mindcut Posted August 12, 2013 Share Posted August 12, 2013 https://vimeo.com/72049588 Some more files from the Black Magic Pocket Camera. Graded with FCPX. Changed Saturation, Exposure. Link to comment Share on other sites More sharing options...
Axel Posted August 13, 2013 Share Posted August 13, 2013 We need two things in FCP X for proper grading: 1. The function to save and load a reference clip for a splitscreen comparison (or sth. else that lets you see the grade in context), 2. ALL color correction parameters must be keyframeable. Other than that, for those who don't know FCP X, CC is much simpler and easier than in most other NLEs. It's not an effect or filter, it's done in the always-available clip-info. Link to comment Share on other sites More sharing options...
peederj Posted August 13, 2013 Share Posted August 13, 2013 I'm impressed with your grades mindcut. Some of the best posted on this site. FCPX is deceptively simple, but you can do nearly everything you need with just the stock tools in it for well-captured footage. To get around keyframeable color in FCPX, you can blade the clip and dissolve across the cut from one correction to another. To have a comparison frame, you can just use the Match Color view, without necessarily picking a color to match. This also lets you match someone else's footage or still you import. Another way of doing that is Window->Show Event Viewer, and load your still or whatever (you can export and re-import a still from your timeline for this if you want) into it next to the footage you're grading. Axel 1 Link to comment Share on other sites More sharing options...
Axel Posted August 13, 2013 Share Posted August 13, 2013 To get around keyframeable color in FCPX, you can blade the clip and dissolve across the cut from one correction to another. To have a comparison frame, you can just use the Match Color view, without necessarily picking a color to match. This also lets you match someone else's footage or still you import. Another way of doing that is Window->Show Event Viewer, and load your still or whatever (you can export and re-import a still from your timeline for this if you want) into it next to the footage you're grading. Very good. Esp. the match color view. Thanks! Link to comment Share on other sites More sharing options...
Lee Mullen Posted August 14, 2013 Share Posted August 14, 2013 https://vimeo.com/72248107 Link to comment Share on other sites More sharing options...
