Waveform on external monitor with LUT (GH5) - any way to see non-lut waveform?
j169
This may be dumb... I have a GH5 (with v-log) and a Feelworld monitor. The monitor has a waveform (thankfully as the GH5 does not output its waveform over HDMI...).
If the GH5 doesn't output the custom LUT, then the waveform on the monitor is correct and useful.
But if I turn the custom LUT output over HDMI on, so I can see how the final image will look, the waveform now uses the LUT'd (?) image to base the waveform on, and that's no longer correct or useful - as I see it?
Am I wrong/right? Is there any good work arounds?
Thanks
