Iscorama 54 support clamp
Robin Kautto
http://www.ebay.com/itm/Anamorphic-iscorama54-Arriflex-28mm-40mm-100mm-T2-1-lens-set-/130969054679?pt=Camera_Lenses&hash=item1e7e5d2dd7
Where can I buy this kind of lens support clamp for my iscorama 54? Also willing to find the 80mm dia rear filter.
I have sent him a message but no answer as of yet.
The support is probably a custom job, as i've never seen them for sale & i did look quite hard for one.
Same goes for the rear filter.
Be interesting to hear his answer...
I use the Cavision mount http://www.bhphotovideo.com/c/product/750371-REG/Cavision_R15_LS25100M_Lens_Support_with_Metal.html with my Iscorama 54
 but I have a rear adapter ring replacement made by Redstan which changes the rear filter size and is slightly wider on the outside diameter.  I'm told he's out of them.  Even with that it requires a thin piece of cardboard (like those that come in packets of photo printer paper) to make a tight fit.  It's too roomy with the stock Iscorama 54 rear ring but could probably be built up with the right material.
