Andrew Doyle Posted June 24, 2013 Share Posted June 24, 2013 I just purchased a LOMO 35mm square front anamorphic with the original 35mm taking lens. I will have two LOMO prime lenses in 50mm and 75mm focal lengths arriving shortly. Will I be able to use either of these lenses as a taking lens? Can I have anamorphic 35mm, 50mm and 75mm just by replacing the taking lens and keeping the front 35mm anamorphic attachment? Link to comment Share on other sites More sharing options...
au8ust Posted June 24, 2013 Share Posted June 24, 2013 35mm squarefront usually has a lot of distortion than the one designed for 50/75. Although you can use 50/75 prime on 35mm anamorphic you'll get more distortion. Link to comment Share on other sites More sharing options...
Andrew Doyle Posted June 24, 2013 Author Share Posted June 24, 2013 Thanks for reply. I will give it a go once I get the LOMO primes. Link to comment Share on other sites More sharing options...
