FilmMan Posted June 29, 2013 Share Posted June 29, 2013 Here's another Low Cost Gyroscopic Camera Stabilizer. Not sure if this was posted. Cheers. http://makezine.com/2012/03/12/how-to-low-cost-gyroscopic-camera-stabilizer/ $529 US. Coming soon. Read this website. https://www.gyroscope.com/d.asp?product=GYROSTABILIZER Ratguity 1 Link to comment Share on other sites More sharing options...
FilmMan Posted June 29, 2013 Author Share Posted June 29, 2013 Me Bad. Here's the corrected price as today for a Built Model: $521.49 https://www.gyroscope.com/d.asp?product=GYROSTABILIZER Hand-held gyrostabilisers for binoculars and cameras have been around since the 1950’s and have been used extensively in the film industry as a means to stabilise the video footage. There are numerous scenarios where the camera is being buffeted causing unwanted blurring or shaking. In many cases gyrostabilizers enable shots that would otherwise be impossible. For example the chase scene in the forest from the film Return of the Jedi required an ultra-smooth shot as the cameraman walked/ran through the forest floor. The footage was then sped up giving the illusions of a fast smooth but intense chase scene. The concept is simple; A gyrostabiliser connected to camera gives stabilization resisting moving in given directions. Each gyrostabiliser unit provides stabilization on single axis, either pitch, yaw or roll depending how you choose to mount it. You can also stack multiple gyrostabilisers together providing stabilization on extra axis/axes. Fittings are built-in into the gyrostabilizer to mount two together for both pitch and yaw axis. So In other words it helps with twisting motions left/right and twisting up/down. If the roll axis needs to be stabilized too (rare) a third gyrostabilizer needs to be added (no mounts to do this can be provided at present). Until now the gyrostabilizers have inherently expensive and only affordable to serious professionals. Development of a lower cost gyrostabilizer is being finished. Many applications will require just one gyrostabilizer. Some two. You will have to consider what you need. I will describe some typical setups soon..... Reduces/stops camera shake where there is Pitch, Roll or yaw (1 axis per gyrostabilizer) Relativity quiet operation Reduces blurring Enables use of slower shutter speeds Can be used with binoculars Can work with most types of cameras, including SLR cameras Works with small/medium sized video cameras (can double up for large cameras) Ideal for use in Helicopters and Fixed wing aircraft Works with any vehicles not providing a complete smooth ride Can be used where bulky equipment cannot go Can be used wherever there is a problem with vibration or unwanted movement Could even be used with some RC aircraft and UAVs Stackable for easy 1 axis or 2 axis stabilization (pitch + yaw) 3 axis stabilization possible with your own mounting equipment Built in Camera mounts to connect to most cameras and video cameras Specification of the camera gyrostabilizer Size: H 91mm x W 156mm x L 72mm (excludes camera brackets) Weight: TBA Battery: 360g with over charge, discharge and circuit protection protection Battery size: 76 mm x 115 mm x 32 mm Battery life: up to 3 hours (with LED battery Fuel Gauge) Start up time: TBA dB: TBA Link to comment Share on other sites More sharing options...
mtheory Posted June 30, 2013 Share Posted June 30, 2013 Cool, how exactly does it work, you just mount it to the base of your camera and it's supposed to stabilize it? How do you mount two of them? Waiting for the videos. The site says these guys are sold out, - if this works as I want it to, I'll send my money NOW. Link to comment Share on other sites More sharing options...
FilmMan Posted July 1, 2013 Author Share Posted July 1, 2013 mtheory, we'll have to wait and see how the final version performs. There probably will be a lot more gyros popping up during the year. Cheers. Link to comment Share on other sites More sharing options...
Bruno Posted July 1, 2013 Share Posted July 1, 2013 http://nofilmschool.com/2013/06/affordable-gyrostabilizer-besteady-one-prices/ Link to comment Share on other sites More sharing options...
AaronChicago Posted July 1, 2013 Share Posted July 1, 2013 The Defy 3 axis gimbal is up for preorder next week: http://relentless.tv/blog/relentless-launches-product-defy-g2/ $2300 Link to comment Share on other sites More sharing options...
Paulio Posted July 1, 2013 Share Posted July 1, 2013 It's been said before but the tech behind these is going to be reproduced very shortly by manufactures in China and India. 2013 is going to be year of the gyro. I wouldn't drop $2300 on the first wave. Link to comment Share on other sites More sharing options...
silvertonesx24 Posted July 2, 2013 Share Posted July 2, 2013 It's been said before but the tech behind these is going to be reproduced very shortly by manufactures in China and India. 2013 is going to be year of the gyro. I wouldn't drop $2300 on the first wave. I wonder what the final settled price point will be. For me, I suppose I would like it to be under $1000 to be able to justify adding this to my gear. Link to comment Share on other sites More sharing options...
AaronChicago Posted July 2, 2013 Share Posted July 2, 2013 No doubt prices will drop, but I don't think $2300 is unreasonable. Good tripods, sliders, jibs cost as much or more. There are alot of precision technical components working in these things. I got to play with the Movi at Alex Buonos workshop and it's pretty impressive. He said that when they demo'd it to JJ Abrams, he had an intern try and recreate a shot from Star Trek that took an hour to set up and maneuver. The kid picked up the Movi and nailed it in one try. Link to comment Share on other sites More sharing options...
Steven Gehner Posted July 8, 2013 Share Posted July 8, 2013 Here is also a cheap version. I don't know if it's any good. http://www.ebay.com/itm/3-Axis-Camera-Gimbal-W-servos-Gyro-handle-gimbal-Stabilized-Mount-for-Movie-/141009954495 US $655.80 tosvus 1 Link to comment Share on other sites More sharing options...
