DBounce Posted May 5, 2019 Share Posted May 5, 2019 There is generally a pretty big difference in file size from 4K to 1080 to 720... but is the actual difference that much? Link to comment Share on other sites More sharing options...
Amazeballs Posted May 5, 2019 Share Posted May 5, 2019 I agree with ppl in the comments - it depends on what type of scene you shoot. If it is something with a lot of motion and shallow dof, then not that much. But if you shoot with more dof and less blur, you will clearly see it. Depends on lighting as well. I can see it very well in those scenes. Plus, there is always a post factor - do you want to be able to crop/zoom your video, push your grade more or less. Ofc there is a downside to 4k, a tax in disk space and computer power required to process and edit it smoothly. KnightsFan and Emanuel 2 Link to comment Share on other sites More sharing options...
Jrteh Posted May 5, 2019 Share Posted May 5, 2019 Never ending topic bcos nowadays most smartphone do delivery 4k webrunner5 1 Link to comment Share on other sites More sharing options...
webrunner5 Posted May 5, 2019 Share Posted May 5, 2019 Well if all you have is a 720, 1080p monitor or TV doesn't show hardly at all. But if you have a 4K TV or monitor I think it shows up like a sore thumb. And yeah like @Jrteh says, you can see it even now on Smartphones. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted May 5, 2019 Share Posted May 5, 2019 I can't really tell a difference unless cropping in. I never crop in so its pretty useless for me to be honest. Only makes a difference on youtube due to Youtube's weird compression. But you can just upscale your 1080 to 4k and it looks good. Link to comment Share on other sites More sharing options...
Mako Sports Posted May 5, 2019 Share Posted May 5, 2019 I crop in a good bit and 4K helps with post stabilization for the few times im not using a tripod. However Its hard to tell when watching on a tiny phone screen, but I watch a ton of stuff on a 27'' and 25'' monitor so yes I can tell the difference. Also 1080p on a 4K TV usually looks kinda terrible. kaylee 1 Link to comment Share on other sites More sharing options...
KnightsFan Posted May 5, 2019 Share Posted May 5, 2019 I never notice a difference between 4k and 1080p for distribution even on a large 4k tv. However, with every camera that I have used or edited footage from, downscaled 4k for a 1080p delivery is significantly better than natively shooting 1080p. For capture, I think 4k is without a doubt "worth it" in terms of SD card and disk space, and processing power--unless you need a very quick turnaround and don't much about image fidelity. 4k is also very useful for green screening, motion tracking, and other information-hungry VFX processes, especially if you downscale to 1080p afterwards. On the other hand, I can't honestly say I see a difference between downscaled 4k and native 1080p after YouTube compression. But FWIW it's a fairly well known trick to upscale 2k to 4k just to get a higher bitrate on YouTube, if the bandwidth supports it at the streaming end. Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted May 5, 2019 Share Posted May 5, 2019 I got a 4k monitor thinking I'd be amazed, but I truly can't tell a difference between it and my 1080 monitor, its slightly larger than my 1080 monitor though. kaylee and webrunner5 2 Link to comment Share on other sites More sharing options...
Amazeballs Posted May 5, 2019 Share Posted May 5, 2019 I have a 27 inch 4k monitor, but I could not tell the difference in most shots of Matti clip. Link to comment Share on other sites More sharing options...
Emanuel Posted May 5, 2019 Share Posted May 5, 2019 It depends on the level of detail of the shot and the size of the picture displayed, obviously. Where crop magnifications can pop up the differences in-between. There are human limitations, as well. Which means a much more noticeable difference from SD to HD or from 720p to 1080p rather than from 2K to 4K or even as far as the next 6K or 8K steps concern. Except if you'll print a large format. Then, the difference can be crucial between to have it or not to have. It is what it is. Like when you won't probably notice the difference between 10 to 100 millions in your bank account as much as from 10,000 to 100,000 or from there to 1 million. There's always a sweet spot in everything. In my country we're used to say the virtue is in the middle, for some reason ; -) Link to comment Share on other sites More sharing options...
kaylee Posted May 5, 2019 Share Posted May 5, 2019 20 minutes ago, Mako Sports said: I crop in a good bit that was a huge revelation after making my short in 1080p: i wish id shot a bunch of it just a little wider, and then cropped in during post. even if the extra pixels just go to straightening out a horizon line, it wouldve been super useful to have that 20 minutes ago, Mako Sports said: and 4K helps with post stabilization which is huge, bc several shots that i stabilized in post were ones that i didnt plan on stabilizing at all. 4ks great for adding camera movement, as well. lots of post stuff but this is my take for something thats grading/vfx heavy, so if you have a fast turnaround its a whole different story Mako Sports and webrunner5 2 Link to comment Share on other sites More sharing options...
