Danielius Posted June 3, 2019 Share Posted June 3, 2019 Hi, I just bought a tripod at a local flea market, however it came without rubber feet. A straightforward option would be to buy original replacement feet, however they are double what I payed for the tripod itself. Do you happen to know of any knockoff alternative options for such item? https://cvp.com/product/vinten-v4160-1901-rubber-feet-flowtech?gclid=Cj0KCQjwitPnBRCQARIsAA5n84nWXBtOfQj3JNWJNW_Zqsi7wmWrcN4cX62KrqizV3h5lXCzOe22KgUaAoe8EALw_wcB Cheers Link to comment Share on other sites More sharing options...
webrunner5 Posted June 3, 2019 Share Posted June 3, 2019 I Seriously doubt anyone makes a knock off of those feet. Probably the reason you got it cheap. Unless the tripod meets your needs and is a heck of a good tripod depends if you buy the feet from Vinten or throw it away. They make damn good stuff, but there low end is nothing to write home about just like all the others players are also. A Good, great Tripod and head cost a fortune unless you really luck out on a used one. And they are about as important as anything, even today to have. Danielius 1 Link to comment Share on other sites More sharing options...
Danielius Posted June 3, 2019 Author Share Posted June 3, 2019 42 minutes ago, webrunner5 said: I Seriously doubt anyone makes a knock off of those feet. Probably the reason you got it cheap. Unless the tripod meets your needs and is a heck of a good tripod depends if you buy the feet from Vinten or throw it away. They make damn good stuff, but there low end is nothing to write home about just like all the others players are also. A Good, great Tripod and head cost a fortune unless you really luck out on a used one. And they are about as important as anything, even today to have. Thank you, I think you are spot on here. It was 150£ for Vision 11 head, Carbon Fiber legs, Vinten dolly all in a padded case. I will just get the original ones. webrunner5 1 Link to comment Share on other sites More sharing options...
tupp Posted June 3, 2019 Share Posted June 3, 2019 Might be worthwhile to attempt to find some other solution. Wonder if these would work at £48.00: Danielius 1 Link to comment Share on other sites More sharing options...
webrunner5 Posted June 4, 2019 Share Posted June 4, 2019 3 hours ago, Danielius said: Thank you, I think you are spot on here. It was 150£ for Vision 11 head, Carbon Fiber legs, Vinten dolly all in a padded case. I will just get the original ones. As far as I can tell that rig is like a 6,000 Dollar or more setup new. Yeah I think I would spend 132 Dollars for the feet lol. Danielius and newfoundmass 2 Link to comment Share on other sites More sharing options...
newfoundmass Posted June 4, 2019 Share Posted June 4, 2019 4 hours ago, Danielius said: It was 150£ for Vision 11 head, Carbon Fiber legs, Vinten dolly all in a padded case. I will just get the original ones. ? Jeez! Danielius and webrunner5 2 Link to comment Share on other sites More sharing options...
Danielius Posted June 4, 2019 Author Share Posted June 4, 2019 8 hours ago, tupp said: Might be worthwhile to attempt to find some other solution. Wonder if these would work at £48.00: Thank you - these look exactly like the feet on the dolly! Also, judging from Amazon reviews, seems like people are having luck using Manfrotto feet for Vinten tripods. I will try your suggestion first and let you know which one works 5 hours ago, webrunner5 said: As far as I can tell that rig is like a 6,000 Dollar or more setup new. Yeah I think I would spend 132 Dollars for the feet lol. Off-topic: a few weeks back, I bought a used Ursa Mini 4.6K for 1200£ from a local CEX. It came with 2 VLock batteries, a charger, two 128gb CFast cards, and a top handle. Seems like every time a new ‘revolutionary’ camera is announced, these shops are flooded with older generation tech, priced lower than everything on eBay. webrunner5 1 Link to comment Share on other sites More sharing options...
webrunner5 Posted June 4, 2019 Share Posted June 4, 2019 Where do you live to see such great deals? I have Never been that lucky lol. Danielius and newfoundmass 2 Link to comment Share on other sites More sharing options...
newfoundmass Posted June 4, 2019 Share Posted June 4, 2019 7 hours ago, Danielius said: Thank you - these look exactly like the feet on the dolly! Also, judging from Amazon reviews, seems like people are having luck using Manfrotto feet for Vinten tripods. I will try your suggestion first and let you know which one works Off-topic: a few weeks back, I bought a used Ursa Mini 4.6K for 1200£ from a local CEX. It came with 2 VLock batteries, a charger, two 128gb CFast cards, and a top handle. Seems like every time a new ‘revolutionary’ camera is announced, these shops are flooded with older generation tech, priced lower than everything on eBay. I hate you! Danielius, webrunner5 and JordanWright 3 Link to comment Share on other sites More sharing options...
Danielius Posted June 5, 2019 Author Share Posted June 5, 2019 On 6/3/2019 at 11:16 PM, tupp said: Wonder if these would work at £48.00 Just got a set of Manfrotto feet for 32£, they work a treat. https://www.amazon.co.uk/Manfrotto-565-Rubber-Shoes-Spiked/dp/B00131GCAC/ref=sr_1_5?keywords=manfrotto+feet+rubber&qid=1559735204&s=gateway&sr=8-5 Thank you for the suggestion xx 23 hours ago, webrunner5 said: Where do you live to see such great deals? I have Never been that lucky lol. London, UK. It's a tedious work looking for these deals webrunner5 1 Link to comment Share on other sites More sharing options...
Shirozina Posted June 5, 2019 Share Posted June 5, 2019 The CEX website has some good deals but I'm not sure everything in the stores is up there. You have to ask where some of this stuff comes from if someone can walk in off the street with a bit of kit and then walk out with some cash......... Danielius 1 Link to comment Share on other sites More sharing options...
