IronFilm Posted April 23, 2019 Share Posted April 23, 2019 This here is even more impressive technology to deal with limiting than Zoom's F6 32bit files or the F8n's "look ahead limiters": http://jayrose.com/funny/PAPManual_April2014.pdf ? Link to comment Share on other sites More sharing options...
kye Posted April 23, 2019 Share Posted April 23, 2019 2 hours ago, IronFilm said: This here is even more impressive technology to deal with limiting than Zoom's F6 32bit files or the F8n's "look ahead limiters": http://jayrose.com/funny/PAPManual_April2014.pdf ? I have an idea. If you can get a sample unit to me then we can work together to work out how to connect it to a live stream of stock market prices.... IronFilm and Snowfun 2 Link to comment Share on other sites More sharing options...
Anaconda_ Posted May 29, 2019 Share Posted May 29, 2019 The test sample here is pretty amazing, and the explanation of how it works is also very interesting. I also like how it runs on NPF batteries as well as AA. Not sure on the menus though. Link to comment Share on other sites More sharing options...
thephoenix Posted May 29, 2019 Share Posted May 29, 2019 4 minutes ago, Anaconda_ said: The test sample here is pretty amazing, and the explanation of how it works is also very interesting. I also like how it runs on NPF batteries as well as AA. Not sure on the menus though. yep. i am nt a sound person but it sounds quite amazing. and it's tiny Link to comment Share on other sites More sharing options...
Anaconda_ Posted May 29, 2019 Share Posted May 29, 2019 1 minute ago, thephoenix said: yep. i am nt a sound person but it sounds quite amazing. and it's tiny My understanding is, you don't need to be with this. Plug everything in, press record and then get your levels right in post. (obviously not good working practice - at least try and get them right in the box) Link to comment Share on other sites More sharing options...
thephoenix Posted May 29, 2019 Share Posted May 29, 2019 7 minutes ago, Anaconda_ said: My understanding is, you don't need to be with this. Plug everything in, press record and then get your levels right in post. (obviously not good working practice - at least try and get them right in the box) sounds a bit simple but it looks like it. if it works that well the uses are endless ? for a reasonable price i find. looks like perfect for itw as it is tiny. don't know if it can be put under a camera cage. but sure accessories will come soon Link to comment Share on other sites More sharing options...
Anaconda_ Posted May 29, 2019 Share Posted May 29, 2019 56 minutes ago, thephoenix said: don't know if it can be put under a camera cage. but sure accessories will come soon There is already a bracket to mount it under a camera, but I'm not sure if it's included or an optional extra. It is definitely possible though. Great for panel discussions and multi-person interviews. Slight side-step, and not really related, but what I've started doing while recording live music though, is have all the instruments go into my recorder, then plug the Rode Wireless Go into the output and send the signal to my camera. It really makes it great for syncing after I've mixed the recordings, but also helps when playing back for the artist, so they can hear their performance better than they could with the in-cam mics. Mounting the recorder under the camera would provide the same end result, but will also limit your movements (should you want to move of course). Link to comment Share on other sites More sharing options...
IronFilm Posted May 29, 2019 Share Posted May 29, 2019 3 hours ago, Anaconda_ said: I also like how it runs on NPF batteries as well as AA. That is definitely a step in the right direction, like Sound Devices uses. 3 hours ago, Anaconda_ said: My understanding is, you don't need to be with this. Plug everything in, press record and then get your levels right in post. (obviously not good working practice - at least try and get them right in the box) NOOOOOOOOOOOOOOOOOOO Getting good sound is waaaaaaay more than just getting good levels! 1 hour ago, Boomboom said: … at 13:14 about the TC menu in Bluetooth mode… a hint: Timecode Systems. Ditch the box ! ? Nifty! Zoom has already paired with TCS before for their Ambisonics mic/recorder. https://jwsoundgroup.net/?app=core&module=system&controller=content&do=find&content_class=forums_Topic&content_id=33053&content_commentid=361111 Anaconda_ 1 Link to comment Share on other sites More sharing options...
Anaconda_ Posted May 29, 2019 Share Posted May 29, 2019 6 hours ago, IronFilm said: Getting good sound is waaaaaaay more than just getting good levels! Well sure, but things like mic selection and placement aren’t dependent on the recorder you use. Levels are highly dependent on the recorder, it’s preamps, built in limiter etc etc. all of which you can forget about with this... it seems . Link to comment Share on other sites More sharing options...
thephoenix Posted May 29, 2019 Share Posted May 29, 2019 at least seems like there is much more room for mistakes ? Link to comment Share on other sites More sharing options...
kye Posted May 30, 2019 Share Posted May 30, 2019 18 hours ago, thephoenix said: at least seems like there is much more room for mistakes ? Which is ALWAYS welcome in my book! thephoenix 1 Link to comment Share on other sites More sharing options...
Grimor Posted June 9, 2019 Share Posted June 9, 2019 Curtis review: thephoenix 1 Link to comment Share on other sites More sharing options...
webrunner5 Posted June 9, 2019 Share Posted June 9, 2019 Hmm, down vote, interesting. ? Link to comment Share on other sites More sharing options...
Emanuel Posted June 9, 2019 Share Posted June 9, 2019 Because it was already posted above in the same page... Link to comment Share on other sites More sharing options...
webrunner5 Posted June 9, 2019 Share Posted June 9, 2019 Seems pretty brutal for a long time contributor who does some cool stuff.. Link to comment Share on other sites More sharing options...
Emanuel Posted June 9, 2019 Share Posted June 9, 2019 I understand. I don't appreciate downvotes at all. Pretty coward stuff to be sincere. They might be banned for once IMO. I also approve your fair concern on topic now. Lack of personal consideration cannot be tolerated at any rate. It is not a matter of opinion, but decency actually. webrunner5 and sanveer 2 Link to comment Share on other sites More sharing options...
Grimor Posted June 9, 2019 Share Posted June 9, 2019 Lo siento, no volverá a ocurrir! Emanuel and webrunner5 2 Link to comment Share on other sites More sharing options...
sanveer Posted June 9, 2019 Share Posted June 9, 2019 38 minutes ago, Emanuel said: I understand. I don't appreciate downvotes at all. Pretty coward stuff to be sincere. They might be banned for once IMO. I also approve your fair concern on topic now. Lack of personal consideration cannot be tolerated at any rate. It is not a matter of opinion, but decency actually. I agree. The downvoting option is not a good option to have. Emanuel 1 Link to comment Share on other sites More sharing options...
Emanuel Posted June 9, 2019 Share Posted June 9, 2019 17 minutes ago, Grimor said: Lo siento, no volverá a ocurrir! No worries, next time you'll be shot dead! ; -) Grimor 1 Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted June 9, 2019 Super Members Share Posted June 9, 2019 Just found his review from Curtis st Grimor, Emanuel and sanveer 3 Link to comment Share on other sites More sharing options...
