thephoenix Posted September 13, 2019 Share Posted September 13, 2019 new 16.1b3 today and new bm raw 1.5 What's new in DaVinci Resolve 16.1 b3 • Support for the Clean Feed Viewer mode on the Fusion page • Support for additive compositing for ResolveFX Light Rays and ResolveFX Glow • Support for automatically enabling Use OFX alpha for ResolveFX Match Move and ResolveFX Drop Shadow • Support for encoding AVC Intra 50, 100 and 200 on DaVinci Resolve Studio • Ability to preserve video essence for faster rendering of DNxUncompressed clips without content changes • Improved representation of small cuts on the top timeline in the Cut page • Improved graticule and timecode display on timeline rulers • Improved sound library search with support for binary and wildcard searches • Addressed an issue where accessing the Media Pool option menu on a dual screen layout would sometimes cause a crash • Addressed an issue where deleting a marker in the top timeline in the Cut page would not work correctly • Addressed an issue where trimming a clip in the Cut page would sometimes not refresh the waveforms correctly • Addressed an issue where trimming or moving a clip in the Cut page would sometimes result in incorrect snapping behavior • Addressed an issue where scrubbing the playhead in the top timeline in the Cut page would sometimes result in incorrect snapping behavior • Addressed an issue where gaps for manually synced clips in the sync bin would not be loaded correctly when opening a project • Addressed an issue where converting in and out points to a duration marker would sometimes cause a crash • Addressed an issue where timeline regions with titles and generators would not show some burn-ins correctly • Addressed an issue where clicking next keyframe in the Edit timeline curves area would sometimes not work correctly when the retime curve was selected • Addressed an issue where transitions from some OpenFX plugins would not work correctly • Addressed an issue where auto arranging tools in the Fusion node editor would sometimes cause an overlap of nodes • Addressed an issue where saving Fusion preferences when viewing the 3D viewer would disable the lighting options in the 3D viewer • Addressed an issue where the rendering and playback of Alembic model files in Fusion page would sometimes cause a crash • Addressed an issue where moving viewer controls in a project using video field processing would cause a crash • Addressed an issue where encrypted DCTLs could not be opened in ResolveFX DCTL • Addressed an issue where control/command-dragging media in the Fairlight timeline would sometimes not add the first clip in selection • Addressed an issue where AudioFX favorites would not be loaded correctly across application restarts • Addressed an issue where playback of clips at a different sample rate would sometimes result in clicks • Addressed an issue where some video clips with embedded audio would sometimes not show audio waveforms • Addressed an issue where the combined waveform display on the source viewer would show incorrect profiles for clips with mismatched sample rates • Addressed an issue with different audio limiting behavior between the Fairlight and Edit pages with native audio on Windows systems • Addressed an issue where the audio I/O configuration would sometimes not be saved correctly • Addressed an issue where the Fairlight B-Chain Settings context menu would not work correctly if the application language was not set to English • Addressed an issue where undoing the addition of a track on the Fairlight timeline would result in hidden tracks getting unhidden • Addressed an issue where some H.264 clips would decode with corrupt thumbnails or as black frames on some Windows systems with AMD GPUs • Addressed an issue with decoding some MP3 files • Addressed an issue where decoding 6K BRAW clips while using CUDA processing on a multiple GPU system would sometimes result in an error • Addressed an issue where some uncompressed AVI clips would not be decoded with the correct frame rate • Addressed an issue where rendering a supplemental IMF would sometimes result in an error • Addressed an issue where the camera metadata for ARRI Quicktime clips would not be initialized correctly in the Media page • Addressed an issue where using media management to transcode clips to H.264 with multi-pass encoding would cause a crash on macOS systems • Addressed an issue where exporting a project with input sizing presets applied for clips and changing the preset in a newly imported project would sometimes cause a crash • General performance and stability improvements Link to comment Share on other sites More sharing options...
Mako Sports Posted September 13, 2019 Share Posted September 13, 2019 Braw is also officially supported in Avid and Premiere Pro CC now Geoff CB and ntblowz 2 Link to comment Share on other sites More sharing options...
thephoenix Posted September 13, 2019 Share Posted September 13, 2019 happy to have speedtest on pc now ntblowz and Emanuel 2 Link to comment Share on other sites More sharing options...
Geoff CB Posted September 13, 2019 Share Posted September 13, 2019 On 9/13/2019 at 10:35 AM, thephoenix said: happy to have speedtest on pc now Expand Finally! That is long overdue. Link to comment Share on other sites More sharing options...
kye Posted October 12, 2019 Share Posted October 12, 2019 This might be useful to some: deezid and Emanuel 1 1 Link to comment Share on other sites More sharing options...
Emanuel Posted March 6, 2020 Share Posted March 6, 2020 kye and cam1982 2 Link to comment Share on other sites More sharing options...
Devon Posted July 18, 2020 Share Posted July 18, 2020 Newb question here. After some reading, it sounds like I need to create a display LUT to monitor more accurately with my GUI monitor. To get as accurate as I can with a GUI display: I have a SPYDER colorimeter, and will use displayCAL to create the LUT. Once it's created, I should disable "Use Mac Display Color Profiles for Viewers" and use the LUT for output monitoring? Right? Or should I have "Use Mac Display Color Profiles for Viewers" ENABLED in combination with the display LUT? Link to comment Share on other sites More sharing options...
