@yan_berthemy_photography Posted March 14, 2019 Share Posted March 14, 2019 Hi guys, I am looking to turn on IBIS for my manual lens (no connection between body and lens) I would like to use sensor stabilization but it does not work... only works with my native 25mm 1.7 panasonic lens... is this normal? any settings to change?? Link to comment Share on other sites More sharing options...
fuzzynormal Posted March 15, 2019 Share Posted March 15, 2019 3 hours ago, @yan_berthemy_photography said: Hi guys, I am looking to turn on IBIS for my manual lens (no connection between body and lens) I would like to use sensor stabilization but it does not work... only works with my native 25mm 1.7 panasonic lens... is this normal? any settings to change?? The Panasonic GF2 doesn't have IBIS. Link to comment Share on other sites More sharing options...
Super Members Mattias Burling Posted March 15, 2019 Super Members Share Posted March 15, 2019 7 hours ago, @yan_berthemy_photography said: Hi guys, I am looking to turn on IBIS for my manual lens (no connection between body and lens) I would like to use sensor stabilization but it does not work... only works with my native 25mm 1.7 panasonic lens... is this normal? any settings to change?? You might have to enable "shoot without a lens" in the menu. It's the same on all cameras basically. Link to comment Share on other sites More sharing options...
@yan_berthemy_photography Posted March 15, 2019 Author Share Posted March 15, 2019 14 hours ago, fuzzynormal said: The Panasonic GF2 doesn't have IBIS. here I speak about GH5 10 hours ago, Mattias Burling said: You might have to enable "shoot without a lens" in the menu. It's the same on all cameras basically. I can't find it in my GH5 @Mattias Burling Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted March 15, 2019 Super Members Share Posted March 15, 2019 1 hour ago, @yan_berthemy_photography said: here I speak about GH5 I can't find it in my GH5 @Mattias Burling With the GH5 it is not listed in the menu settings as it automatically switches on when no lens contacts are detected. Link to comment Share on other sites More sharing options...
tupp Posted March 15, 2019 Share Posted March 15, 2019 You have to set the focal length for each manual lens you use. I think that the GH5 asks you about the focal length when you turn on the camera. Link to comment Share on other sites More sharing options...
kye Posted March 16, 2019 Share Posted March 16, 2019 6 hours ago, tupp said: You have to set the focal length for each manual lens you use. I think that the GH5 asks you about the focal length when you turn on the camera. Yes, it does. IIRC it's also in the menu setting for stabilisation too, so you can set it there as well. I just turn the camera off then on again to change it Link to comment Share on other sites More sharing options...
