androidlad Posted May 11, 2019 Share Posted May 11, 2019 2 hours ago, andjo said: Dynamic range on the full frame version looks very pleasing from this example F8 has the same pixel level DR as S6 and FUJI XT3 (~11EV) as they have the same 3.76um pixel design. But if we normalise the 8K footage from F8 to 4K, it'll have about 1EV cleaner shadow. Link to comment Share on other sites More sharing options...
AlexTrinder96 Posted May 11, 2019 Share Posted May 11, 2019 36 minutes ago, androidlad said: F8 has the same pixel level DR as S6 and FUJI XT3 (~11EV) as they have the same 3.76um pixel design. But if we normalise the 8K footage from F8 to 4K, it'll have about 1EV cleaner shadow. will the F6 be using the same/similar sensor as the Mavo LF? Link to comment Share on other sites More sharing options...
androidlad Posted May 11, 2019 Share Posted May 11, 2019 14 minutes ago, AlexTrinder96 said: will the F6 be using the same/similar sensor as the Mavo LF? They are indeed using the same sensor IMX410. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted May 11, 2019 Share Posted May 11, 2019 8 hours ago, androidlad said: F8 has the same pixel level DR as S6 and FUJI XT3 (~11EV) as they have the same 3.76um pixel design. But if we normalise the 8K footage from F8 to 4K, it'll have about 1EV cleaner shadow. Same dynamic range as Fuji XT3 video? Thats a bit disappointing. Link to comment Share on other sites More sharing options...
androidlad Posted May 11, 2019 Share Posted May 11, 2019 2 hours ago, thebrothersthre3 said: Same dynamic range as Fuji XT3 video? Thats a bit disappointing. Yes, but at 8K FF, you gotta look at it in totality. Link to comment Share on other sites More sharing options...
zerocool22 Posted May 11, 2019 Share Posted May 11, 2019 10 hours ago, androidlad said: They are indeed using the same sensor IMX410. Thats awesome! Hopefully they can implement a decent codec instead of h265. If I was Z Cam I would be knocking on blackmagics door for Braw. I downloaded a clip from the F6, but I could not push the image around like I wanted or way less room to play around with vs my ursa mini pro or even my pocket 4K at this point, seems they need to fix the curve on that cam still, also something weird going on with the noise in the camera(but its still all very alpha/beta, so they have some time to fix the problems). Link to comment Share on other sites More sharing options...
androidlad Posted May 11, 2019 Share Posted May 11, 2019 Just now, zerocool22 said: Thats awesome! Hopefully they can implement a decent codec instead of h265. If I was Z Cam I would be knocking on blackmagics door for Braw. I downloaded a clip from the F6, but I could not push the image around like I wanted or way less room to play around with vs my ursa mini pro or even my pocket 4K at this point, seems they need to fix the curve on that cam still, also something weird going on with the noise in the camera(but its still all very alpha/beta, so they have some time to fix the problems). They are working on Cineform RAW. Link to comment Share on other sites More sharing options...
zerocool22 Posted May 11, 2019 Share Posted May 11, 2019 Just now, androidlad said: They are working on Cineform RAW. I never worked with Cineform RAW, what are the compression rates at? I freaking love BRAW at 12:1 I know some people prefer cdng over braw. But I certainly don't, the sizes are too massive. Braw is offering RAW at even smaller files then prores can. Link to comment Share on other sites More sharing options...
KnightsFan Posted May 12, 2019 Share Posted May 12, 2019 1 hour ago, zerocool22 said: Hopefully they can implement a decent codec instead of h265 Last I heard, the S6, F6, and F8 will have H264, H265, ProRes, and a proprietary RAW format. ProRes would be pending Apple's approval (no reason it wouldnt be approved, it was for the E2 after all). Raw could be converted to Cineform raw in post using z cam's converter. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted May 12, 2019 Share Posted May 12, 2019 2 hours ago, zerocool22 said: Thats awesome! Hopefully they can implement a decent codec instead of h265. If I was Z Cam I would be knocking on blackmagics door for Braw. I downloaded a clip from the F6, but I could not push the image around like I wanted or way less room to play around with vs my ursa mini pro or even my pocket 4K at this point, seems they need to fix the curve on that cam still, also something weird going on with the noise in the camera(but its still all very alpha/beta, so they have some time to fix the problems). I'd expect prores like the E2 Link to comment Share on other sites More sharing options...
zerocool22 Posted May 12, 2019 Share Posted May 12, 2019 7 hours ago, KnightsFan said: Raw could be converted to Cineform raw in post using z cam's converter. This sucks major though... ZCAM if you are reading this, ask bm for braw and we all will be happy. [update] I just read that zcam cannot support braw because they own standard hdmi, which is not supported by braw. (well this is for external, what about interal though) Link to comment Share on other sites More sharing options...
