mirekti Posted March 3, 2019 Share Posted March 3, 2019 Is there anyone using one of these monitors as a reference monitor? I was thinking of hooking it up with Intensity Pro 4k from BlackMagic over HDMI. Thanks and cheers!!! Link to comment Share on other sites More sharing options...
androidlad Posted March 3, 2019 Share Posted March 3, 2019 Yes but it must be calibrated with an X-Rite i1 Display Pro via its hardware 3D LUT slot. Link to comment Share on other sites More sharing options...
mirekti Posted March 3, 2019 Author Share Posted March 3, 2019 19 minutes ago, androidlad said: Yes but it must be calibrated with an X-Rite i1 Display Pro via its hardware 3D LUT slot. I do have i1 Display Pro so that’s not an issue. I saw there’s also SW series which is aimed to photographers, and these PV to videographers. Became intrigued by PV series after watching this Which one you have? Link to comment Share on other sites More sharing options...
Kisaha Posted March 3, 2019 Share Posted March 3, 2019 This is 1200€ in my country. Certainly interesting, a bit over my budget. I will be choosing for a new 4K monitor (30+ inches) the next months. Does anyone has any other suggestion? Especially at the 999€ limit?! Link to comment Share on other sites More sharing options...
Rinad Amir Posted March 4, 2019 Share Posted March 4, 2019 I have Pv3200Pt my first 4k 10bit monitor Compliments Gh5s with Atomos I will post some pics when i get home) mirekti 1 Link to comment Share on other sites More sharing options...
Rinad Amir Posted March 4, 2019 Share Posted March 4, 2019 As promised webrunner5, mirekti and Vision 3 Link to comment Share on other sites More sharing options...
mirekti Posted March 4, 2019 Author Share Posted March 4, 2019 32 minutes ago, Rinad Amir said: As promised Nice. I am not sure if I fully understand Benq's line. Their "photographer" line also covers AdobeRGB. When I compare it to their "videographer" line, it looks the same, but with more color space. I mean, I don't see that PV line has something that SW doesn't, and it is better for video compared to SW line. ? At the moment it's either the one you have or SW271. SW271 is a bit smaller, but it should be enough as it will only be used as a reference monitor connected via BM's Intensity Pro 4k so 32 might actually be an overkill. Link to comment Share on other sites More sharing options...
Rinad Amir Posted March 4, 2019 Share Posted March 4, 2019 17 minutes ago, mirekti said: Nice. I am not sure if I fully understand Benq's line. Their "photographer" line also covers AdobeRGB. When I compare it to their "videographer" line, it looks the same, but with more color space. I mean, I don't see that PV line has something that SW doesn't, and it is better for video compared to SW line. ? At the moment it's either the one you have or SW271. SW271 is a bit smaller, but it should be enough as it will only be used as a reference monitor connected via BM's Intensity Pro 4k so 32 might actually be an overkill. Thanks man ,yah i was in same boat as you man but after reading couple threads on reddit lol and watching Andrey lebrov video above i made up my mind ? Which ever one you pick u not gona be disappointed also tip: make sure to get X-rite i1 Display Pro Link to comment Share on other sites More sharing options...
Zak Forsman Posted March 4, 2019 Share Posted March 4, 2019 I've got the BenQ PV270. It's great for a home color grading setup. Something to note, Blackmagic products (I have the Decklink Mini Monitor 4K) see that it isn't a 4K monitor and reduce resolution to HD, regardless of your settings. Meahmut 1 Link to comment Share on other sites More sharing options...
webrunner5 Posted March 4, 2019 Share Posted March 4, 2019 8 minutes ago, Zak Forsman said: I've got the BenQ PV270. It's great for a home color grading setup. Something to note, Blackmagic products (I have the Decklink Mini Monitor 4K) see that it isn't a 4K monitor and reduce resolution to HD, regardless of your settings. It might be like my HP monitor. If you use HDMI it is only HD. I Have to use the DisplayPort to get 2K out of mine. Mine is a 2K monitor tops. thephoenix 1 Link to comment Share on other sites More sharing options...
