Posted January 19, 2019 Share Posted January 19, 2019 By the way I was told there's a big Kaizen firmware coming for CM-55C around the end of this month. It'll be available here: http://www.swit.cc/productshow.aspx?id=320 Link to comment Share on other sites More sharing options...
BrunoCH Posted January 19, 2019 Author Share Posted January 19, 2019 Good new ! Very good monitor but I'm a little disappointed by the Users LUTs. There are only 17x17x17. Not very useful. Hope the new firmware can improve this. Link to comment Share on other sites More sharing options...
androidlad Posted January 19, 2019 Share Posted January 19, 2019 8 hours ago, BrunoCH said: Good new ! Very good monitor but I'm a little disappointed by the Users LUTs. There are only 17x17x17. Not very useful. Hope the new firmware can improve this. 17^3 precision is more than enough for monitoring. The ones that support higher precision all downconvert to 17^3 internally. Link to comment Share on other sites More sharing options...
Timotheus Posted January 19, 2019 Share Posted January 19, 2019 @BrunoCH can you comment on the anamorphic functions of this monitor? Very interested whether it can display full size 2x stretch... Thanks. Link to comment Share on other sites More sharing options...
BrunoCH Posted January 19, 2019 Author Share Posted January 19, 2019 1 minute ago, Timotheus said: @BrunoCH can you comment on the anamorphic functions of this monitor? Very interested whether it can display full size 2x stretch... Thanks. I don't use anamorphic but you get 1X ; 1,33X ; 1,5X ; 1,66X ; 2X ; 2XMAG. 9 hours ago, androidlad said: 17^3 precision is more than enough for monitoring. The ones that support higher precision all downconvert to 17^3 internally. What do you mean about down convert internally? I expose my goal. I created with 3D LUT combine tool (colorizer.net) a Fuji deLOG -1 stop and another - 2 stop. these LUTs are to get a correct REC 709 image when I ETTR the FLOG on a low-contrast scene. But these LUTs are 3x65 and they don't work on my monitor. Do you have an idea to do this? Link to comment Share on other sites More sharing options...
BrunoCH Posted January 19, 2019 Author Share Posted January 19, 2019 @Timotheus Bad iPhone video. Hope it can help. https://drive.google.com/file/d/1jOPTNaDZ4N-7kvtid5l6qOw_QpdFinhy/view?usp=sharing Timotheus 1 Link to comment Share on other sites More sharing options...
Timotheus Posted January 20, 2019 Share Posted January 20, 2019 22 hours ago, BrunoCH said: Hope it can help. Very much so. Thank you for helping out man. Link to comment Share on other sites More sharing options...
androidlad Posted January 20, 2019 Share Posted January 20, 2019 23 hours ago, BrunoCH said: I don't use anamorphic but you get 1X ; 1,33X ; 1,5X ; 1,66X ; 2X ; 2XMAG. What do you mean about down convert internally? I expose my goal. I created with 3D LUT combine tool (colorizer.net) a Fuji deLOG -1 stop and another - 2 stop. these LUTs are to get a correct REC 709 image when I ETTR the FLOG on a low-contrast scene. But these LUTs are 3x65 and they don't work on my monitor. Do you have an idea to do this? You can use LUTCalc to generate 17^3 LUT sets with exposure compensation directly. Or Photoshop CC can downconvert LUTs to various resolution. Link to comment Share on other sites More sharing options...
BrunoCH Posted January 20, 2019 Author Share Posted January 20, 2019 1 hour ago, androidlad said: You can use LUTCalc to generate 17^3 LUT sets with exposure compensation directly. Or Photoshop CC can downconvert LUTs to various resolution. I had the same idea. But something is buggy. I don't know if it's LUTCalc or the monitor (The LUTs seem to work correctly in FCPX). The LUTs with exposure compensation -2 and -3 stops work perfectly. The LUT deLOG and LUT exposure compensation -1 produce false colors in the highlights. I tried everything for hours I dropped. https://drive.google.com/file/d/1LZMwjus41s9pEpzNwpJ9UfiBpl5C5h25/view?usp=sharing I don't have photoshop. There is also this solution but too complicated for me. http://opensource.mikrosimage.eu/ColorPipe-tools/LUTLab/LUT_to_LUT/ I hope the kaisen firmware add downconvert high precision LUT to 17^3. Link to comment Share on other sites More sharing options...
Adam Kuźniar Posted January 23, 2019 Share Posted January 23, 2019 a bit off topic but how is the monitor in general? Anything you specifically like or dislike about it? I'm looking into a affordable monitor for my G80 and the main reason why I want to pick this one up is for LUT monitoring Link to comment Share on other sites More sharing options...
androidlad Posted January 23, 2019 Share Posted January 23, 2019 4 hours ago, Adam Kuźniar said: a bit off topic but how is the monitor in general? Anything you specifically like or dislike about it? I'm looking into a affordable monitor for my G80 and the main reason why I want to pick this one up is for LUT monitoring It's the best non-high brightness monitor out there. Period. Link to comment Share on other sites More sharing options...
BrunoCH Posted January 23, 2019 Author Share Posted January 23, 2019 11 hours ago, Adam Kuźniar said: a bit off topic but how is the monitor in general? Anything you specifically like or dislike about it? I'm looking into a affordable monitor for my G80 and the main reason why I want to pick this one up is for LUT monitoring I really like the layout scene organization with 8 possible tools by scene. I create a scene with waveform (very good, very fine) and histogram. And a scene with false color. This 2 scenes for exposure. And I create an another scene with a deLOG LUT for visualisation. I really like the peaking tool (not focus peaking). Peaking looks like a kind of oversharp on the focus part. It is very effective to help focus. There are many deLOG LUT installed, as well as a lot of faslecolor for the main existing LOGs. And also the possibility to put 16 LUT by SD card . Unfortunately these users LUT are in 17x17x17. And it limits the use. Link to comment Share on other sites More sharing options...
BrunoCH Posted January 28, 2019 Author Share Posted January 28, 2019 After more time with LUTCalc, I understand better this app and I found a better way to create the LUTs I wanted and everything worked fine. I created a 17^3 LUT based on the Fuji LUT deLOG WDR and also 3 versions of this LUT going down one stop each time. Everything works as I want. Very good monitor for the price. Great application (3.49Euros Mac version or free version online). Link to comment Share on other sites More sharing options...
Attila Bakos Posted February 13, 2019 Share Posted February 13, 2019 Does this monitor have RGB parade? Link to comment Share on other sites More sharing options...
BrunoCH Posted February 13, 2019 Author Share Posted February 13, 2019 Yes the waweform has three options : Luma, RGB, parade. swit 55 parade.mov Attila Bakos 1 Link to comment Share on other sites More sharing options...
