Marin Posted December 17, 2019 Share Posted December 17, 2019 16 minutes ago, KnightsFan said: You can use LUTcalc to make one https://cameramanben.github.io/LUTCalc/LUTCalc/index.html If you use Resolve, you can use a CST node, which should have slightly better results than a LUT. They supposedly added F-Log support in version 16.1 (I'm still on 16.0 so I can't confirm firsthand). I'm new to LutCalc so don't know how to set it up. I use Premiere Pro. Link to comment Share on other sites More sharing options...
KnightsFan Posted December 17, 2019 Share Posted December 17, 2019 19 minutes ago, Marin said: I'm new to LutCalc so don't know how to set it up. I use Premiere Pro. LutCalc generates LUTs based on the difference between the color spaces you select in the drop downs. You specify an "in" and an "out" and it'll generate a LUT that would transform from one to the other. All you need is to know what gamma and gamut you are coming from (in your case, F-Log gamma and F-Log Gamut) and what you want to put it into. There are several Arri options, I'm not sure which one you want. You would enter this information on the left where it has Rec (in) and Out dropdowns. If you want a straight mathematical conversion, you can uncheck customization. You also probably want to leave the camera as generic and stop correction at 0. Then on the right you can set up the LUT file's options. You'd probably want a 3D lut, 65x65x65, in .cube format. I would use the largest range, and leave it unclipped. I'm not an expert, I've just used it once or twice in the past, so just play around with it. There are some how-to-guides and info on the main page as well that might be interesting https://cameramanben.github.io/LUTCalc/ Geoff CB 1 Link to comment Share on other sites More sharing options...
Marin Posted December 18, 2019 Share Posted December 18, 2019 13 hours ago, KnightsFan said: LutCalc generates LUTs based on the difference between the color spaces you select in the drop downs. You specify an "in" and an "out" and it'll generate a LUT that would transform from one to the other. All you need is to know what gamma and gamut you are coming from (in your case, F-Log gamma and F-Log Gamut) and what you want to put it into. There are several Arri options, I'm not sure which one you want. You would enter this information on the left where it has Rec (in) and Out dropdowns. If you want a straight mathematical conversion, you can uncheck customization. You also probably want to leave the camera as generic and stop correction at 0. Then on the right you can set up the LUT file's options. You'd probably want a 3D lut, 65x65x65, in .cube format. I would use the largest range, and leave it unclipped. I'm not an expert, I've just used it once or twice in the past, so just play around with it. There are some how-to-guides and info on the main page as well that might be interesting https://cameramanben.github.io/LUTCalc/ will try! thanks! ? Link to comment Share on other sites More sharing options...
phoberus Posted May 18, 2020 Share Posted May 18, 2020 Hey guys. Do we need to activate "Display Colourspace Converter" and covert it from 2100 to 709 or does LUTCalc convert it anyway, if we set HLG as an input and Alexa-X2 as the output? Do you choose the Alexa-X-2 gamma because it looks good without processing or because it is easy to grade? Someone figgured in the meantime better settings out to convert f-log or hlg to a nice looking rec709? Link to comment Share on other sites More sharing options...
phoberus Posted May 26, 2020 Share Posted May 26, 2020 @androidlad I also tested a little bit and turned customisation off (see post above). For my taste and my test shots i did, the colors were better in Amira709. Did you tested this Gamma too or what do you think about it? The rest in my screenshot is good, right? Link to comment Share on other sites More sharing options...
