compensate /change exposure ... HOW?
toggen
Hi!
I have followed the setting suggestions from the GH2 - book,
but how do i compensate /change exposure when i use a manual lens,
i don´t want to change the aperture on the lens.
I really want to use the scroll wheel in the "display button menu"
+ - 3 steps, but it is greyed out..
Prob. a very easy thing this stuff, but please, help!
Thanks, T
Three things control exposure.  Aperture, Shutter Speed, and ISO.  Basic basic photography / videography.
So if you don't want to change Aperture you are left with 2 options.  And when shooting video you usually want to use the 180 degree rule, leaving your shutter speed 1/50th of a second (for 24p shooting) for optimal motion.
So you are now left with one option....iso!
The + - 3 EV options are greyed out for a reason.
If you are using a manual lens you have no option but to operate focus and aperture manually. If you mean you do not want to adjust the aperture then the only other methods are as already mentioned ISO or use a variable ND filter.
Cheers, Rob
[quote author=toggen link=topic=352.msg2150#msg2150 date=1330723239]
Got it. thanks to all!
Too bad,really - having to plunder around with filters..
[/quote]
...like every other professional shooting movies for hollywood?
It is part of film making.
Filters cut "some" sharpness but they are a needed accessory when controlling exposure or for creative flare or softening effects.  Heliopan make a good Variable ND filter for your lenses - costs around $250.
If you have a good matte box you can use 4x4 or larger filters and stack them quite easily.
Have fun!
