bobinvegas Posted April 25, 2019 Share Posted April 25, 2019 there is a Mitakon Zhongyi Speedmaster 50mm f/0.95 III Lens for Sony E but I can't find an E to L adapter... only EF to L and SA to L from sigma. Mitakon makes the same lens in RF but not EF. My purpose is to shoot video in dark nightclubs in low light. I want to spend up to 4000 for the camera, adapter and lens. Is this setup even a good strategy? Thanks for any advice. Link to comment Share on other sites More sharing options...
Administrators Andrew Reid Posted April 25, 2019 Administrators Share Posted April 25, 2019 Leica M adapter, Leica Noctilux 50mm F0.95, sorted No the E-mount lenses won't go on, but not a lot of difference between F0.95 and F1.2 for low light really. The S1 is also extremely clean at high ISO so it's questionable you even need faster than F2 for nightclubs. Link to comment Share on other sites More sharing options...
Super Members BTM_Pix Posted April 25, 2019 Super Members Share Posted April 25, 2019 There is also the 7Artisans 50mm f1.1 Cheaper than the Mitakon too. webrunner5 1 Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted April 25, 2019 Share Posted April 25, 2019 I don't really think its necessary. 1.4 is very fast on full frame especially since you can crank the iso up pretty high. Emanuel 1 Link to comment Share on other sites More sharing options...
bobinvegas Posted April 25, 2019 Author Share Posted April 25, 2019 but going sub f/1 will double the amount of light from f/1.4, correct? making an image twice as bright with no increase in noise? it seems like a significant difference. I will look into the 7Artisans, thank you. but with either lens it requires an adapter, correct? aside from losing the features of the lens like stabilization and auto-focus, is there a negative effect to using an adapter with a lens that is not native? Link to comment Share on other sites More sharing options...
Emanuel Posted April 25, 2019 Share Posted April 25, 2019 I find f/1.8 pretty fast enough nowadays on the best sensor performance available today of MFT size per se, go figure... LOL : -) Link to comment Share on other sites More sharing options...
kye Posted April 26, 2019 Share Posted April 26, 2019 If you don't already own an S1 then you might consider if a different camera has better high-ISO performance or DR. I'm not saying there is one, but it would be worth checking against things like the A7III, etc. Link to comment Share on other sites More sharing options...
bobinvegas Posted April 26, 2019 Author Share Posted April 26, 2019 thanks. the a7iii has very little noise at high iso in dark settings but i'm avoiding that camera because it only does 8 bit color. can't wait for the a7siii but it seems like it is a long way away. the s1 tests i've seen online appear to have similar performance to the a7iii and a7sii. i haven't seen another camera that comes close to those for lacking noise at high iso in low light. i completely understand the gut feeling that 1.4 and 1.8 are very fast but i have spent the last year watching footage captured in dark nightclubs and i feel that i am hyper sensitive to the amount of noise and detail that can be captured at in those dark environments. my goal is to try to get the best possible exposure... full frame, 10 bit and around f/1. Link to comment Share on other sites More sharing options...
Mmmbeats Posted April 27, 2019 Share Posted April 27, 2019 Good luck focussing on club subjects at that aputure and sensor size. Extremely difficult task. Link to comment Share on other sites More sharing options...
Geoff CB Posted April 27, 2019 Share Posted April 27, 2019 Voigtlander 40mm 1.2 with the A7III or A7s II. Plenty brightness for your needs and sharp from wide open. Anything wider or faster on full frame will up your budget considerably. Simon Young 1 Link to comment Share on other sites More sharing options...
Robert Collins Posted April 28, 2019 Share Posted April 28, 2019 On 4/26/2019 at 5:49 AM, bobinvegas said: but going sub f/1 will double the amount of light from f/1.4, correct? Actually that isnt correct. F stops measure the aperture. Light transmission is measured in T stops. The T stop is always higher than the f stop as some light is lost in transmission through the lens. The faster the f stop lens you use - typically the greater the amount of light you lose. So as an example.... https://www.dxomark.com/olympus-m-zuiko-digital-ed-25mm-f-1-2-pro-lens-review-solid-choice/ https://www.dxomark.com/panasonic-lumix-g-25mm-f1-7-asph-micro-four-thirds-mount-lens-review-attractive-option/ the olympus 25 1.2 is t stop 1.8 and the panasonic 25 1.7 is t stop 2.0 So, as a guess, if you go from f1.2 to f0.95 you will probably only gain a third of a stop more light. Link to comment Share on other sites More sharing options...
