How do I get that "Canon" look?
acuriousman
What Panasonic (+hacks) gives the low-end shooter in resolution they take away in color. You will need some sort of LUT-based correction, but if all you've got is 8-bit 420 to work within it's going to be rough. The Panasonics don't offer Log gammas either iirc, and you might get in-camera sharpening/NR artifacts showing up too with too extreme a push.
The easiest and cheapest thing to do might be buying a 2nd hand Rebel T2i. You'll also get better DoF and low-light thrown in the package, and you can run Cinestyle on it for better DR. For all the complaining about Canon (some justified) the color is the best in the biz objectively and subjectively.
