ronjbase Posted August 22, 2013 Share Posted August 22, 2013 When I import my GH3 files into FCPX the clips names are change to the event name. Is there a way to prevent this, would like to keep the original file nameif possible. Thanks in advance. Ratguity 1 Link to comment Share on other sites More sharing options...
Axel Posted August 22, 2013 Share Posted August 22, 2013 Strange. How do you get them to change their names? Describe your procedure. There are a lot of options in FCP X how to import clips. I am eager to learn a new one. Link to comment Share on other sites More sharing options...
ronjbase Posted August 27, 2013 Author Share Posted August 27, 2013 Just import from card the only items check off in the import settings box are in the Transcoding choices , both are checked Link to comment Share on other sites More sharing options...
Axel Posted September 8, 2013 Share Posted September 8, 2013 Took me a while. Because I thought you meant that FCP X changes the original names of the clips, which it doesn't. Per default - at least as long as you work with original media - the clip names in the event browser show the date. But it's just a read-out of metadata that can be changed at every time and has no influence on, say 'clip-037.mts'. You can batch-rename clips by choosing them and clicking the gear-icon in info (lower right). There you can apply rules of numbering and renaming and also 'original name'. The latter option, however, won't display any non-QT-extension, because even with native AVCHD you will have mov-rewrapped copies that FCP X refers to. Link to comment Share on other sites More sharing options...
ronjbase Posted September 8, 2013 Author Share Posted September 8, 2013 Thanks, Shooting 50Mbps inthe .mov mode hope that doesn't make a difference. Will have to try that... figured it was something simple. Link to comment Share on other sites More sharing options...
