jgharding Posted June 21, 2013 Share Posted June 21, 2013 https://vimeo.com/67934251# http://19lights.com/wp/downloads/ I cannot test this, just FYI! Ratguity 1 Link to comment Share on other sites More sharing options...
jgharding Posted June 21, 2013 Author Share Posted June 21, 2013 Sorry, I can't amend the title, I meant 5D MKiii Link to comment Share on other sites More sharing options...
Jan Erik Ihle Posted June 21, 2013 Share Posted June 21, 2013 Hi, I just wondered if I am the only one having problem getting the ginger HDR plugin to work with the newest version of premiere (premiere CC) It works fine on adobe 6, but I can't import RAW in Premiere CC :/ Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 21, 2013 Administrators Share Posted June 21, 2013 Ginger is still in early stages. I cover it in the book. I am sure Cloud support will come but they have much more to do first. I tried Cloud yesterday and I see it has absolutely zero Cinema DNG support. They removed it altogether! Maybe they'll get it right for version 9 :) jgharding 1 Link to comment Share on other sites More sharing options...
Jan Erik Ihle Posted June 21, 2013 Share Posted June 21, 2013 Guess I'll stick to premiere 6 then .. Just alittle annoying as I just installed the cloud on my new laptop.. Most likely I won't be able to downgrade it to 6.. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted June 21, 2013 Administrators Share Posted June 21, 2013 You can run Cloud alongside CS6, it doesn't replace it. Link to comment Share on other sites More sharing options...
Jan Erik Ihle Posted June 21, 2013 Share Posted June 21, 2013 I just found out. I figured you couldn't download the older versions of the software once you had updated the creative cloud, but it was "hidden" in the "more information" tab, where you select software... Link to comment Share on other sites More sharing options...
nigelbb Posted June 22, 2013 Share Posted June 22, 2013 If you want to carry on using Encore for authoring DVDs & Blu-rays then you need to install Premiere Pro CS6 as they have not provided a CC version of Encore. It's a bummer because while you can still create the discs it means that you cannot use dynamic linking with PP CC so need to render out the finished files before importing into Encore. Link to comment Share on other sites More sharing options...
