Looking for a good stabilizer
Matthew Marshall
Im in need of some advice. I have a full Redrock UltraCage setup. Backplate everything and power distribution system connected to a V-Mount battery. Its heavy to say the least. I bought the Steadicam Merlin and body brace. Which worked with just the dslr, well even with the beginning parts of the ultracage. However with the full ultracage and battery it is far too heavy.
Im in need of a scale for sure, however does anyone have any suggestions for good heavy duty heavy camera stabilizers? Im concerned the Glidecam 4000 doesn't support the weight I need it to support.
Additional accessories on the camera
Marshall LCD
H4N Zoom
Sennheiser boom mic with blimp windscreen
Its all very heavy and most I can find only support 4-10 lbs
Ultracage setup
Ultracage
Ultracage backpack and v-mount battery attachment
Shoulder support (which I could very well remove without much effort that in itself is heavy)
MatteBox (id like to use this however i can remove it)
Id like one that i can just lock onto with a Manfrotto quick release plate whenever I need a steadicam shot and not have to take the whole ultracage apart just to do it.
Thanks in advance.
I have not and that's the issue. Don't have a scale anywhere. Gotta find one first and go from there. It looks like stabilizer sleds are the only option. However most for the weights I'm guessing at I.e over 10 lbs come with the vest and arm as well. Nothing separate.
Another option may be the Varizoom
http://www.amazon.com/Varizoom-Fully-Supported-Stabilizer-Camera/dp/B000MT1Q48/ref=sr_1_7?s=photo&ie=UTF8&qid=1372467166&sr=1-7&keywords=stabilizer+sled
By my estimate my camera weight is right within 10-20 so around 15 or so i'd think.
Just dont need the arm :\ I contacted Glidecam to see if they have an option however it looks like ill just have to waste money buying another vest and arm.
