High quality movie camera for image analyses
Christoph460
Hi forum members,
I am in the need of your help, since I got kinda stuck in searching a camera with some specific requirements and would be more than happy if you can give me some advice here.
Use-case scenario
  • I want to record labels, which are printed and will be transported via a conveyor belt.
Requirements
  •  high quality video stream, which means either a raw stream or almost no compression with artifacts/blurring
    • internal or external encoding possible
  • >=60fps
  • resolution >= Full HD (1920x1080px)
  • 24/7 recording
  • small case
  • no build in display needed
  • shutter speed > 1/2000s
Current Situation
  • I have for testing a Black Magic Micro Cinema Studio 4k camera in house, which delivers an uncompressed raw stream (good), but has a maximum shutter speed of 1/2000s. And this is the current weakness.
  • I came across the Z Cam E2, which sounds from the technical specs really nice. The quality of the encoded stream has to be tested.
Your Help
  • Do you know any alternative cameras which would fulfill these requirements, but I was not capable to find in the large wide web? Do you have already experience with the Z-Cam E2
If there is anything unclear or you have some further input here for me, I would be happy to get your advice
best Christoph
