HockeyFan12 Posted January 30, 2019 Share Posted January 30, 2019 The Ronin-M is just so... big. Anyone tried either of these combinations out? For geurilla-style single operator work. I'm shooting a spec ad now with a C200 handheld and I like the raw image (not crazy about the price or anything to do with the 8 bit options, which would be fine at half the price) but it could be steadier. I can't fit a Ronin-M, C200, and lenses in a backpack. I'd like something I could fit in a backpack and balance quickly. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted January 30, 2019 Share Posted January 30, 2019 Just now, HockeyFan12 said: The Ronin-M is just so... big. Anyone tried either of these combinations out? For geurilla-style single operator work. Depends on your lens choice Link to comment Share on other sites More sharing options...
HockeyFan12 Posted January 30, 2019 Author Share Posted January 30, 2019 Just now, thebrothersthre3 said: Depends on your lens choice Good point! Ideally, Sigma 18-35mm f1.8. But Canon pancakes are an option, too. I don't even think I could fit it on a Ronin-M with the Sigma, that lens is heavy. Link to comment Share on other sites More sharing options...
mercer Posted January 30, 2019 Share Posted January 30, 2019 Did you buy a C200 or rent it? Link to comment Share on other sites More sharing options...
webrunner5 Posted January 30, 2019 Share Posted January 30, 2019 If you can live with f2.8 lenses there are a Ton of Canon EF, EF-S lenses in that range. f1.8, well not so much. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted January 30, 2019 Super Members Share Posted January 30, 2019 This is a fairly comprehensive run through of setup and sample footage from it. He gets some heat in the comments about the footage being in slow motion and not using a heavier lens so make sure you check out Parts 2 and 3 from his channel where he addresses both of those with more setup and footage. My feeling from this and other videos is that it struggles without additional stabilisation, through at least using handles (which he adds in Part 3) or without an EasyRig or vest/arm combo that I've seen in some others. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted January 30, 2019 Share Posted January 30, 2019 Looks super top heavy. webrunner5 1 Link to comment Share on other sites More sharing options...
webrunner5 Posted January 30, 2019 Share Posted January 30, 2019 Hell just use a Zenmuse X5R on a Osmo handle. Even has Raw. Crazy stuff. Link to comment Share on other sites More sharing options...
DBounce Posted January 30, 2019 Share Posted January 30, 2019 It will work, but it will not balance 100%. That's ok because the Ronin S has powerful motors... so close enough will work fine. The overall weight is going to be an issue. For this reason I recommend picking up a glidecam vest and arm. They make an accessory that can attach to the bottom of the Ronin S. With this setup, weight becomes a non-issue. Granted, this does add extra bulk. 1 hour ago, webrunner5 said: Hell just use a Zenmuse X5R on a Osmo handle. Even has Raw. Crazy stuff. Zenmuse X5R is no C200. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted January 30, 2019 Share Posted January 30, 2019 43 minutes ago, DBounce said: It will work, but it will not balance 100%. That's ok because the Ronin S has powerful motors... so close enough will work fine. The overall weight is going to be an issue. For this reason I recommend picking up a glidecam vest and arm. They make an accessory that can attach to the bottom of the Ronin S. With this setup, weight becomes a non-issue. Granted, this does add extra bulk. Zenmuse X5R is no C200. Kind of gets away from the whole geurilla-style mindset. Might be worth investing in a small cam to fly on a gimbal, lots of options these days. Link to comment Share on other sites More sharing options...
HockeyFan12 Posted January 30, 2019 Author Share Posted January 30, 2019 Thanks everyone. The YouTube footage doesn't look very good to me, and that's too big a rig to carry around and looks hard to balance. I think I'll stick with handheld for shooting inserts and stuff. 2 hours ago, webrunner5 said: Hell just use a Zenmuse X5R on a Osmo handle. Even has Raw. Crazy stuff. That might be the best option for me. I'm not sure how good the autofocus is, but if it were more affordable and the autofocus were any good that would be pretty amazing. 9 minutes ago, thebrothersthre3 said: Kind of gets away from the whole geurilla-style mindset. Might be worth investing in a small cam to fly on a gimbal, lots of options these days. Yeah, agreed. For this project I'll just stick to handheld, and I agree the above rig is too unwieldy to be practical, but I don't think a Ronin- M (which seems to stabilize better) is quite portable enough. webrunner5 1 Link to comment Share on other sites More sharing options...
mercer Posted January 30, 2019 Share Posted January 30, 2019 Canon’s IS Lenses are pretty damn good handheld... the 35mm f/2 hasn’t failed me yet. BenEricson 1 Link to comment Share on other sites More sharing options...
BenEricson Posted January 31, 2019 Share Posted January 31, 2019 6 hours ago, mercer said: Canon’s IS Lenses are pretty damn good handheld... the 35mm f/2 hasn’t failed me yet. Same here. 35mm F2 and the 24-105 or 100mm Macro IS if you’re indoors. Link to comment Share on other sites More sharing options...
zerocool22 Posted February 3, 2019 Share Posted February 3, 2019 I would say get the original ronin, its much smoother and can hold heavier loads. (I owned all 3) Link to comment Share on other sites More sharing options...
