thephoenix Posted March 19, 2019 Share Posted March 19, 2019 1 hour ago, Stathman said: Correct me if I'm wrong, i think the correct way to do it is to use the preferred "HLG to xxx Lut" as a 3d output lut so any further corrections happening before the lut is applied to the image. actually it is wrong. color magement will convert to any output you want and you can change it when you want and rcm is non destructive. Link to comment Share on other sites More sharing options...
Stathman Posted March 19, 2019 Share Posted March 19, 2019 2 hours ago, thephoenix said: actually it is wrong. color magement will convert to any output you want and you can change it when you want and rcm is non destructive. Yes, of course you can use rcm. I was just following the previews posts and my point was about the correct way to apply the lut. You can use REC.2100 HLG as an input in rcm. thephoenix 1 Link to comment Share on other sites More sharing options...
MeanRevert Posted March 19, 2019 Share Posted March 19, 2019 5 hours ago, Stathman said: https://www.sendspace.com/file/iemw3r You can create it yourself though, its not that difficult. LUTCalc is a nice tool. Hi Stathman, Could you also please put up the 'LUTCalc HLG Rec709 LUT'? Thank you! thephoenix 1 Link to comment Share on other sites More sharing options...
Stathman Posted March 19, 2019 Share Posted March 19, 2019 Here you go! https://www.sendspace.com/file/kh0lgf thephoenix 1 Link to comment Share on other sites More sharing options...
thephoenix Posted March 19, 2019 Share Posted March 19, 2019 fyi https://www.fujirumors.com/exif-video-resolved-dr-adds-fujifilm-support-for-exif-metadata-import-in-davinci-resolve/ Link to comment Share on other sites More sharing options...
thephoenix Posted March 20, 2019 Share Posted March 20, 2019 23 hours ago, thephoenix said: fyi https://www.fujirumors.com/exif-video-resolved-dr-adds-fujifilm-support-for-exif-metadata-import-in-davinci-resolve/ anyone tried ? Link to comment Share on other sites More sharing options...
thephoenix Posted April 1, 2019 Share Posted April 1, 2019 how do you guys handle hlg with premiere ? got some footage on my ninja v shot with the xt3 hlg, premiere tells me it is 8bit and in scopes i cannot get the full range even with higlights set at max Link to comment Share on other sites More sharing options...
kepache Posted April 4, 2019 Share Posted April 4, 2019 what is the exact workflow here though? i just import my HLG footage in final cut, and then simply drop that alexa x2 lut on it and grade it from there? or do i have to tell final cut to interpret the footage in some particular way blabla Link to comment Share on other sites More sharing options...
Wed Posted April 8, 2019 Share Posted April 8, 2019 On 4/4/2019 at 11:01 AM, kepache said: what is the exact workflow here though? i just import my HLG footage in final cut, and then simply drop that alexa x2 lut on it and grade it from there? or do i have to tell final cut to interpret the footage in some particular way blabla HLG is Rec2020 it has to be resolved to Rec709 at some point unless only going to be seen on a TV that can resolve HDR10. FCPX has a default custom lut plugin that can do just that in a Rec709 Library. Pop it on your footage and choose Rec2020 input and Rec709 output...to boot you can add a lut if you want to or just let the plug resolve the color space for you. webrunner5 1 Link to comment Share on other sites More sharing options...
kepache Posted April 9, 2019 Share Posted April 9, 2019 13 hours ago, Wed said: HLG is Rec2020 it has to be resolved to Rec709 at some point unless only going to be seen on a TV that can resolve HDR10. FCPX has a default custom lut plugin that can do just that in a Rec709 Library. Pop it on your footage and choose Rec2020 input and Rec709 output...to boot you can add a lut if you want to or just let the plug resolve the color space for you. thanks! Link to comment Share on other sites More sharing options...
