Sharpest setup
Rikoshet
Hello guys!
Need an advice and your experience here. Looking for sharpest setup.  As I understand to shoot anamorphic we need:
1. taking lens. I will choose a modern one, maybe sigma art o maybe a vintage one it depends on anamorphic adapter. I'll be using it on Pocket 4k so I need to start with 50mm equivalent like 25mm m4/3 lens.
2. anamorphic adapter. Better 16mm or 35mm?
3. single focus adapter. As I understand from the big Tito Ferradans review, the rectilux is the sharpest, ok. Which anamorphic adapter is sharpest, is there a list somewhere?
Thank you!
1. modern glass, so native high quality M4/3 glass from Panasonic or Olympus or veydra.
2. cinelux ES
3. Rectilux HCDNA
You will get oval bokeh and some corner distortion ,that will be very sharp but sterile .
You should rather consider vintage primes as taking lenses, you will get less sharp results but something with more live in it.
Just a reminder:
You'll get a massive vignette if you use 25 mm M4/3 lens with a 2x anamorphic adapter.
The widest you you could go is 42.5 mm
14 hours ago, heart0less said:
Just a reminder:
I don t think that true, I can go 55mm with a cinelux 2x + rectilux on full frame .
You should be able to use a 28mm if you don t use a speedbooster.
Even in photo mode?
Or in video (after cropping out the sides in order to finally deliver in 2.35:1) ?
That'd be quite a feat, though everything is possible. Especially in anamorphic world.
Meanwhile, OP mentions M4/3 camera, which most likely means GH5 and therefore - 4:3 open gate mode.
18 hours ago, heart0less said:
Even in photo mode?
actually he states pocket 4k
On 4/27/2019 at 8:58 PM, Rikoshet said:
1.  I'll be using it on Pocket 4k so I need to start with 50mm equivalent like 25mm m4/3 lens.
i am also wondering with the 2x crop on the p4k how wide one could go before vignetting ? the only rule i know of is about 85mm for full frame. How things work on m4/3  is a mystery i have yet to delve into.
On 4/29/2019 at 2:16 PM, heart0less said:
Even in photo mode?
in video mode with extraction for 2.39, I quickly tested in photo mode and I should also be able to extract 2.39 from it .
Basically the cinelux cover up to 42.5mm for 35mm, 4 perf anamorphic ( that a larger area than most super 35mm sensors), once you add a single focus solution in from you mostly cover up to 45mm .
https://www.pointsinfocus.com/tools/depth-of-field-and-equivalent-lens-calculator/#{"c":[{"av":"2","fl":42.5,"d":3048,"cm":"0"}],"m":0}
I did a data input there so you can see the equivalency per format.
That still theoretical as the lens design of the taking prime influence the values as well, but that a good ballpark.
Thank you Laurier! There some options for that focal lenght, what do you suggest? Zeiss, canon fd, russian lenses?
Thank you!
On 4/29/2019 at 3:16 PM, heart0less said:
Even in photo mode?
No, I said Pocket 4k camera so no open gate there.
Thank you anyway for your time!
Thank you!
If you want something sharp I will go zeiss I think, the russian 28mm is slow , and I did not try the FD.
Guest
Reply to this topic...
  Only 75 emoji are allowed.
