dummy battery coupler bmpcc (1st version)
bristo
Hi everybody,
I have a question I try to deal with, related to my Pocket (old one not the 4k)
I have a juicebox battery which is great: http://juicebox.direct/product/jbmp-01/
However the bmpcc cable system is not convenient and I would like to use a dummy battery with my juicebox magic power.
I found this: https://www.aliexpress.com/snapshot/0.html?spm=a2g0s.9042647.0.0.d51436fa7hlRvs&orderId=99088514035971&productId=32825839201
But the jukebox battery output 12V and this dummy battery is made for 9V.
Is it gonna work?
Thanks for your help.
Thanks.
be carefull I think 12V is too much thru the battery compartment.
I just bought a used battery grip for canon 6D for 10 dollars. It works with 2 LPE6 battery. The grip with those batteries deliver 7.4V which is perfect to power the bmpcc with a dummy battery. I am going to modify it with the dummy battery to be able to have a battery grip for the pocket without using the 12V port on the side of the bmpcc. I will post some pictures.
This is what I want to do for the bmpcc (old one)
http://cheesycam.com/sony-a7s-powered-by-canon-5d-mark-ii-lp-e6-diy-modded-battery-grip/
Ok just tried it today:
-canon grip (cheap Chinese one) I bought for 10 euros, it accepts two canon lpe6 batteries (I already have)
-EN-EL6 dummy battery I ordered thru AliExpress for 7 euros.
A little bit of work, I am really bad at electronic, it is really easy, just connect properly the wires + and -, use some tap and foam...
I do not know why I did’nt do it before??
I can know use my beloved bmpcc as a runandgun camera with enough power and put it and out of my bag without having the power 12V wire on the side always annoying me.
9C034FED-E716-41E6-83A5-7AA722AB9BE2.thumb.jpeg.c94b62e9678fbb138cf68b4477b361a0.jpegEADD3D20-A1C4-46F6-A8AA-A9D2A9E9C3BD.thumb.jpeg.eb2e687bded059ab9332b2fefc48ada9.jpeg59677784-FE03-4875-B911-CDFAF7DD74E9.thumb.jpeg.287b4fc14cf466f7ca2172e0c9e25f9b.jpeg60198909-C195-4086-A7DE-2F80DC28AC64.thumb.jpeg.e46782b2a16fa3ebe6f5b07a103373c9.jpeg2855F027-E338-4F4F-A8E5-FA469AA51C25.thumb.jpeg.4bf480c33f3fbb21c15278a6064107ba.jpeg
Not completely tested how long I can run the bmpcc.
I would say (first impression) with the canon grip with 2 LPE6n I can run it in raw video recording for 1 hour and 15min , probably more. Two LPE6n should correspond to 5 or 6 normal bmpcc batteries.
The battery indicator on the bmpcc  when I use this homemade grip is not accurate, it does not work properly. With the two canon batteries fully charged it displays 45% on the bmpcc screen and with one batterie Fully charged  23%. However , like I said with 44% (which corresponds to 100% with two batteries) I can easily record in raw more than an hour and 15min.
I will take the bmpcc on a trip this weekend and see how it behaves.
I let you know.