kaylee Posted May 5, 2019 Share Posted May 5, 2019 edit: the difference between 4k and 1080p on youtube on my 1080p TV is huge. of course i notice it! that being said, you need to have an objective idea of the resolving power of a grid of pixels... whether its 2k, 4k, whatever, theres a high end limit to the detail in an image at a given resolution, and MOST cameras dont approach that in any mode whatsoever, so its kind of an abstract comparison ? an analogy: my 5d3 shoots ~soft~ stills, to me. pleasantly soft, dreamy stills at 22 megapixels, compared to the *actual resolving power* of that 5760x3840 grid, right? other manufacturers have razor sharp images at 100%, in comparison, at the same spatial resolution. thats a matter of taste, but to think that 22 megapixels = my camera is of course retarded Link to comment Share on other sites More sharing options...
thebrothersthre3 Posted May 5, 2019 Share Posted May 5, 2019 37 minutes ago, kaylee said: edit: the difference between 4k and 1080p on youtube on my 1080p TV is huge. of course i notice it! that being said, you need to have an objective idea of the resolving power of a grid of pixels... whether its 2k, 4k, whatever, theres a high end limit to the detail in an image at a given resolution, and MOST cameras dont approach that in any mode whatsoever, so its kind of an abstract comparison ? an analogy: my 5d3 shoots ~soft~ stills, to me. pleasantly soft, dreamy stills at 22 megapixels, compared to the *actual resolving power* of that 5760x3840 grid, right? other manufacturers have razor sharp images at 100%, in comparison, at the same spatial resolution. thats a matter of taste, but to think that 22 megapixels = my camera is of course retarded Youtube is not a good way to compare 1080 to 4k. Link to comment Share on other sites More sharing options...
kye Posted May 5, 2019 Share Posted May 5, 2019 I think 8K will be worth the tradeoff... oh, hang on. kaylee 1 Link to comment Share on other sites More sharing options...
kaylee Posted May 5, 2019 Share Posted May 5, 2019 2 hours ago, thebrothersthre3 said: Youtube is not a good way to compare 1080 to 4k im aware of that, it was a gross generalization about "seeing a difference' Link to comment Share on other sites More sharing options...
IronFilm Posted May 5, 2019 Share Posted May 5, 2019 So we're making an argument for 720 now? Mako Sports, Kisaha, kaylee and 1 other 4 Link to comment Share on other sites More sharing options...
Emanuel Posted May 5, 2019 Share Posted May 5, 2019 Something missing here is the fact (or not) about the sensor native resolution used, as well, color depth and bit rate as for instance. That equation counts much more than some other nonsense math for the subject matter strictly based on 4K vs 1080p or 720p acquisition. There are other variables completely ignored over here on this discussion. webrunner5 1 Link to comment Share on other sites More sharing options...
kye Posted May 5, 2019 Share Posted May 5, 2019 16 minutes ago, IronFilm said: So we're making an argument for 720 now? It makes a pretty speedy proxy resolution! I'm all for it!! kaylee 1 Link to comment Share on other sites More sharing options...
Jimmy G Posted May 5, 2019 Share Posted May 5, 2019 What I got out of that clip was a good argument for considering one's resolution as another, um, "film stock" choice (along with, oh say, Picture Profiles) based on one's shooting intent and delivery intent. For a "15 Jump Cuts of handheld footage for a 44-second quick-turn-around video of "My friend rocking his Electric Skateboard" intended for cellphone consumption on YouTube" (which will not be critically viewed, and will likely be forgotten by the time the viewer reaches their subway stop! Ha!) he makes a good argument for one to consider shooting cheap and fast with not only one's gear choices but also with one's resolution choices (with the caveat, "where applicable"). IMHO. However, if one's shooting intent and viewing intent is for considered consumption where the viewer is taking-in the entire scene while expecting high quality footage (read: commercial shoot, weddings, sports/action showcasing/highlighting, cinematic content) on larger 4K (or even, HDR-capable) screens then to my tastes, shooting at 1080 or 720 might/would work if tossed in "here and there as artistic cutaway shots" but not as the primary resolution choice. Case in point, it's very clear and obvious to me when these GH5S scenes drop to 1080 for slow motion vs the 4K main content... Surprising Results Filming with GH5S from Panasonic - YouTube: ...well, my 2¢ on the matter. Link to comment Share on other sites More sharing options...
kaylee Posted May 5, 2019 Share Posted May 5, 2019 if youre trying to do a comparison thats even in the realm of objectivity, take what you think is a high quality 4k clip, render it out at 1080p, and watch both. compare. easy this video is wildly subjective, it makes its point, but... cmon Link to comment Share on other sites More sharing options...
