elubes Posted June 21, 2013 Share Posted June 21, 2013 Hi, Had questions about flares. 1) Is there some technique to get a bunch of flares without seeing the actual source of the light or having it come anywhere near the frame? Are some of these DP's spotting a mini dedo/beam from far away who's sole purpose is just for flares? I think it was Punch Drunk Love where there's a lot of flare, but I don't remember seeing the source of the light in many of the shots. 2) And then the other thing is when I'm testing my own anamorphics, the source light just off frame produces an intense purple flare (almost opaque) at the frames edge in addition to the normal flares I'm used to. Where's that purple flare coming from? My anamorphic or the taking lens? I was using a Helios and a Kowa 16-S. Thanks so much! Erik Link to comment Share on other sites More sharing options...
Tito Ferradans Posted June 22, 2013 Share Posted June 22, 2013 2) And then the other thing is when I'm testing my own anamorphics, the source light just off frame produces an intense purple flare (almost opaque) at the frames edge in addition to the normal flares I'm used to. Where's that purple flare coming from? My anamorphic or the taking lens? I was using a Helios and a Kowa 16-S. Hey Erik! Kowas and Sankors are particularly famous for their vignetting when light sources are pointed directly inside it, because the inner parts of the body reflect the light and end up showing in the frame. (please, correct me if I'm wrong, but I remember reading about this on another thread, and getting results from personal testing) Link to comment Share on other sites More sharing options...
Caleb Genheimer Posted June 22, 2013 Share Posted June 22, 2013 Yes, you're right. My Kowa "reverse vignettes" (as I like to call it, because it is a vignette, but light white, not dark). If you don't like those, use a longer taking lens. But even Panavision anamorphics have those ghost vignettes. I actually kinda like them. Very distinct, and it creates a unique frame which is great for practicing unorthodox composition. As far as the purple flares are concerned, I haven't found any good answer anywhere, but I've experienced them as well, and not just with Anamorphic, but with most any lens at wide apertures. They're pretty particular in that the light source has to be in a fairly precise position in order for them to happen. As for flares from out of frame, you've just got to experiment. A bright, focused light is the most important part of the equation, but wide aperture and a slightly longer lens would both be good ideas as well, I think. Link to comment Share on other sites More sharing options...
Gábor Ember Posted June 22, 2013 Share Posted June 22, 2013 Use a longer taking lens so that the light source is not visible in the shot but the light can hit the front of the anamorphic. Use some bright LED flashlights and experiment, The white vignetting is apparent on the Sun Anamorphic too. Link to comment Share on other sites More sharing options...
JohnBarlow Posted June 22, 2013 Share Posted June 22, 2013 A powerful HID Flaslight will give good off camera flares Link to comment Share on other sites More sharing options...
elubes Posted June 23, 2013 Author Share Posted June 23, 2013 cool...thanks for the replies guys! Link to comment Share on other sites More sharing options...