liork Posted March 4, 2019 Share Posted March 4, 2019 5 hours ago, mirekti said: Nice. I am not sure if I fully understand Benq's line. Their "photographer" line also covers AdobeRGB. When I compare it to their "videographer" line, it looks the same, but with more color space. I mean, I don't see that PV line has something that SW doesn't, and it is better for video compared to SW line. ? At the moment it's either the one you have or SW271. SW271 is a bit smaller, but it should be enough as it will only be used as a reference monitor connected via BM's Intensity Pro 4k so 32 might actually be an overkill. The 3200 model does not support DCI P3 which is a shame for this price and the HDMI is only 1.4 verson = 30Hz. This one is nice: https://www.lg.com/us/monitors/lg-32UD99-W-4k-uhd-led-monitor Kisaha 1 Link to comment Share on other sites More sharing options...
mirekti Posted March 4, 2019 Author Share Posted March 4, 2019 1 hour ago, Zak Forsman said: Something to note, Blackmagic products (I have the Decklink Mini Monitor 4K) see that it isn't a 4K monitor and reduce resolution to HD, regardless of your settings. I had just placed an order for SW271, and then read the above. Oh man, there's always something. Do you know why it didn't recognize it as a 4k monitor? I use Intensity Pro 4k. Link to comment Share on other sites More sharing options...
webrunner5 Posted March 4, 2019 Share Posted March 4, 2019 Maybe it is something with HDMI not the latest version? Just best to use the DisplayPort which the Decklink Doesn't have.. "You can connect the monitors to a PC or Mac via one of the HDMI 1.4, DisplayPort 1.2 or mini DisplayPort 1.2 ports. However, be aware that HDMI 1.4 does not support 3840x2160 at 60 Hz, which is required for the 32” monitor." From this article. https://www.tomshardware.com/reviews/benq-pv3200pt-32-inch-uhd-pro-monitor,4605-3.html And why do you even Need the BMD Decklink when every decent video card or laptop has a DisplyPort or Mini DP in them?? HDMI stuff is total shit for data transfer rates! Link to comment Share on other sites More sharing options...
mirekti Posted March 4, 2019 Author Share Posted March 4, 2019 7 minutes ago, webrunner5 said: Just best to use the DisplayPort. I cannot, I am using BlackMagic Intensity Pro 4k. It has HDMI 1.4a SW271 has HDMI 2.0 and from Tom's Hardware -> Correct signal handling for all formats https://www.tomshardware.com/reviews/benq-sw271-27-inch-professional-monitor,5785-7.html So if I keep my timeline to 24fps it might work after all. Link to comment Share on other sites More sharing options...
webrunner5 Posted March 4, 2019 Share Posted March 4, 2019 Man those things have been around for 10 years or more. Why do you even need it in this day and age? Those things were invented for the music industry for synthesizers and software mixers. I had some of them F ing years ago. Just hook the damn thing into your video card. Or is your video card 10 years or older? Link to comment Share on other sites More sharing options...
mirekti Posted March 4, 2019 Author Share Posted March 4, 2019 2 minutes ago, webrunner5 said: Why do you even need it in this day and age? Ask that Black Magic, they have come up with the sw configuration in which you need to use an external reference monitor. Link to comment Share on other sites More sharing options...
webrunner5 Posted March 4, 2019 Share Posted March 4, 2019 For what BMD program, Resolve? Resolve doesn't give a rats ass what monitor you are using. If you have the BMD SDI one I can see that but, just a HDMI one, nah. Now they make a HDMI one with breakout cables, but that is still more an audio thing than video. Link to comment Share on other sites More sharing options...
mirekti Posted March 4, 2019 Author Share Posted March 4, 2019 2 minutes ago, webrunner5 said: For what BMD program, Resolve? Yes, I am using LG 38WK95C-W as my main monitor, and that's fine. But in Resolve if you wanted to enable Monitoring (full screen preview on another monitor) I had to buy the card. Has that changed? Basically, on top of LG I have been using some old Dell Ultrasharp which started giving up, and it needs to get replaced. Link to comment Share on other sites More sharing options...
webrunner5 Posted March 4, 2019 Share Posted March 4, 2019 Well if your video card has 2 inputs it can support 2 monitors at the same time. You don't Need 2 video cards to do that. Not all video cards can do that though. Link to comment Share on other sites More sharing options...
Kisaha Posted March 4, 2019 Share Posted March 4, 2019 1 hour ago, liork said: The 3200 model does not support DCI P3 which is a shame for this price and the HDMI is only 1.4 verson = 30Hz. This one is nice: https://www.lg.com/us/monitors/lg-32UD99-W-4k-uhd-led-monitor Great! And it is 300€ less in my country, isn't it a little old though? Do you have any other suggestions? Maybe a Dell or Samsung? I am reading a lot of QC issues for the BenQ. Link to comment Share on other sites More sharing options...
