thephoenix Posted March 21, 2019 Share Posted March 21, 2019 hi all to be able to use my fuji xt3 with my moza air 2 i am looking for a micro usb to 2.5mm jack cable. i guess it does exist, maybe as a triggering cable for some camera brand but has a specific name. found the fuji rr80 cable that could be it but it is a bit long and has some kind of central thing that adds weight as i need short cable like 20cm http://www.reddotphoto.com.sg/jjc-2-5mm-male-to-fuji-rr-80-cable-k.html the other solution would be a short 3.5 to 2.5 jack as i have a mini usb to jack adapter from gopro but cannot find such a short cable. what i exactly need is that Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted March 21, 2019 Super Members Share Posted March 21, 2019 If it is an RR80 then this is a compatible one with a less prominent shell (which I'm presuming are for for the resistors) and a coiled cable which you should be able to cable tie up if you want it shorter. https://www.ebay.co.uk/itm/Cable-Met-K-Compatible-with-the-Remote-Release-Fujifilm-RR-80/352279060053?hash=item520577de55:g:peIAAOSwD~FbwLjF If you want to make it permanently shorter then just cut and splice after the housing like this thephoenix 1 Link to comment Share on other sites More sharing options...
thephoenix Posted March 21, 2019 Author Share Posted March 21, 2019 thanks how good is that seller... Postage to: Worldwide Excludes: United States, Australia, France, Germany, Italy, Spain, PO Box wrote him anyway to know if he ships to france as i hope this is a mistake, who doesn't ship to france or germany when you are in germany ?? Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted March 21, 2019 Super Members Share Posted March 21, 2019 14 minutes ago, thephoenix said: thanks how good is that seller... Postage to: Worldwide Excludes: United States, Australia, France, Germany, Italy, Spain, PO Box wrote him anyway to know if he ships to france as i hope this is a mistake, who doesn't ship to france or germany when you are in germany ?? This one is less picky about sending to his own country https://www.ebay.es/itm/Anschlusskabel-passt-zu-Fujifilm-HS50EXR-fur-Kabelausloser-Auslosekabel-RR-80A/272844853447?hash=item3f86d210c7:g:i2kAAOSwng9ZuEii Link to comment Share on other sites More sharing options...