IronFilm Posted May 12, 2019 Share Posted May 12, 2019 On 5/11/2019 at 2:34 PM, eatstoomuchjam said: Big things are happening! I just received my E2C which is the smaller budget version of the E2. It can shoot 4k at up to 30fps in ProRes and it costs only $800 (I got it for a little less due to early bird preorder)! I'll be doing some comparisons of it vs my bigger E2 tomorrow, hopefully. Also, for the full-size E2, Z Cam just released firmware 0.86 which, among many other nice improvements, adds 4kp160 (2.4:1 instead of 16:9). I hope to find something that is moving tomorrow to play with that as well. How is the dynamic range of the E2C? As that is one area on the spec sheet that the E2C performs below the E2 Link to comment Share on other sites More sharing options...
mercer Posted May 13, 2019 Share Posted May 13, 2019 On 5/10/2019 at 10:34 PM, eatstoomuchjam said: Big things are happening! I just received my E2C which is the smaller budget version of the E2. It can shoot 4k at up to 30fps in ProRes and it costs only $800 (I got it for a little less due to early bird preorder)! I'll be doing some comparisons of it vs my bigger E2 tomorrow, hopefully. Also, for the full-size E2, Z Cam just released firmware 0.86 which, among many other nice improvements, adds 4kp160 (2.4:1 instead of 16:9). I hope to find something that is moving tomorrow to play with that as well. Thanks for the update but where can you preorder the e2c? I can’t find it anywhere. Link to comment Share on other sites More sharing options...
DBounce Posted May 19, 2019 Share Posted May 19, 2019 I believe this might be the first footage from their new S35 6k camera... And perhaps more interestingly, footage from their new global shutter variant... the E2G Link to comment Share on other sites More sharing options...
zerocool22 Posted May 19, 2019 Share Posted May 19, 2019 1 hour ago, DBounce said: I believe this might be the first footage from their new S35 6k camera... And perhaps more interestingly, footage from their new global shutter variant... the E2G For me the F6 is the most interesting one (hoping to see a F6 vs mavo lf side by side soon). The e2g has very limited DR(this example also has a lot of dead pixels and some weird noise/grain going on, the noise problem is also present in the F6 video). Link to comment Share on other sites More sharing options...
DBounce Posted May 19, 2019 Share Posted May 19, 2019 @zerocool22 I watched it on my smartphone so I missed the detail. I'm going to rewatch on my LG Oled TV. Ok, now that I have viewed the footage on my HDR 4k TV, we'll it's not great. I think it's not ready for prime time. andrgl 1 Link to comment Share on other sites More sharing options...
Zak Forsman Posted May 19, 2019 Share Posted May 19, 2019 6 hours ago, DBounce said: I believe this might be the first footage from their new S35 6k camera... This is the Full Frame 6K camera. here's the breakdown of their cameras. E2 - M43 4K S6 - Super 35 6K F6 - Full Frame 6K F8 - Full Frame 8K DBounce and webrunner5 2 Link to comment Share on other sites More sharing options...
mercer Posted May 19, 2019 Share Posted May 19, 2019 1 hour ago, Zak Forsman said: This is the Full Frame 6K camera. here's the breakdown of their cameras. E2 - M43 4K S6 - Super 35 6K F6 - Full Frame 6K F8 - Full Frame 8K How do you like the E2? Also, have you heard anything about the E2C’s availability? webrunner5 1 Link to comment Share on other sites More sharing options...
IronFilm Posted May 20, 2019 Share Posted May 20, 2019 12 hours ago, DBounce said: I believe this might be the first footage from their new S35 6k camera... Gah, why does it have to be shaky handheld footage? Link to comment Share on other sites More sharing options...
zerocool22 Posted May 20, 2019 Share Posted May 20, 2019 Well it still in developing stages, but from the looks of it there is still quite some work to get it in the mavo lf range. Didnt knew it needed that much tweaking for each camera individual, as I understand a lot of people are getting good results with the zcam E2 4K. Link to comment Share on other sites More sharing options...