Malvix Posted April 15, 2019 Share Posted April 15, 2019 First of all, thank you for sharing your results! I'm just starting out with video, could you please share the LUT that you used for the shot titled "HLG with Alexa LUT generated by LUTCalc, no grading, WB 5300K, Shift 0"? My results look vastly different from what you are getting, I'm not sure what I'm inputting wrong in LUTCalc. I'm using Resolve. Link to comment Share on other sites More sharing options...
Ike Posted May 1, 2019 Share Posted May 1, 2019 Stathman, thanks for sharing your workflow with the custom LUTs. I'm curious as to why nobody is keeping the gamma fixed in HLG (without transform) and just remapping the gamut to Rec.709. When using the LUTs shared on here I found myself pulling the luma curve way down to get a correct exposure and gamma. I then created a new LUT that transforms the gamut from Rec2100 to Rec709 but keeps the gamma as Rec2100 HLG (no transform). With this new LUT I barely have to tweak the wheels to get the image looking neutral. Link to comment Share on other sites More sharing options...
No Parade Posted May 16, 2019 Share Posted May 16, 2019 Can anyone help with the exact steps to edit HLG Footage in FCPX? 1) Library set to Rec2020 2) Import Files recorded in 422 Pro Res 10bit Fujifilm Flog F.Gamut of the NINJA V in FCPX (They show up as Rec709 files in the infobox window, what is strange / The internal recorded files are displayed as Rec2020 HLG in the infobox box in the right corner) 3) And then how to proceed?! Thank you! Link to comment Share on other sites More sharing options...
redepicguy Posted July 24, 2019 Share Posted July 24, 2019 What are you guys setting your zebras to when shooting HLG? Link to comment Share on other sites More sharing options...
thephoenix Posted July 25, 2019 Share Posted July 25, 2019 6 hours ago, redepicguy said: What are you guys setting your zebras to when shooting HLG? ? funny, question seems familiar, you should have copied paste my question how do you guys expose with the XT3 for hlg ? any of you use ETTR ? if yes how do you work ? zebras or histogram ? how should zebras be set ? Link to comment Share on other sites More sharing options...
thephoenix Posted August 2, 2019 Share Posted August 2, 2019 well i did a quick test setting zebra to 100% then going to the limit of the 100 using the nd filter and then ETTR. did the same with 95 and 90% but got more details in the shade with 100 and i keep the highlights ok, so as highlights are not clipped in resolve and got details in the shadows i think i am gonna work like that for the next projects. Link to comment Share on other sites More sharing options...
Mackeral_Fillet Posted November 23, 2019 Share Posted November 23, 2019 On 5/16/2019 at 1:21 PM, No Parade said: Can anyone help with the exact steps to edit HLG Footage in FCPX? 1) Library set to Rec2020 2) Import Files recorded in 422 Pro Res 10bit Fujifilm Flog F.Gamut of the NINJA V in FCPX (They show up as Rec709 files in the infobox window, what is strange / The internal recorded files are displayed as Rec2020 HLG in the infobox box in the right corner) 3) And then how to proceed?! Thank you! Did you ever get this workflow? I use FCPX also and would like to understand workflow. Link to comment Share on other sites More sharing options...
Marin Posted December 17, 2019 Share Posted December 17, 2019 Can someone put F-log to Alexa lut? I don't use HLG and can't find one for F-log. Thanks! Link to comment Share on other sites More sharing options...
heart0less Posted December 17, 2019 Share Posted December 17, 2019 This one seems pretty nice, but I have my doubts about it. It's more of a look LUT than a proper conversion LUT. https://sellfy.com/p/lhny3g/ Link to comment Share on other sites More sharing options...
KnightsFan Posted December 17, 2019 Share Posted December 17, 2019 1 hour ago, Marin said: Can someone put F-log to Alexa lut? I don't use HLG and can't find one for F-log. Thanks! You can use LUTcalc to make one https://cameramanben.github.io/LUTCalc/LUTCalc/index.html If you use Resolve, you can use a CST node, which should have slightly better results than a LUT. They supposedly added F-Log support in version 16.1 (I'm still on 16.0 so I can't confirm firsthand). Link to comment Share on other sites More sharing options...
