BENQ PV270 and PV3200PT
mirekti
  On 3/19/2019 at 5:32 PM, androidlad said:
Set whatever value you find pleasing in Resolve. But you need to make sure you monitor is calibrated and maintained at 100nit.
Expand
sorry but why having monitors that can go to 300 nits if you can only go 100 ? i don't get it.
you mean i should lower the brightness of my monitor to 100 nits ? and how do i do that ?
Expand
Because there are colour space standards. And for BT.709, it's 100nit. For BT.2100 HDR, it's 1000nit.
PV270 can be calibrated by i1 Display Pro via 3D LUT.
Expand
ok. i do have the i1 and i use it to calibrate my monitor but i have no recall of nits value at any moment.
i just run the i1 profiler and do what it tells me to do.
Hi there
I have the PV 270 that is attached to a mac vis Ultrastudio mini monitor. Does any one know how I calibrate the monitor through the mini monitor as I understand it this affects the screen image. Or should I just connect direct to the HDMI output of the mac?
  On 3/20/2019 at 12:15 AM, neilmac said:
Hi there
Expand
Hardware calibration result is applied to all inputs on the monitor.
